Question about Lands Phones
We have a Uniden home phone DSS7855/DSS7855+1. We usually pick up the handset, dial the number and press talk.The number dials straight away. A few days ago the phone was put through to our mobile so we could receive calls while away. On return I accidently tried to make a call on our phone before cancelling call forward to the mobile.Since then when we lift up the handset and dial a number there is a period of a "continuous engaged" signal before the number dials. This did not happen before????
  • 50 Answers
Hi
please to the following steps to fix it
1) Remove the battery cover.
2) Remove the battery pack by disconnecting.
3) Leave the battery cover off and the battery pack disconnected for at least 5 min.
4) reconnect the battery pack and he battery
5) Recharge the handset's battery pack before using again.
to get the phone manual please visit the following link
http://72.14.235.132/search?q=cache:TfXv7VxtS4wJ:www.uniden.com.au/resources_main/pdfs/DSS7855_7855%2B1_OM%2520.pdf+how+to+reset+DSS7855/DSS7855&hl=en&ct=clnk&cd=1
Good Lock
Posted on Jan 18, 2009
  • 716 Answers
Activate Call Forwarding And Then Deactivate It. Then Unplug Your Receivers From The Power Source For About Two Minutes And Remove The Batteries From Your Handsets.Then Replace Batteries And Plug The Phone Back In (Note) You May Have To Put Your Phone's On The Cradles For One Second To Get Power.
Please Be Advised That This Method May Delete Your Recorded Greeting And All Numbers Saved In Caller I.d Or Programmed For Quick Dial.
Thanks For Using Fixya.Com
Sincerely,
Michael Scott
    Brigadier General:
  • 8,619 Answers
Hi!
You can reset your phone and then can reprogram it again.
You can reset it by---
Unplug the battery. Hold down The * (star) and the #(hash) keys simultaneously. Re-connect the battery, phone will beep and screen will be blank. Press the voicemail (righthand silver key under the lcd screen). As above EEPROM/RAM message will appear. Place handset on base and your problem is solved.
  • 10,594 Answers
Please take out battery of hand set for couple of minutes and put back battery and check hand set by dialing a number.
Handset might need to re-register with base unit.
    Guru:
  • 859 Answers
You should probably reset you cordless base unit, place each handset in the base unit and reinitialize each hand set. The procedure to reset you base unit is probably in your manual and I won't take the time to Google the answer you can find for youself.
My suggestion lies in the fact that your base unit is confused by what you did and how you did it.
Regards,
Worldvet
How to get a dial tone on your uniden 6.0 cordless phone
If you have a phone line that is active, lift the handset from the cradle, enter the number and press TALK. Or just press TALK if you want to verify that you have a tone signal.
Aug 27, 2011 | Uniden DECT 6.0 Cordless Telephone...
GE cordless- back of phone says model number 5-2811. How do I get the "do not disturb" off so my phone will ring?
1. Pick up the phone handset and dial *98.
2. Press 1 to enable Do Not Disturb.
3. Once you hear the confirmation that Do Not Disturb has been enabled, you may hang up the phone handset.
1. When you are ready to accept calls, pick up the phone handset and dial *98.
2. Press 2 to turn off Do Not Disturb. When you hear the confirmation you may hang up the phone handset.
Aug 10, 2009 | Uniden Cordless Phone
How to set up Speed Dial on a Uniden phone?
My Mom had this same problem.   I found these instructions on Uniden's website (uniden.com) under the "Owner Manuel" section.
Here you go - good luck!
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers (up to 20 digits each) in the speed dial
memory. To store number in memory:
1) When the phone is in standby, press [memory]. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number.
 (To enter a 2-second pause between numbers, press [redial/
pause]. Each pause counts as a digit. )
3) Press [memory] again.
4) Select the speed dial location where you would like to store the
number ( [0] to [9] ). You will hear a confirmation tone indicating
that the number has been stored.
NOTE:
• Storing a number to a speed dial location will
overwrite the any previously stored number without
warning.
• When storing numbers into memory and the handset is idle (i.e., no key is
pressed) for more than 0 seconds, it will beep rapidly, and then the phone
will return to standby.
Dialing a Stored Number
1) When the phone is in standby, press [talk], and listen for a dial tone.
