Question about Panasonic SD-2501WXC Automatic Breadmaker with Nut & Raisin Dispenser & Gluten Free Program
Rest time a problem.Can it be skipped?
The rest time makes the cycle too long when I want to make dough.Is there any way of resetting the programmes to avoid this step?
My wilbilt machine didn't have manual book . I make a dough in it but didn't cook I put on white bread setting What time I should put in d time I started it or what
You must have an indicator on the machine for what kind of bread to make, Put ingredients in and press the loaf setting of your choice and the machine should to the rest.
Your machine or any machine, does NOT cook the dough. You have to do that after you shape into a loaf or buns.
Nov 07, 2017 | Kitchen Appliances - Others
Tip
8 Steps to Fixing Any PS3 Issue
Note: If your PS3 is on, but you are looking at a blank screen, you PS3 may be in HD mode.
  • Turn off your PS3.
  • Hold down the power button for 2 beeps. This will reset your PS3 video to standard output.
  • If you are unable to reset your video, skip to Step 8.
  1. Back Up your PS3. You will need a compatible external hard disk drive for this step.
  2. Enter Recovery Mode.
  3. Choose "System Update".
    Try to load a game or movie. If it works, skip the rest of the steps listed below; otherwise, continue.
  4. Re-enter Recovery mode, and choose "Restore Default Settings".
  5. Re-enter Recovery mode, and choose "Restore File System".
  6. Re-enter Recovery mode, and choose "Rebuild Database".
  7. Re-enter Recovery mode, and choose "Restore PS3 System". WARNING!: This option will delete everything on your PS3 hard disk drive!
  8. Return the unit to Sony. If your PS3 is still under warranty the fix will be free; otherwise it will cost $150.
on Mar 26, 2010 | Sony Playstation 3 (PS3) Console
How can i fix dough that wont rise?
Check if yeast is old out of date, expired. When making bread most items should be at room temperature unless the recipe calls for milk to be heated to a certain temperature. Follow instructions carefully. Note the differences in Canadian and American flour you will need more American flour if you are using American flour in a Canadian recipe. When making bread the type and or brand of flour will effect the outcome , humidity also affects bread. As to the outcome of bread kneading , resting, texture are something you learn. If dough is to dry add 1 tablespoon of water at a time , if too wet add 1tablespoon flour, dough should neither be sticky or to dry , should feel like silk . Seasons change the affect of how flour works. Drafts also effect dough, when dough is left to rise it should be placed in a place away from drafts and is warm. A well greased bowl large enough so that the dough can double in size this usually takes about 1 hour don't rush this part. Dough should be greased on top so it will not stick to what it covered with. Once the dough has doubled in size punch it once done, either cut into loafs or into buns, place desired greased pans cover let rise again about one hour. Put in oven set at required temperature , set timer for 15 min, check for brownness, if it is not to your liking leave it oven for another 5 mins, bread or bun's are done when they are tapped on top and it sounds hollow take out of oven let rest in pans for about 5 min's, place cooked bread on rack and let cool, do not place on flat surface as the bottom will sweat it needs to have air flow all around it to cool properly. PS remember making of bread is a labour of love, because it lets you take out any anger while you beat and fold the dough, the dough loves you for this and it will give back to you a light and airy texture. Keep on loving.
Aug 04, 2014 | Baking
HI, I use the dough cycle and it takes 1 hour 20 minutes, but it actually only kneads the first 10 minutes and then here and there a minute for all together about 15 minutes of kneading. Is my machine not...
It sounds like everything is OK...machines knead a while,,,,rest a long time....knead a little rest along time etc......that resting allows the dough to rise....
Feb 27, 2011 | Breadman TR555LC Bread Maker
WEST BEND BREAD & DOUGH MAKER MODEL 41041Z. ALL INGREANTS IN TUB, PRESS ''START'' MACHINE SHOWS ''REST''
Jul 25, 2010 | West Bend Kitchen Appliances - Others
How to reset unicom 51152
After inserting battery, press "000" then PROG.Enter your new 1-6 digit code and press PROG again.
To programme the alarm timing, press PROG then press:-
1 for 30seconds alarm 2 cycles, 20 seconds rest in between.
2 for 60seconds alarm 2 cycles, 30 seconds rest in between.
3 for 90seconds alarm 2 cycles, 30 seconds rest in between.
any more you wanna know let me know.
Tonybeatty@hotmail.com
Feb 03, 2010 | Kitchen Appliances - Others
Panasonic bread machine SD253. Programmer
The only thing you can do for these machines is the following:
first, if the unit is always plugged in, disconnect it for at least an hour.  This may reset it.
I doubt there are parts...but if you disassemble the unit and cycle all of the connectors, you may get lucky.  IF parts exist, you'll likely need a timer module.
Nov 10, 2008 | Panasonic Kitchen Appliances - Others
Panasonic SD-2501WXC Automatic Breadmaker with Nut & Raisin Dispenser & Gluten Free Program Logo
270 people viewed this question
Top Panasonic Kitchen Appliances - Others Experts
Irene Tulloch
Oloyede Monsuru
Are you a Panasonic Kitchen Appliances - Other Expert? Answer questions, earn points and help others
