Question about Canon Pixma MX410 All-In-One Printer
Canon Mx410 Sucking the paper in sideways.
Every time I try to print or copy or run any type of maintenance, the paper gets sucked in through only one side, causing the paper to crinkle and create a paper jam. I'm thinking that on of the rollers is broken or something fell in blocking access to the roller. However I cant get to it in any way to check. When I put my hand down through the paper feeder I feel a roller on the side that inst sucking and nothing on the other side. Any form of assistance will be helpful.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Canon Expert
  • 95 Answers
If you look in the back of the printer, there is a door to open and see if anything is in the way. Usually there is going to be an object like a paper clip or something. Use flashlight to help you see better.
Posted on Jun 03, 2017
  • 18 Answers
SOURCE: false paper jam
possible solution - I had a similar printer that had small stones that fell into the paper slot at the back and jammed the mechanism. a shelf behind the printer had these little rocks and a child dropped them into the printer. I had to take it all apart, but it worked after that
Posted on May 30, 2009
arjoy
  • 87 Answers
SOURCE: I have a canon IP2600 printer only 4 months old
In many cases, forcing (pulling out) the jammed paper in the printer might caused severe damages on the gears or some parts on the mechanical stability.
Noise problem might occurred if some of the joints (parts) were dis-aligned. Dis-assemble carefully the printer, and look for that damage. Put some grease and assemble.
Posted on Jan 20, 2010
SOURCE: Paper jammed at exit rollers of Canon D860. Paper
You can download the repair manual for a similiar Canon printer, the iR1200-1500, on Ebay for $ 3.00 to $ 5.00 and this will tell you how to take apart the printer. I had the same problem and the manual allowed me to remove the fuser assembly and clear the jam. If you prefer, Canon sells the Image Class D860/880 repair manual for you printer for $54 plus shipping. The Ebay dealer also included the parts maunal, which is a sepatate charge from Canon.
Posted on Jul 18, 2010
wheatlandsvc
  • 1110 Answers
SOURCE: When using the feeder on our Canon D1120 at the
This is caused by dirt/debris stuck to your ADF scanner glass. When you use the feeder on these type of machines what happens is that your documents are fed over a strip of glass when they are scanned. So anything stuck to the glass is scanned as a solid "line". You just need to locate and clean the strip glass. It will be located 1 of 2 places on your machine. The first location would be just to the left of the larger main glass. Just look for a strip of glass about an inch wide running from the front towards the back. The other location is harder to find as it would be located inside of the feeder assembly. Sometimes you have to open the feeder unit and look for the glass strip inside. But most machines it is located just to the left or right of the large main glass. Since your copies are fine when you use the main glass then be assured that the strip glass is what is causing this problem.
Good Luck and Thank You for using Fixya.
WheatlandServices
Posted on Dec 27, 2010
  • 1570 Answers
SOURCE: My canon pixma MP470 printer
Hi
Please inspect again for paper jam located inro the paper tray, in the ink cartridge compartment and rear door of the printer (back door of the printer). If you find the paper jammed, it solves you problem and try to print again.
If not, just open the cartridge door, turn off the printer and move the cartridge using your hand the ink cartridge to the left going to the right and then right to left for 2 times. Then try to print again, also jammed message errror is related to stuck up cartridge.
Posted on Feb 26, 2011
Paper is getting stuck
Clean the paper feed roller and look attention is the mechanical problem.
Feb 21, 2013 | Canon Pixma MX410 All-In-One Printer
Canon mx410 is not loading the paper
I have the same model and had the same problem. I pulled a hair pin out of it that didn't allow the paper to fall in completely. Try running a stiff piece of paper around teh paper feed area to see if you have anything dropped in there.
Oct 16, 2012 | Canon Pixma MX410 All-In-One Printer
Error message with canon mx410 "cannot scan from adf"
I fixed this by changing the Copy Intensity from Auto to Manual
I had the same paper jam (caused by pressing Stop during a page going into the ADF), but I had pressed OK as instructed and the page was auto fed back out again. Then I couldnt copy from ADF after that.
