Question about Refrigerators
Drip pan location in a GE Model GTS18
Drip pan location
Boba
  • 64 Answers
SOURCE: I cannot get to the drip pan under refridgerator to empty it. It is filled with sludge and smells bad
Thank willie for helping with one: "Well, it looks like the pan is a seperate plastic pan and not the compressor mounting pan like some of the newer ones are. It appears that you have to remove the condensor fan motor and mounting bracket then maybe the pan will left up and over the compressor, or maybe there is enough room to lift the pan up and out the front over the condensor coils"
Posted on Jun 11, 2006
applianceboy
  • 77 Answers
SOURCE: Water dripping on GE Fridge model TFX24ZR
check your water filter. water preasure is important in the operation of the water valves. if the filter is ok replace the valve. water filter should be changed at least once every year.
Posted on Sep 26, 2007
  • 33 Answers
SOURCE: Cannot remove drip pan
im sorry but that drip pan cannot be removed you might have to do the best you can with it in there.
Posted on Jan 03, 2008
  • 1462 Answers
SOURCE: Overflowing drip pan under the fridge
for reallybsq
problem could be door seals not sealing completely and hence excessive ice formed on evaporator and excess water when it melts. however, i have found this problem many times with large larder fridges and really found no cure.
for guest.
towards the bottom of the back wall, there is a gulley with a drain hole in the middle. this drain is blocked. clear it with something flexible and make sure water flows away freely
Posted on Sep 07, 2008
  • 148 Answers
SOURCE: GE refrigerator tfx27zp or 25zp or 22zp not sure.
The drip pan is located under the front of the frig.
FIX
open both doors, remove the panel that is across the bottom of the fridge( there are release tabs over the left and right front corner areas close to the hing sides
after removing the panel you should see a tray that slides on rails under the fridge
remove the panel and inspect to see (use a flash light)if you can see the drain tube
I believe your drain tube is freezing up somewhere inside the frig
If you can determine where this drain tube fishes up through the back inside wall of the frig
remove all of the trays and observe the back panels there should be some type of collector tray
near the frig light Some models have a hot bulb to do the defrost
I suggest that you tun frig off with both doors open take a hair dryer and blow hot air where you think the drain is located to melt any ice and look down in the drain pan to see if it starts draining
Hope this helps
Good luck ( ps cal ge customer service and give model number I bet they have a design poblem
If they do they may have a work around
God Luck
Posted on Jan 05, 2009
Where is the drip pan located in a GE Model GTS18EBMDRWW?
Inside the kick panel at the bottom. The panel is pulled out to release it and gain access to the pan
Dec 30, 2012 | GE Refrigerators
Drip pan
The drip pan is located behind the toe panel (grille) at the bottom. The pan should be located in the left side. If you have auto defrost, the pan may or may not have water in it. It is likely to have accumulated grunge which can be removed by a good wash and rinse, being careful to avoid breaking the pan during cleaning. Reinstallation is the reverse of removal.
Sep 12, 2012 | Maytag MZD2766GES Side by Side...
Need to find parts for GE JBP24DOM1WW
We have no parts reference books nor are we a source for any parts. All we can do here is google the part. Just google this phase "Quick Clean Oven parts" and hope the search returns a few results that will lead you to a parts source online.
Jan 16, 2012 | GE JBP24 QuickClean Electric Kitchen Range
Where is the drip pan located on this refrigerator
drip pan is usually located on the bottom of the fridgfe somwhere near the compressor
Jul 24, 2010 | Estate TT18SKXRD Top Freezer Refrigerator
Ref practically new, intermittent leak onto floor at left rear ref is model HSM25GFTCSA side by side
check drip pan, if it full of water and there is no heater on this model you need to upgrade it with heater under drip pan.
but check if it's not cracked and drain line goes to it and not on the side...
www.appliancesrepairla.com
Jun 26, 2010 | GE Hotpoint® HTS18GBS Top Freezer...
Need replacement drip pans for ge xl44 gas stove
u can find the parts only in the service center of GE appliance center.but if ur unit is more than 10 years,im sure no parts available.
Jun 30, 2009 | GE Profile JGP636 Gas Cooktop
Water leaking from under refrigerator
The drip pan is located from behind the refrigerator. You have to take the cardboard off and unplug the unit. You will see the drip pan with the fan unit on top of it.
Apr 29, 2009 | Refrigerators
Drip pan
You can buy this pan at your local appliance parts store. All you need is your model and serial number.I hope this helps you.
Nov 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
I can not find my model number jgbp29mem1bs on the inter net any where. what I want to know if I can get removable pans to go under burners
Sears carries the drip pans you need. They have models for GE / Hotpoint that were made for models before 1990 and the newer ones also that are made after 1990. (Electric) Here is a link to one of the made after 1990 models.
http://www.sears.com/shc/s/p_10153_12605_00848773000P?vName=For+the+Home&cName=Cookware+%26+Gadgets&sName=Food+Prep+Tools&keyword=GE+drip+pans
Hope this helps someone. :-)
Aug 22, 2008 | GE Kitchen Ranges
Jun 04, 2006 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
