I CANNOT SEND A TEXT OR DO VERY MUCH WHILE IM TALKING ON THE PHONE. I USE A BLUETOOTH HEADSET SO I CAN KEEP MY HANDS FREE , I HAVE NOTICED I CANNOT DO MUCH IF IM TALKING ON THE PHONE, NO GOOGLOE MAPS, NO TEXTING, NO APP STORE, NO SCANNING, BUT IT WILL LET ME PLAY MUSIC. I WENT FROM AN MDA WHICH ALLOWED ME TO DO ALL WHILE TALKING. THE MORE I HAVE THIS PHONE THE MORE DISSAPOINTED I BECOME..............
Yes. Starting with the iPhone 4 and newer, all support the following Bluetooth Profiles: A2DP(high fidelity stereo sound for music) , AVRCP(remote control, letting a headset's buttons change tracks, volume, etc), Handsfree and Headset(answer and make calls using the headset) , PAN (tethering a laptop to your cellular data conndction), PBAP (allows access to your contacts/phone book), HID (let's you use input devices like Bluetooth keyboards to type on your phone), and MAP (lets a bluetooth device send texts and get alerts if you receive one). Any bluetooth device with any of those profiles will work.
The BSH-100 uses the A2DP, AVRCP, Handsfree and Headset profiles, all of which your iphone supports. So all features will be enabled and work flawlessly on your phone.
To turn on the Samsung HM3700 headset, slide the power switch up. (You can see it's location on the image below). The indicator light below the power switch will blink blue 4 times (purple or red means your battery is low). If it stays blue it is ready to sync with your phone.There are 3 ways to sync this device to your phone:
Once the headset is on, hold down the talk button for 3 seconds. (the blue light will stay lit for 3 minutes once you enter pairing/syncing mode).
Activate Bluetooth on your phone and search for the hm3700 (keep them close to each other).
Select the headset and enter a PIN number if asked.
2.) Active Pairing: Once you have held down the talk button for 3 seconds and the blue light is on, press and hold the talk button again to make the blue light purple.
The device will try to automatically connect to your phone for 20 seconds. Your phone should not be connected to other Bluetooth devices during this process.
copy ur text messages via mark text option and den copy text... den go in notes make new note>paste text>save. den u can send dat note via bluetooth free of cost. another option is u can keep messages in sim card memory and den copy it to ur other phone.
Set your volume to mid range. If it continues you'll need to return it or exchange it. The voice pickup sencer in the bluetooth is defective. Or the phone needs an upgrade.
If you've set the audio input and output to the bluetooth and it still doesn;t work then you probably should try a different headset -- non-Motorola. Their radios sometimes are too weak. You can also try sitting closer to the PS3.