I tried everything, and then started to retrace my steps of all the things I might have tinkered with to try and get the copying working in the first place, before the paper jam.
Then I remembered I had set the Copy Intensity from Manual to Auto (thinking Auto is always best). With hindsight, it now makes sense for it to be manual with the ADF as otherwise how would it load a page, use it to set auto density, and then reload it again for the actual copy to occur. This happens okay on the flatbed scanner as it can scan a little, work out the settings, and then scan for real.
Copy Intensity is reached on my Canon MX from the Menu button at the bottom left of the front panel. - Then press the right arrow twice to get to Color Intensity. - Hit OK. - Then right arrow from "Auto" to "Manual Adjust"- Then pick a setting or leave it as half-way between light and dark- Press OK
Now every time my ADF copying works a treat. Thats what I get for tinkering in things I didn't need to change in the first place. I was just trying to get a quick copy going from ADF to paper without saving a file up on the computer and then printing.
Aug 09, 2012 | Canon Pixma MX410 All-In-One Printer
Canon mx410 paper jam error
For me on my Cannon MX410 with a "paper Jam" light displayed this WORKED!! The absolute BIZZARE thing was after I went and through the described procedure above and rebooted and tried to print the 1st page that came out had a "crushed" ****-roach on the 1st page! So I didn't have a paper jam,...but a
ROACH Jam. :) I told my wife, Humm pest service not workin I guess! It errored out again, but simply unpluggingUSB and power cord (not the steps described for the Print Spooler) it prints fine. SO saved me buying a new printer which was just 6 mos. OLD and FINE by me! So THX, Vikram Kumar Thumu!
Jan 28, 2012 | Canon Pixma MX410 All-In-One Printer
How do I mirror/reverse print on a cannon mx410?
On the print window, click on preferences. Click the Main tab at the top, then click the arrow for the drop down menu next to Media Type. At the bottom is Other Papers. Click there, and you'll find T-Shirt Transfers where you can print in reverse. Don't forget to switch back!
Aug 20, 2011 | Canon Pixma MX410 All-In-One Printer
We tried printing and copying with the setting set at LTR and LTR-R and we checked the paper tray and every time we make a copy or print it prints out the entire document perfectly centered across the...
It seems to me to be a problem of the Blue paper cassette size dial is set wrong. First see what the settings are from the display by pressing the paper select button. Most people have it set for the upper cassette to be LTR ( 8 1/2 X 11 inch paper - length running from front to rear in the cassette ) and the lower cassette to be LTR-R ( 8 1/2 X 11 inch ) or Legal ( paper length running left to right). Check to make sure the blue dial agrees with what's in the cassette. Try doing the testing by putting the paper on the glass first and closing the top. If this is correct and the problem is in the Documnet feeder then one of the raised flags may be broken or the sensor bad. The left one is for letter, the second one for LTR-R or legal and the third is for 11 X 17. The opening and closing fo the side guides also helps to determine paper size. Hope this helps you.
Nov 30, 2010 | Canon imageRUNNER 2270 Copier
Copier jamming/copy printing sideways
If it jams every copy then it sounds like the paper tray size is not programmed properly. This is also why the print is the wrong direction on the page. So the copier thinks it has 8.5X11 loaded like this > -- and instead it is loaded like this > |
I hope that makes sense. So this not only causes the print to be the wrong direction but since the paper dimension are different that what the machine expects then it throws the sensor timing off and results in a paper jam. So just open your paper trays and check the paper size dials in the trays to make sure they match the paper size AND direction of the paper loaded into that tray.
May 13, 2010 | Canon imageRUNNER 2200
Paper is jamming
probaly to much paper try removing some of the paper and then try printing something to see if the problem goes away
Jan 11, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Canon Pixma MX410 All-In-One Printer Logo
75 people viewed this question
old marine
old marine
