I have a vizio plasma 42" hdmi 720p 1080i tv with
  • 933 Answers
The panel part #'s will have to match exaclty, the Ysus board # will have to match as well.
Posted on Dec 31, 2012
3 Suggested Answers
SOURCE: ysus board blowing fuses. any clue 42 inch esa made by LG
I have the same problem. Did you find a solution?
Posted on Feb 10, 2010
  • 2318 Answers
SOURCE: Some troubleshooting help please.
The part that caused the fuse to blow is the hybrid that is mounted underneath the heatsink on the YSUS and ZSUS boards. The part used on these boards might be YPPD-J017C or YPPD-J018C, in about 90% of the time, replacing these hybrids fixes the plasmas with no video but good audio. Since VS and GND is shorted, that means that the hybrid has shorted internally. Most service techs would rather replace the entire YSUS or ZSUS boards since the hybrids are very difficult to remove.
Let me know if you require further assistance.
Posted on Apr 09, 2010
Testimonial: "Appreciate the good info and quick reply. THANKS VERY MUCH"
Viore 42" (PDP42V18HA) HDMI WOES
More than likely you ruined the HDMI circuit. Over twice the required voltage is never good.
Jul 11, 2016 | Vizio 42" viore pdp42v18ha 720p widescreen...
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
Dec 30, 2015 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
Vizio hdmi blacking out when displaying PS3 in 720p
in these case hdmi technology is new then ps3 you will use the hdmi or usb display mediator for ps3
Feb 09, 2012 | Vizio XVT3D424SV 42 in. 3D LCD TV
How can I switch my screen resolution on the Pioneer PDP-4270 from 480i to 720i or 1080i? HDMI cable is connected appropriately. I have tried new HDMI cables, and pressing reset to factory settings along...
Change the resolution on the cable box or satellite box, witch ever you have. A set by itself cannot change the resolution, if the cable is giving you 720p, that's what you'll see for that station. All stations do not transmit in HD. The best picture is only as good as they're giving you.
Dec 19, 2010 | Pioneer PDP-4270HD 42 in. Plasma...
Cannot adjust picture size on vizio
If the picture size isn't changing with the television's picture size adjustment setting there could be a few things going on. Check to see that you're in the right input on the television i.e. if you are connected to a high definition receiver make sure you are not in the tv/tuner input (tv display would say analog channel 3 or 4). Make sure your tv is switched to the high definition input i.e. component 1 hdmi 1 and etc. If you are in the high definition input already check and see that your cable box or satellite tv receiver is set to the proper resolution. For example if you have a 720p television make sure the cable box is set to 720p not 1080i. Last but not least look for the hd zoom # button on the cable remote. The button may also say format or aspect.
Aug 19, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
Cracked plasma screen
honestly probably not worth it
May 31, 2009 | Insignia 42" Flat-Panel Plasma HDTV
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
Adjust the system's video output settings. Select the best output settings for the TV in use.
1. Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1
HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p
Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i
Composite / S Video *3 480i 576i
AV MULTI / SCART *4 480p / 480i 576p / 576i
*1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5. Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
6. Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
7. Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
I have the NS-PDP42 42" PLASMA 720-P and I would like to know how to change the screen resolution for hdmi devices. In the user guide it says to change it to 1280 x 720p but it does not tell how to...
There's no way to tell the HDMI input whether it should take 720p or 1080i input on this set. The best thing to do is experiment. Set your Comcast box to 720p and watch it that way for a while, then set it to 1080i and watch it for a while. The PDP42 has to do a little picture manipulation in either mode, but I think you'll find that the 720p mode will work best for you. I have this set with Verizon FiOS and I have the FiOS output set to 720p. Looks great, no complaints.
Jul 23, 2008 | Televison & Video
Picture shifts to left
I had the offset left issue for non-HD channels with my Panasonic 42" plasma, using Comcast HD cable box. Went into the configuration menu (to get there with the newer Comcast boxes, you have to turn the box off, then hit the menu button on the box immediately after). You will see on the menu a resolution (probably says 1080i), then below it a "4:3 override". Our said 480i. When I changed it to "none", so that it stayed 1080i, it worked! It also works by selecting 480p, but then the picture is stretched.
Mar 13, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Ilo 42" plasma tv
Go the the settings on the cable box. look for output resolution, then change it to 1080i and 720p. now turn the box off and back on your tv will now display the input of wither 1080i or 720p depending on the hd channel your watching.
Dec 26, 2007 | Televison & Video
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
Electro Med Services...
