Acer aspire wireless problem fix
Wireless connection to ATT's Pace modem/router is intermittent. Works fine with ethernet.
  • 7,627 Answers
Have you done all your Laptops updates, windows updates? Are you moving the laptop about the house and losing a signal? Is the laptop static and losing the signal? Many thing will interfere with a radio signal(wireless) Is the wireless Secured? Have you tried other channels?
Posted on Dec 31, 2012
  • 1 more comment
  • Kel Saito Jan 03, 2013
    Windows updates, yes. Acer driver updates, yes. Laptop static and losing signal.. Secured with WAP. Problem in laptop not in router because it was replaced with same symptoms.
  • max carson
    max carson Jan 03, 2013
    If you have other devices connected, do they have the same issues? If the Wireless router was replaced and you have the same symtoms ,does the laptop connect and stay connected else where? Did you replace the router? Did the ISP replace the router? Did the ISP verify and a Tech come out to analyze the signal? If the laptop will stay connected on some other wireless, I would suspect the ISP trouble is outside. If the laptop does noy stay connected with alother wireless, maybe the antenna has a bad connection, bad wireless adapter, roll back the wireless adapter driver. First you have test the wireless laptop connection by another wireless router.
  • max carson
    Another wireless away from your location, a hotspot, coffee shop, any where out of your loaction.
SOURCE: Acer laptop not conneted to 2Wire147 Moderm
what is the password to get into the wireless network?
Posted on Jun 30, 2008
SOURCE: acer aspire 5720 notebook with operating system XP was vista
Hi all, I must say, I now have an operating XP install on the Acer Aspire 5720Z thanks to this blog. Thank you all, and can confirm that this is a great solution.
http://www.acerpanam.com/flex/acerdrivers/bin/drivers.html?CFID=4394128&CFTOKEN=56207662
Cheers
Rfscann
Posted on Dec 12, 2007
  • 4 Answers
SOURCE: Acer Aspire 1640Z
You can try ?
turn off your moderm, turn off your wireless access point (2 minutes) and restart your computer.
Posted on Jan 26, 2008
frankzjm
  • 191 Answers
SOURCE: Acer Aspire 7730 UNABLE TO GET WIRELESS CONNECTIVITY
you need to try
1) check bios aetup screen thereis setting wireless enable/disable
and check xp control panel--system--device manager wireless driver no yellow triangle mark( which need update driver)
2) check wireless switch at laptop frront or right side, set to "on" to make sure the wireless light not on. if wireless indicate light still black means your wireless card out of works, check wireless card by open small back cover clean pins and reinstall it again
3) finally you might need change a wireless card.
Posted on Feb 09, 2009
  • 30 Answers
SOURCE: Acer Aspire One will not connect to wireless router
Most Acers use an IPN2220 Wireless card. If yours does, you use XP, and your router is using WPA or WPA2 (TKIP or AES) security then you'll need to update the driver by searching for it manually using the Custom button (Hardware) in Windows update (instead of Express). This driver is not part of XP service pack 2 or 3. In my experience if you don't update to the newest common form of home wireless security (WPA2 AES) then the older formats seem to become unreliable in the way you discribe
Posted on Mar 25, 2010
Wireless not working on acer aspire 5551a
Connect to internet using ethernet cable and update wifi driver from makers site, if this does not work then buy a usb wifi adapter off ebay or from a local store, put it into usb port and install the driver from the disc supplied with the adapter and off you go (far cheaper than replacing the wifi card)
Jan 10, 2013 | Acer Aspire 5536-5224 Notebook
How to install to att 2wire 2701hgb modem router
Plug one end of an Ethernet cable into the modem's Ethernet output port and plug the other end into the router's single WAN/Internet input port.
Nov 09, 2017 | NetGear RangeMax Dual Band Wireless-N...
Need detailed help setting up my 2wire 1701hg gateway. I have high speed att dsl internet. I tryed already but att redirects me to there website, I tried calling them but they keep trying to charge mt 49$...
I can help you to configure the modem... Before that i need answers for certain questions....
How many lights are litup in your modem...? Do u have the light called "Internet and DSL" lit up in your modem ? Do you know the connection type ??? PPPoE If so do u know what is the Username and password ??
May 23, 2011 | 2wire (1000-100052-000) 802.11g/b Wireless...
Wont connect to internet
First, you might want to try plugging an Ethernet cable directly into the side of the laptop to make sure a direct connection works. If that works, ensure that your wireless switch is turned on (it's usually on the side of the laptop.) Other problems could be related to your router, or your computer's wireless card. If none of the solutions above work, try resetting your router by first unplugging the power, and then the cables, and then the modem's power and coax cable. Wait a few minutes, and plug it all back in. If that doesn't work, try updating your operating system.
May 04, 2011 | Acer Aspire One PC Notebook
Have an att 2700he-b wireless router. don't have dsl anymore. have cable internet & using cable ethernet output to use the 2700 as a router - works oOK for ethernet routing but need to set up the...
Are you trying to install the router.
You can do it manually without the CD.
MAke sure that your computer is able to go online
through the modem.
If your computer is able to go online through the
modem
Then you need to connect the computer to the router
ad the modem to the router.
open the set up page of the router and change the
settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 10, 2010 | 2wire Computers & Internet
Wireless connection works fine from the d-link router but the desktop linked from the phoneline keeps going offline. Why?
You've omitted some information about your hardware & configuration & connections.
You should have:
1. cable-modem connected to cable socket (or DSL-modem connected to telephone wall-jack);
2. router connected via Ethernet cable to the cable-modem (or DSL-modem)
3. desktop computer connected via Ethernet cable to the desktop computer
4. wireless device (iPod or netbook or notebook) connected over the "ether" to the router -- this connection will stay "up" almost "forever" (as long as there is AC-power to the router and power to the wireless device).
Which parts & connections do you have?
Dec 26, 2009 | D-Link Computers & Internet
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
2wire Wireless router not working w/Comcast cable modem
Its almost impossible to connect a 2wire DSL router with a Cable modem. They dont go hand in hand.
Although you can connect the outgoing ethernet wire from the modem in the last ethernet plug on the back of the router and then have the ethernet connections coming from the router. But not wireless. and if you find a way, contact me at jneal2k9@hotmail.com
Feb 03, 2008 | 2wire (1000-400108-001) Router
Wlan connection problem
please be specific, what exactly is happning???
Nov 07, 2007 | Acer Aspire 5630 Notebook
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
