Question about Maytag Dishwashers
How do i clean the food filter in a MDB-9 maytag dishwasher
  • 20 Answers
SOURCE: No power to Maytag Dishwasher MDB-8
no breaker on motor look at door lock ***. for power
Posted on Feb 18, 2009
SOURCE: Maytag dishwasher filter (?)always clogging
How do I take apart and clean the filter, I've gotten the screws out but to do now?
Posted on Sep 18, 2009
rylee_smith
  • 8619 Answers
SOURCE: My Maytag dishwasher Model # MDB-3 will not drain.
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Nov 03, 2009
  • 677 Answers
SOURCE: maytag performa dishwasher PDBL390AWB - dirty dishes
The problem is hard water. Go to www.dishwasherfilter.com and get their new product. It filters the water and takes out the hard minerals that cause spots and clog dishwashers. It is very affordable and has a money back guarantee.
Posted on Mar 18, 2010
SOURCE: Maytag dishwasher legacy 300 quiet series
I was so impressed with the advice on this website, I thought I would take a stab at this. The difference is, I will include all the steps, so if I go into a little too much detail for you, I'm sorry, but I felt a few things got left out that needed to be said.
Tools Needed: screwdriver with t-15, and t-20 torx bits (available at any hardware store), and a pair of pliers. Also I used a headlamp so I did'nt have to hold a flashlight with my teeth.
step#1- Clear a spot on your counter or kitchen table and remove both the lower and upper racks from your dishwasher. The lower rack just lifts out, the upper you will find two light blue plastic caps that once removed will allow you to slide the rack off of the metal slides. Next, the long L shaped spray bar that goes up the back and across the top needs to be un-clipped and removed, 2 clips at top and 2 clips at the back. It might take a little wiggling but that spray bar slides into the top cover, once unclipped push back at the bottom and tilt the upper part toward you, it should come out fairly easily and give you wide open access to the cover. Next you want to remove the plastic nut that holds the spinner in place, using your pliers turn it counter clockwise, it should loosen fairly easily, and remove nut and spinner. Next with either a T-20 or T-25 torx bit, remove the 3 screws that hold the outer cover in place, notice the direction of the tube that plugs into the spray bar, make sure it goes back in the same way. Now remove the T-15 screw that holds the black grinder cover in place and remove screw and cover. Now remove the 6 screws that hold the inner cover in place and remove the cover. You can now see what all the fuss was about, mine included a piece of pistachio shell, a bay leaf, and a cherry pit. Once it's all cleaned out, just reverse these steps and be ready! You have just earned your place as your homes resident handyman or woman!
Posted on Jun 14, 2010
Where is filter on maytag mdb-9 dishwasher
If you wish to get more details visit the site linked here. http://homenol.blogspot.com/
Feb 22, 2017 | Maytag Dishwashers
I've got an MDB-9 and the arms are not spinning.
Oh, Judith, you're my kind of person. Try flushing the arms with your sink sprayer. There may be crud inside and it may be clogging the jets. That will prevent the arms from moving. If that doesn't do it, I have a .22 automatic so you can put the beast out of its misery.
One more thing, when I've called Maytag, the repair folk have been extremely helpful by walking me through solutions for my washer as well as my dishwasher.
Good luck.
Jun 12, 2011 | Maytag Dishwashers
I bought the unit almost a year ago -my warranty is not up yet- but i can't get it work properly. Dos not matter what i put in it or how it always comes out spotty or greasy or food particle dried on the...
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Apr 13, 2010 | Maytag 24 in. MDB5651A Built-in Dishwasher
I have a Maytag MDB dishwasher. We recently took apart the spray arm assembly down to the filter to clean out the lime. The problem is that the inside of the spray arm has such a build up of lime and we...
have you tried boiling it in vinegar? it might help. no garenties for that particular problem, but that's what I do with my kettle and chunks of lime come out when I do.
Jul 18, 2009 | Maytag MDB9600A Jetclean II Built-in...
No water comes in to wash dishes.
sorry to sound obvious, but you will have pull the dishwasher out to get to it, just follow the hose into the inlet valve unit, they are located under the unit at the back.
Jan 27, 2009 | Maytag 24 in. MDB9150A Built-in Dishwasher
Will not drain
common problem is detergent/power used, the filter becomes blocked, and the outlet solenoid becomes blocked.
Dec 16, 2008 | Maytag 24 in. MDB9150A Built-in Dishwasher
Nov 03, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Dishes have dried on food particles after cleaning
common problem with dishwashers, the filters become blocked/ break down, a cleaning cycle with an approved detergent usually fixes this. if not, the filters my need replacing.
Oct 24, 2008 | Maytag 24 in. MDB9150A Built-in Dishwasher
Maytag Dishwsasher Model MDB-9
The Switches do not oprate when you press them. What can be the reason?
Sep 27, 2008 | Maytag 24 in. MDB9150A Built-in Dishwasher
Lights flashing can`tstop
there is a clog in your filter trap once uncloged pull plug to reset dishwasher
May 30, 2008 | Maytag 24 in. MDB3700 Built-in Dishwasher
Dishwashers Logo
140 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
