Question about GE Refrigerators
Where is the drip pan located in a GE Model GTS18EBMDRWW?
Location of drip pan in a model GTS18EBMDRWW
  • Thomas Totten
    Thomas Totten Dec 31, 2012
    There is no removable kick panel on this Model!
    Top Expert:
  • GE Master
  • 45,141 Answers
Inside the kick panel at the bottom. The panel is pulled out to release it and gain access to the pan
Posted on Dec 30, 2012
applianceboy
  • 77 Answers
SOURCE: Water dripping on GE Fridge model TFX24ZR
check your water filter. water preasure is important in the operation of the water valves. if the filter is ok replace the valve. water filter should be changed at least once every year.
Posted on Sep 26, 2007
  • 1462 Answers
SOURCE: Overflowing drip pan under the fridge
for reallybsq
problem could be door seals not sealing completely and hence excessive ice formed on evaporator and excess water when it melts. however, i have found this problem many times with large larder fridges and really found no cure.
for guest.
towards the bottom of the back wall, there is a gulley with a drain hole in the middle. this drain is blocked. clear it with something flexible and make sure water flows away freely
Posted on Sep 07, 2008
docjohn174
  • 943 Answers
SOURCE: refrigerator water drip pan
thanks for the question no other way to do itthere is no drain hose attached to that tray sorry thanks for the question The appliance doc
Posted on Sep 11, 2008
SolutionGuy
  • 331 Answers
SOURCE: Location of GE refrigerator circuit board
The main board is located behind the unit at the lower right hand corner behind a panel that's about 8" X 12".
Posted on Oct 29, 2008
barkencoa
  • 3463 Answers
SOURCE: how to empty drip pan
At the back of the food compartment where the water collects ,there is a drainage hole, this is blocked up,poke a long thin piece of wire or similar and poke it down the hole, this should clear the blockage,
If the water does not drain away then you need to go the rear of the frig and clear the rubber or plastic hose that you will see on the top of the motor compressor. this should solve the problem.
Plz rate this solution.
Thanks. and merry xmas.
Posted on Dec 20, 2008
Drip Pan Placement
Go to page 75 in the service manual where it explains the drip pan for different models. Click HERE I will be here should you have questions, Thanks Sea Breeze
May 02, 2013 | Sub-Zero Refrigerators
Drip pan
The drip pan is located behind the toe panel (grille) at the bottom. The pan should be located in the left side. If you have auto defrost, the pan may or may not have water in it. It is likely to have accumulated grunge which can be removed by a good wash and rinse, being careful to avoid breaking the pan during cleaning. Reinstallation is the reverse of removal.
Sep 12, 2012 | Maytag MZD2766GES Side by Side...
Need to find parts for GE JBP24DOM1WW
We have no parts reference books nor are we a source for any parts. All we can do here is google the part. Just google this phase "Quick Clean Oven parts" and hope the search returns a few results that will lead you to a parts source online.
Jan 16, 2012 | GE JBP24 QuickClean Electric Kitchen Range
How do I remove the drip pan from a side by side 6.5 Ingliss model I525AGXR002
If you have a removable drip pan get the kick plate off there and that pan should slide out the front. This machine is made by Whirlpool and I am thinking you maybe have a drip pan above the compressor. In that case yall would remove the rear dust cover and use a rag to clean out the pan as it is bolted down to the compressor. Model number don't show up on repair clinic or appliance parts pros.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 27, 2011 | Refrigerators
Why do i keep getting a puddle of water in the bottom of my frige? The water must be coming from the top because each day, there is water on top of the food containers all the way down to the bottom.
Sounds like you have a defrost drain issue. Often times these get clogged, and the back flow water drips into the fridge, usually the culprit on a GE is a clogged drain diverter, located on the outside back of the unit. Remove the tube by bending and pulling away from the diverter while holding the diverter firmly in place. Then turn the diverter one quater turn clockwise and it should pull down and away from the appliance. Clean this diverter out thoroughly, as it is likely full of gunk. However, on some older model GE top mounts, ive seen the drain pan underneath the evaporator coil inside the freezer with a small rust hole, and the water drips through this hole instead of the intended drain hole, the water then misses the tubing, and drips into the fridge. this drain pan will then have to be replaced.
Dec 10, 2010 | GE Refrigerators
Ref practically new, intermittent leak onto floor at left rear ref is model HSM25GFTCSA side by side
check drip pan, if it full of water and there is no heater on this model you need to upgrade it with heater under drip pan.
but check if it's not cracked and drain line goes to it and not on the side...
www.appliancesrepairla.com
Jun 26, 2010 | GE Hotpoint® HTS18GBS Top Freezer...
Water leaking from under refrigerator
The drip pan is located from behind the refrigerator. You have to take the cardboard off and unplug the unit. You will see the drip pan with the fan unit on top of it.
Apr 29, 2009 | Refrigerators
Need replacement drip pan for model #GRP4P Part # 22619
my proublem is solved. I was looking for a replacement "Drip Pan" for my George Foremen "The next grilleration" grill. The solution is, I googled it. (George Foremenr replacement parts) It sent me to their sight and as you sroll down the page to the bottom you will see comments from other people who were also searching. And some from other who have found answers. You will see a toll free number where you can order your replacement parts for several appliances. My replacement "Drip Pan is on the way.
Apr 12, 2009 | George Foreman GRP4P Indoor Grill
Refrigerators Logo
144 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
