Question about Mitsubishi WS-48311 48" Rear Projection Television
Mitsubishi WS-48311 won't enter option menu
Picture has become a bit skewed - can't read bottom scroll text on some channels. And the time out indicators on fox football at top of screen. Wanted to adjust vertical size and perhaps keystone distortion. I found a service manual online and was able to enter the tech menus (menu, 2-2-7-0 for example) yesterday. I just browsed the menus yesterday, didnt change anything. Today tv does nothing when I punch in the codes. Not sure what's up. Put new batteries in remote but no dice. Menu button works, number buttons work to enter a channel number. But when I try to enter a tech menu code it doesn't respond.
  • J wilson Dec 31, 2012
    Okay now I feel terrible. It's a 48313 - I looked up the wrong service manual today. Codes are totally different.
ctf1800
  • 4402 Answers
SOURCE: Mitsubishi WD52525 DLP Projection TV
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Posted on Jan 29, 2008
MrBob84
  • 90 Answers
SOURCE: Screen cut off on the bottom - WT-42313 Mits 42"
Make sure your remote is the official Mit remote, and that it is set for TV, usually the far left setting at the top of the remote.
These remotes control many different devices. Some will allow video to work without allowing audio to work.
TV will allow all to work.
Mr Bob
Posted on Feb 07, 2008
  • 11 Answers
SOURCE: mitsubishi WS-65611 tv channels cannot stop scrolling
Check to make sure the channel down button is not stuck. If it is not the button is probably defective. Mits has had a lot of problems with the buttons.
Posted on Jan 22, 2009
  • 12 Answers
SOURCE: T. V. stuck on one channel showing the device option.
I had same problem and discovered one of the little buttons on the front of the TV was stuck down. Don't know why, unless the maid bumped it hard as we never use them. Anyway, I poked/wiggled a few times at each button and the problem stopped.
Posted on Apr 15, 2009
Slinteriors
  • 8617 Answers
SOURCE: On Mitsubishi DLP TV MITS-WD-52631
Replace the front key board panel. You should be able to get one at www.tvrepairworld.com just hit the contact button on the right and enter the model number and symptom they respond quickly.
Posted on Aug 20, 2011
How do I hook ws-48311 to hdmi cable
you don't have an HDMI input on this unit & will need to use the component input.
Oct 27, 2014 | Mitsubishi WD Televison & Video
Tv remote codes free
IF YOU DONT HAVE THE MANUAL, LOCATE THE MANUFACTURERS NAME AND FIND THEIR INFO ONLINE AND CONTACT THEM FOR THE CODES FOR YOUR MITSUBISHI
Feb 03, 2014 | Mitsubishi WS-48311 48" Rear Projection...
Blurry picture
By focus is the set looking 3d etc--called a convergence issue---if so go into the menu with the Mitsubishi remote and see if it will adjust---if off and will not adjust in some area of the screen the set needs the convergence chips replaced.
If convergence is good and not the issue describe the problem a bit more----these sets have 3 picture tubes with lens---from rear of set (safest way) the lens can be cleaned with a lens cloth---dust on them will make the picture look darker and dull looking and usually is done one time a year--do not try to adjust anything until you try this first.
Nov 05, 2012 | Mitsubishi WS-48311 48" Rear Projection...
I have a 62 inch mitsubishi ws-65413 and the color comes in the goes out. blue and yellow are in more. what is the problem ?
if colors look skewed and come and go----next time enter the convergence menu on the set and call up advanced---a grid of lines should appear---if skewed when set bad (lines should be yellow) you have a common issue---convergence----the model indicated uses two stk-394-250 chips and both would have to be replaced.
Aug 26, 2012 | Mitsubishi WS-55315 55" Rear Projection...
Mitsubishi WS-55613 55in.
1. "wavy" may mean a signal problem inside the set--are you seeing colors out of position or skewed around letters etc?
2. Does it do it when a DVD is played? (this will rule out certain things).
SD TECH
Apr 21, 2012 | Mitsubishi WS-55613 55" Rear Projection...
I have a Mitsubishi, model # WS-48311. The red and blue are constantly way off. This is especially apparent when text is on the screen. I made sure the convergence was lined up, but still have the problem....
If the text bows way out of proportion you may in fact need new convergence IC's, part # for most of these is stk392-560. in some cases a resistor in this circuit will change value causing misalignment of convergence. you should not be able to get the convergence perfect if either condition exist. I have encountered cold solder connection in some of these older projo tv's.
Nov 29, 2010 | Mitsubishi WS-48311 48" Rear Projection...
Need to sell working parts from a Mitsubishi WS-48311
Hi, I seen your Post. I would like to buy parts off from you. How can I get in contact with you.
Dec 02, 2008 | Mitsubishi WS-48311 48" Rear Projection...
Are there internal picture controls for the WS-55315?
Good Day; OPTION MENU "MENU 0370" SERVICE MENU. CAUTION document settings before any adjustments are made. V = vertical, H = Horizontal. Good Luck, big IRISH.
May 11, 2008 | Mitsubishi WS-55315 55" Rear Projection...
S-Video on the blue screen
menu has input selection to turn on/off or name video inputs.....T.
Oct 24, 2007 | Mitsubishi WS-48311 48" Rear Projection...
Component color turns yellow
when you say color. Do you mean gray scale like what if you turn off the color completely?? Does the picture look B&W? need to know this?
Jul 01, 2006 | Mitsubishi WS-48311 48" Rear Projection...
Mitsubishi WS-48311 48" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
