Question about Nintendo 64 Console
Nintendo NES how do i clean the games for nintendo nes?
Well theoretically you could use the same old way we did it for years with isopropyl and a q tip. Or you could try ebay to get a first generation or second generation nes cleaner pack
Posted on Apr 27, 2009
2 Suggested Answers
  • 47 Answers
SOURCE: Nintendo NES Repair
Hi sounds like your console has a weak connector pin and is lsing contact with your game. I fixed mine buy purchasing a new connector pin from and it included step by step instructions with photos and a few tips on how to clean NES cartridge games as their is no use in installing a new 72 pin connector if you dont properly clean the NES games because installing dirty games into a new connector pin will result in console blinking flashing again.
Posted on Mar 29, 2010
Well to clean out the super NeS console you need to open it up with a 4.5mm bit tool and use compressed Air cans then to clean them out. Lukie games sells a 4.5 mm game bit tool.
Dec 30, 2011 | Nintendo Super NES Console
Console blinks when game is loaded
Hi there, here's a fix that may help, I've done it on quite a few NES and all have started working. Basically the pins that connect to the cartridge have been pushed flat over time so your not getting a clean connection.
Mar 31, 2010 | Nintendo NES Console
I have changed the pin connector on my nes, it does not flash anymore but now i get a blank screen can someone help me?
First try connecting through the av ports on the side of the console rather than the RF port on the rear of the unit.
If that doesn't work then your problem is likely a loose connection inside, go back in and reassemble.
I have had this issue with several consoles; these two solutions usually take care of it, though in rare cases a defective 72 pin connector was at fault even though it was brand new.
Good luck.
Instructions for NES nintendo console
Jan 07, 2009 | Nintendo NES Console
How to fix my nintendo (NES) without replacing anything
Yes, this is a 72 pin connector problem. The connector has become dirty or oxidized and needs replacing or cleaning. Problem can usually be solved by buying a NES console Pin cleaner which inserts like a game. The "Eliminator" is one which works great wet or dry to eliminate this problem.
Oct 09, 2007 | Nintendo NES Console
Nes Nintendo Channel Trouble
are you using a/v (audio/video cables with rca ends), or direct to cable input on t v.? if direct to t v, did you check ch switch on back of system deck? otherwise is t v programmed for the correct INPUT. T V, AV1. AV2. OR AV3? ANOTHER PROBLEM WITH OLD NES IS YOU MUST CLEAN THE GAME EVERYTIME YOU INSERT IT. TO CLEAN MIX ALCOHOL/WATER 1-1 AND USE QTIP. RUN IT UP AND DOWN BOTH SIDES OF CONTACTS. IT WILL DRY RIGHTAWAY.
Sep 19, 2007 | Nintendo NES Console
Nintendo 64 Console Logo
71 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
