Acer aspire 4339 wireless problem fix?
Wireless connection intermittent with router to internet.
frankzjm
  • 191 Answers
SOURCE: Acer Aspire 7730 UNABLE TO GET WIRELESS CONNECTIVITY
you need to try
1) check bios aetup screen thereis setting wireless enable/disable
and check xp control panel--system--device manager wireless driver no yellow triangle mark( which need update driver)
2) check wireless switch at laptop frront or right side, set to "on" to make sure the wireless light not on. if wireless indicate light still black means your wireless card out of works, check wireless card by open small back cover clean pins and reinstall it again
3) finally you might need change a wireless card.
Posted on Feb 09, 2009
  • 6 Answers
SOURCE: cannot connect acer aspire one to my tp-link router
go start run type services.msc then go down to the bottom click zero wireless configuration then click start and you should be good to go
Posted on Jul 14, 2009
  • 212 Answers
SOURCE: Acer aspire 5542 laptop won't connect wirelessly
GO TO START>NETWORK CONNECTION
CHECK WIRELESS IS THERE OR NOT
if not there
go to Start>Run type "services.msc"
start windows zero configuration
right click WIRELESS
properties
select wireless tab
put one tick mark in the use windows to configure.......................
ok
agin right click on wireless
view wireless network
search on wireless(leftside)
select connect
Posted on Nov 01, 2009
Testimonial: "Many thanks, slight difference in the names on the windows I had to open but it got me on the right track and problem solved."
  • 20 Answers
SOURCE: Won't stay connected to internet with wireless router
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
armania72
Posted on Jan 03, 2010
  • 30 Answers
SOURCE: Acer Aspire One will not connect to wireless router
Most Acers use an IPN2220 Wireless card. If yours does, you use XP, and your router is using WPA or WPA2 (TKIP or AES) security then you'll need to update the driver by searching for it manually using the Custom button (Hardware) in Windows update (instead of Express). This driver is not part of XP service pack 2 or 3. In my experience if you don't update to the newest common form of home wireless security (WPA2 AES) then the older formats seem to become unreliable in the way you discribe
Posted on Mar 25, 2010
My acer aspire wont connect to my centurylink wifi
Try re-installing the wireless card driver and the configure the wireless card to the wireless router's wireless settings. You can also have a look at the wireless card settings in the computers that is connecting to the wireless router/Internet and then apply these settings to the wireless card in the Acer.
Nov 08, 2012 | Acer Aspire 5253-bz692
Acer Aspire 5733 Wireless connection lost
Check the wireless router and high-speed modem.
If the two are not powered on, or if the Ethernet cable connected the two is not completely inserted into both connection ports, you are unable to access the Internet on the Acer Aspire One laptop computer.
Activate the wireless Internet connection on the laptop computer.
Right-click the wireless icon on the desktop, then choose "Enable" from the pop-up menu.
Without activating the wireless receiver on the Acer Aspire One, the laptop is unable to detect any wireless network.
Select the appropriate network you wish to connect to.
Your computer may be attempting to connect to a different Internet connection, preventing you from access the network you desire. Right-click the wireless icon, select "Search for available wireless networks," then choose the network you want to access.
Restart the computer.
The system may have booted and failed to detect the wireless receiver. Restarting the computer corrects this issue.
hope this helps
Sep 13, 2012 | Acer Aspire 5733 Laptop
Acer aspire onw - has signal with wireless connection but will not connected when clicking on browser
Connecting to wireless signal is not the same as connecting to the internet. Verify the wireless router itself is connected. Your internet provider may be off line.
Sep 07, 2011 | Acer Aspire One PC Notebook
I HAVE A ROUTER CONNECTED TO ANOTHER PC COMPTER AND I WANT TO CONNECT TO THE INTERNET WIRELESS ON MY ACER DESKYOP COMPUTER
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards in all the laptops/computers needs to be configured withthese router's wireless settings. Then the laptops/desktop computers cancommunicate with your wireless router and access the Internet via the DSL or cable modem.
Aug 03, 2011 | Acer Aspire L310 (ASL310UD631A) PC...
I do not know how to connect to internet thru wi-fi with my aspire 4738Z
Apr 21, 2011 | Acer Aspire 4730-4947 Notebook
ACER AS5738-6444 Notebook cannot see my wifi router?
The wireless card in the notebook needs to be configured with the Netgear's wireless settings ie. SSID, WPA encryption etc.
Please click on this link for my instructions on securing the wireless network, configure the wireless router and wireless card in the notebook :-
http://www.fixya.com/support/r3559128-wireless_router_security
Feb 05, 2010 | Acer Computers & Internet
I have lost my wireless connection on my laptop
Delete the Existing wireless connections in the laptop and create another one
This should fix the issue
Jan 03, 2010 | 2wire 2700HG-B Router (2700HGB)
I have a acer aspire 5315. I bought a D Link dir 615 wireless internet router. The problem I am having is that I can connect to the router, but I cannot connect to the internet. What is the problem?
Hi the router has not picked up your IP address.follow this Turn off your wireless router and internet connection and your laptop aswell for 30secs .Then first turn on your internet (if seperate from the router) if not switch on the wireless router/internet hub and wait untill the lights stop flashing then switch on your laptop and that should work.
Dec 15, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 4315 can't connect to internet through wireless ADSL router
netsh int ip reset reset.log
netsh winsock reset catalog
Reboot
Jun 09, 2008 | Acer Aspire 4315 Notebook
Computers & Internet Logo
135 people viewed this question
David Payne
David Payne
