Question about Brother MFC8910DW High-speed Laser MFP
Not enough memory for scanning device--Paperport 12.1--how to fix?
Just upgraded to Brother MFC8910 which came with Paperport 12.1. I cannot scan in paperport without receiving the message "Out of memory. Not enough memory for scanning device". I can scan outside of Paperport and can do a PreScan in Paperport. So the issue is not the scanner itself. In addition, the other 2 people I work with in my office have zero issues scanning directly in Paperport. We are all running Windows 7. I have uninstalled the scanner and paperport a few times. Each time I completely deleted everything after the uninstall and the usage of the "Nuance Removal Tool"--this includes deleting registry keys and going into AppData folders. I have tried a minimal install by going into the Brother disk (which has Paperport) and ONLY installing the minimum amount of components rather than the entire "Brother Suite". I have tried everything I have managed to locate on the Web and simply cannot come up with a viable solution. At this point I am debating on reinstalling Windows 7 as I cannot think of anything else. If you need me to post any sort of internal data, please feel free to ask. I would greatly appreciate any feedback as the scanner is an integral part of my work. Thank you so much.
Unable to scan with Brother DCP-7065 DN with Paperport 14
You should first run the Scanner configuration for PaperPort.
Nov 19, 2013 | Brother Office Equipment & Supplies
How do i change the file name that is attached when i use "scan to email" ,change the file in then machine constantly , now i get image.pdf
I could never get my Control Center software to behave, so I just sucked it up and used Paperport.
I got my first copy several years ago with a scanner and have upgraded through each edition.
With the Brother software, I can put the documents into the feeder, run Control Center on my computer, and it let me edit the application that opens when I click Scan to Email, but the attachment always messed up and gave an error.
With Paperport, I click on Scan Settings and I am presented with options to pick a document type (color, b&w and resolution) and device options including auto straighten, pdf, OCR, etc. As it's scanned, I can then merge or unmerge the pdf pages and name them by hand.
It is a $100 program, but they usually offer it for half price most anywhere from time-to-time.
http://www.google.com/search?q=paperport+12&rls=com.microsoft:en-us:IE-SearchBox&ie=UTF-8&oe=UTF-8&sourceid=ie7&rlz=1I7GGLL_en
There are other Scan to email software programs, that may be free, that will do the same thing.
Carl
Jun 19, 2011 | Brother MFC-8860DN Printer
WE now have Windows7 and the printer will print, but you can not scan. It did scan once, but we never found the document we scanned which usually went to My Pictures when the other computer had XP. ...
Hi there!
If you just upgraded your operating system. What you can do is to reinstall the full driver & software package using the CD. You can also install Scansoft Paperport which is a software bundled with brother that you can also use for scanning. Reinstalling everything from the CD should do the trick.
Hope this helps. Please rate if it worked Thanks!
Mar 30, 2011 | Brother MFC 490cw Color Inkjet...
How to scan from brother to microsoft word 2005
First of the Brother has a Software program itself that you will need to load to be able to do any scanning.
When you use this software to scan a document you can then change the scan to be the type of file you need it to be like the microsoft word (.doc) file. Please understand the even though you scan a document does not mean when you get into the '.doc' word 2005 format you can go word or letter by letter. It still acts like a picture not a document you can manipulate.
Blessings,
A/V Media Guy
Nov 23, 2009 | Brother MultiFunction Center MFC-440CN...
OCR problems for Brother MFC-8660DN with Vista 64bit
You are correct in that paperport 9 will not work on Vista and paperport 11 is the alternative. I called about a similar model and the guy at Brother told me that paperport 11 is included on an updated cd from brothermall.com for some models. It was only about $3 so you might want to check for your model. Hope this helps.
Apr 11, 2009 | Brother MFC-8660DN Network Mono Laser AIO...
Issue installing xerox documate 510 scanner using windows vista
Have a Documate 510 Scanner and keep getting the following error message: "out of memory, not enough memory for scanning device". How can i fix this?
Apr 07, 2009 | ScanSoft PaperPort Deluxe 9...
I can't scan
When scanning documents on my MFC 7420, this is what I do. Place document on th scanner bed and don't press any buttons, leave it whatever mode it is in. Go to the computer and click on start> program files> scansoft paperport> open paperport se. When paperport is open click on the scan icon in the upper left corner. A dialog box on the left hand side will ask what you want to scan a picture or document. Select accordingly and press the scan icon.
A new window will pop up and ask what you want to scan and the size. You can either select pre scan or scan. The computer then will send a scan request to the scanner. When it is done scanning close the second window that popped up and the document that you just scanned will be there with a red box around it. Click on the document and it will open, then you can edit and save as needed.
Happy scanning
Hatter1
Jan 29, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother mfc 240c
you have to install the paperport software. This should be done when you have run the whole mfl-pro suite.
go to progr. /scansoft/paperport/ click scanner and simply scan into the paperport desktop.
Feb 28, 2008 | Brother MFC 240C All-In-One InkJet Printer
Brother MFC8910DW High-speed Laser MFP Logo
908 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
