Question about Minn Kota Riptide St Saltwater 80 Bow Mount Trolling Motor
The turn feature on my remote trolling motor will not work
Originally, I thought it was from low power but the thrust has full power and the batteries are fully charged and set for 24 volts. When I press the turn buttons on the remote, it makes a momentary hum (like it normally would when turning), but nothing moves. Any thoughts?
    Champion:
  • 204 Answers
Maybe the pin is sheated on the prop...or something is caught in it..
check the prop.
Posted on Dec 31, 2012
  • Joe F
    Joe F Dec 31, 2012
    Squipps, thanks for the response but the prop is clear and running full speed. The problem is the directional turning (left and right) does not respond.
3 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: model sp 70. When
The drive motor or gear solenoid could be bad.
Posted on May 06, 2010
SOURCE: I have a 74LBS thrust trolling motor that hasn't
i have a minn kota riptide 74 lb trolling motor. the plug on the trolling motor shorted out. i bought a new plug and it only has 3 pronges but the trolling motor has 4 wires and i can't get the right wires to work. which wires do you hook to plug.
Posted on May 17, 2010
Good battery , good battery in remote 70 lb thrust trolling motor - no go. ?
Hey Rob,, ??? ..Did you have the batteries CCA checked?? Cold Cranking Amps..?.. this is the only check to determine if your batteries are actually "good"...Next, take a volt meter and check the voltage at the trolling motor connection..if you have voltage at the plug, its time to move up to the head of the trolling motor...Since I do not know what brand if trolling motor we are working on.. these guys will take care of you from here...
home
Jul 09, 2017 | Boating
My bow mount 43lb thrust foot controlled trolling motor is only working in one speed. It must be in rapid speed be cause the motor only works with selector switch on the rabbit and not on troll.
needs to go to a repair shop for a new resistor unit in the motor .or one of the wires going thru the shaft has broken .they fail dueto the constant flex from turning
Dec 16, 2015 | Boating
I have a Motor Guide Brute 767, 67 lb thrust 24 volt trolling motor. It will only run at about half speed even with new batteries.
I believe you may have a bad low voltage circuit board problem. I do not think they make the board any longer but you may be able to convert it to work by bypassing the circuit board. I am working on one now.
Mar 22, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
Is there any way to modify in order to get more power/thrust out of a mk 30lb other than stock? or can you take a moto guide 80 lb., bow mount foot control, shaft and motor and combine it with transom...
Hey Chris,, you are starting a project (or wanting to) that is going to be problematic... It will be easier to go buy a new trolling motor with the money you are going to spend attempting this conversion... the newer trolling motors are so much more efficient...
Trolling Motors Fishing Motors Electric Boat Motors MotorGuide Trolling...
https://www.minnkotamotors.com/
Jul 15, 2017 | Minn Kota Endura 30 Freshwater Transom...
Why does my Minn Kota Vantage trolling motor act up.
If this is a foot control model, try cleaning the connection where it plugs up. I have cleaned mine but I still have to fidget with it every time to get it to work right.
Jun 22, 2009 | Boating
Motorguide Trolling motor has low thrust in all five speeds
I have a 4 speed with 48 lbs of thrust. On mine, 1 through 3 will move me out pretty well, however, 4th is similar to an overdrive gear in a car or truck and is meant more for maintaining a speed with less draw on the amps.
I certainly wouldn't want to take off with it. I suspect it is the same with your 5 speed. The boat needs to be up to speed and then those two gears will maintain it, with 5th being optimal as far as low draw in amperage.
May 22, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
My brother inlaw got a minkota 40ta all terraine trolling motor that is supposed to produce 40 pounds of thrust. it does not seem to produce even close to that. is it possible that the motor is turning the...
I would check the battery. If you're using an old or under charged battery you will loose power for sure. Make sure you're also using a 12v deep cycle marine battery as this will ensure proper operation and a longer battery life.
Apr 18, 2009 | Minn Kota Edge 40 Freshwater Bow Mount...
Wiring diagram for Die Hard 28 lbs thrust trolling motor
It's probably a Minn kota with a die hard label. Call Minn kota and ask them.
Aug 08, 2008 | Boating
Minn Kota Riptide St Saltwater 80 Bow Mount Trolling Motor Logo
186 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
