Question about Fuji Finepix Ax280 Pink
Hello i have a Fuji ax280 camera it will not switch on and the lens will not retract
2 Suggested Answers
  • 4090 Answers
SOURCE: fuji finepix A303, lens won't retract.
OK you are probably going to think I am loony giving you this advise But No I am completely sane!
Get a can of compressed air OR acces to a compressor at your local garage Get them to fit the triggered air blower tool to it.
Blow around the lens in all the extension joins the firmly slap it in the palm of you hand with the side of the camera making contact with you palm. Do the procedure two or 3 times and inbetween the slaps turn it on to activate the lens mechanism. I have now fixed about 80 of these cameras with this method. I obtained the fix from Sony who charge $90 to do exactly the same. Keep at it as it will eventually work. One tip, make sure the battery is charged before you do this.
Please rate our help to keep the FREE service online ++++ Thanks for using FIXYA
Posted on Sep 03, 2009
Fujifilm ax280 won't turn on
You think the lens got stuck. Don't use force, but try if the lens will move a little when pulled or pushed. Take care, there are gears on the lens and if the motor does not work, you will definitely damage some gears. You need power in the camera, to let the motor retract the lens.
If nothing works, you should go to your dealer, or contact Fuji.
I sometimes read you could try slamming your hand where the camera sits in, while switched on, but if you don't know enough about how everything works in your camera, don't do this. Because you end up with a camera that can't be repaired.
Nov 05, 2013 | Fuji Cameras
How can I rectify the "zoom error" message on screen - also the lens will not retract either
Hello
Unfortunately a "zoom error" message is not something that you will be able to fix. This error indicates a system failure (apparently your lens is damaged, since it will not retract) and requires the camera to be sent in for servicing and repair.
You may find it more cost effective to purchase a new camera as opposed to the repair price on your current camera.
Oct 12, 2010 | Fuji FinePix J10 Digital Camera
Zoom lens won't retract on fujifilm f410
This indicate that there will be some problem with your camera Lens. Try to follow these steps to resolve the issue:-
1) Switch the camera OFF and then ON again. (May be your camera lens is struggling to extend)
2) Load new or fully charged batteries.
Else your device need service (repair)
Rating the solution is highly appreciated....Good Luck
Mar 03, 2010 | Fuji FinePix F410 Digital Camera
Fuji A607 lens will not retract or open
Hi.
That is often caused by a lens problem. The lens mechanism gets stuck because of dirt, or because of a fault.
Follow the instructions here: Lens not retracting on digital camera.
See also: Lens Error.
Regards.
May 20, 2008 | Cameras
Lens not retracting
if the "!ZOOM ERROR" message is displayed on the digital camera, switch the camera off and on again 2 or 3 times.
If this does not clear the error, take the camera to your nearest FUJIFILM Service Station for testing and repairs.
Apr 01, 2008 | Fuji FinePix S7000 Digital Camera
FUJI FINEPIX S7000
Try it with a different set of battery. It is possible that one of your battery is "dead" or close to it, and the camera shuts down.
You have to find the bad battery.
It worked for me.
Jan 22, 2008 | Fuji FinePix S7000 Digital Camera
Usually down to the lens block assy being faulty.Is the lens retracting and opening properly?.It usually turns out to be worn gears in the lens drive assy or the result of a fall.Either way will be expensive repair!My advise is check and see whether camera is covered by insurance for accidental knocks.,
May 09, 2007 | Fuji FinePix A400 Digital Camera
F650
'fraid not, I believe it does that to save battery.
Mar 01, 2007 | Fuji FinePix F650 Digital Camera
Fuji Finepix Ax280 Pink Logo
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