2) Press [memory] and enter the speed dial entry ([0] – [9]) that has the stored number
you want to dial. (If you enter a digit that does not contain a stored number, the
handset will beep rapidly, and the phone will not dial.)
Chain Dialing
The speed dial memory is not limited to phone numbers. You can store any number (up
to 20 digits) that you need to enter once your call connects. This is referred to as Chain
Dialing. An example is a frequently refilled prescription number. Store your pharmacy
phone number in one speed dial and your most frequently refilled prescription number
as another speed dial. To use, once you ring your pharmacy's automated prescription
line, simply press [memory] and the speed dial number where you stored your account
number.
Erasing a Stored Number from Memory
1) With the phone in standby, press [memory] twice.
2) Press the number of the speed dial entry. A tone indicates that the stored number is
erased from memory.
Jan 11, 2009 | Uniden Cordless Phone
Uniden power max 5.8 speed dial
Press and hold a number key (0-9) associated with the speed dial until the phone number appears, and then press talk/flash or speaker on the handset or speaker on the base. The number stored in the speed dial is dialed.
Sep 22, 2008 | Uniden 5.8GHz Dual Cordless Phone
I need to reactivate my uniden cordless phone with remote extra handset. It was on a second phone line in my home, and that phoneline has been cancelled. Now, both units are charged, but and plugged into...
This should get the job done for you!
To re-register DXA14588-2 handsets:
  1. Pick up the handset from the base. Press and hold [find handset] on the base.
  2. While holding [find handset], place the handset in the base. The charge/in use LED on the base begins to flash, indicating the base is registering the handset. Wait for at least five seconds.
  3. Pick up the handset from the base and press [talk/flash]. If the display shows TALK, the handset is registered. If not, place the handset in the base to try again.
  4. Press [end].
  5. Place the next handset in the base and wait for at least five seconds. No need to hold [find handset] this time.
  6. Repeat steps 3 - with any other handsets you have.
Please let me know if you have any further questions.
Good Luck!
Aug 11, 2008 | Lands Phones
CHECKING MESSAGES
First call your home number, when the answering machine picks up, dial 0 then the two digit security code. (You have to check the security code on the handset.) It will then give you voice prompts how to listen, skip and delete messages.
Jan 22, 2008 | Uniden TRU9280-2 Twin Cordless Phone
How to proram speed dial
Here is the solution:
1) Pick up the handset
2) Press the "Store" button
3) Dial the number that you want to store
4) Press the "Store" button
5) Press one of the Memory button such as M1, M2, etc.
6) hang up the phone (put the handset back to the base)
When you're ready to dial the number, just pick up the handset and press one of the Memory button that you just use to store your desired number.
Best of luck,
KP
Dec 18, 2007 | Sakar Talking Caller-ID Speaker Phone
Uniden 900MHz phone model EX17960A
Your cordless phone can store up to ten numbers in the speed dial memory.
1) When the phone is in standby mode, press the memory key. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number; each number can be up to 20 digits.
7
3) If you need the phone to pause during the dialing sequence, press
the redial/p key to insert a two-second delay between the
numbers. You can enter multiple pauses to increase the delay.
4) Press the memory key again.
5) To store this number as one of the ten speed dial numbers, enter a
digit from 0 to 9. If there is already a number in that speed dial
setting, it will overwrite the previously stored number without
warning. You will hear a confirmation tone indicating that the
NOTE: When storing numbers into memory, if the handset is idle
(i.e., no key is pressed) for more than 30 seconds, it will beep rapidly, and the phone
will return to standby mode.
1) When the phone is in standby mode, press the talk key, and listen for a dial tone.
2) Press the memory key and enter the speed dial entry (0-9) that has the stored number you
want to dial. (If you enter a digit that does not contain a stored number, the handset will
Nov 13, 2007 | Lands Phones
Problem when dialing phone
Yes, I have had nothing but trouble with my V-Tech ia5823.
Slow to dial, dropping out going calls and now the base light is flashing at a rapid pace and will not charge the handset.
I want to return it to Wal-Mart but have misplaced the recepit.
I will never buy another V-Tech..Uniden is the way to go!
Jun 02, 2007 | Vtech ia5823 Cordless Phone
Lands Phones Logo
65 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
