Question about Panasonic TX-36PF10 TV
Panasonic TX-36PD30L not starting
I have a 4 year old TV  from Panasonic. Good TV but yesterday had a problem with the power supply to our house which resulted in dimmed house lights. Electricity is now back to normal but with the TV in standby mode (red light on) it attempts to start up but then goes back into standby mode. No video or sound at any stage. The TV was on during the power fault and while I managed to turn it off pretty quickly I did hear a 'scraping noise' before I managed to switch it off. Perhaps its some kind of fuse that has blown?
  • 2 more comments
  • gejkelly Jan 18, 2009
    Tried that. Same result. Seems to spend 5-6 seconds trying to turn itself on (red standby light off) and then back to standby light on. Could it be the tube?
    Model number is TX-36PD30L from the operating instructions manual. No spaces
    Have tried the suggestion of unplugging and holding the power button in for 30 secs.
    Thanks for the advice. I would not try what you are suggesting so it sounds like it needs to go for a repair. Is there anything else I could try short of getting it repaired? No easy fix or reset button? Its a monster to move anywhere.
    Ok. Thanks to others as well
    Genius:
  • 2,920 Answers
You might go ahead and call a repair man...trying all sorts of things people suggest will drive you nuts...it could be the main board or a simple circuit or a tube..its hard to say on here what the problem actually is
Posted on Jan 18, 2009
  • 10,515 Answers
Due to fluctuation in voltage, it seems that few IC's might have blown.........
Its all of circuit board.......
If u wish u may call a repairman or if u wish i wld love to provide u how to change that Ic.....
Take Care.
Do rate this solution..............
    Genius:
  • 1,913 Answers
Change power cable then if rpoblem occurs change your power suply .then if problem remains some circui fault u have to take to the service shop is btter way.
thnaks
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
For some reason, as CRTN has posted, Panasonic TX-36PD30L does not appear among the Panasonic models of TVs. Still applying some basic troubleshooting would require that:
  • opening the unit;
  • perform voltage measurements, determine faulty component and subsequent part(s) replacement;
  • fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron ;
  • access to a service manual or at the very least a schematic diagram with voltage readings.
Initial focus would be on the power supply:
  • most likely the fuse is not blown, you still have the red light on;
  • this indicates that the +5VDC standby B+ is active, power is getting inside and at least one parts of the PSU is operational;
  • "attempts to start up but then goes back into standby mode" indicates the unit is auto-protecting, the built-in diagnostics has sensed a fault and protects the unit from turning on to prevent further damage to the circuitry;
  • once the power supply is accessed, determine and remove the connector to the mains B+ (roughly 150VDC +/-);
  • if the power supply turns on, then problem is on the main board;
  • if power supply does not turn on, then problem is in the power supply itself;
  • if the problem is on the main board, then procedures would be the same. Remove B+ connection to major components to determine if they are causing the fault. Among the 1st to be tested would be the HOT (horizontal output transistor). This would be a big transistor attached to a heatsink very near the FBT (flyback transformer);
  • thereafter, all major components have to be checked.
Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Pls post back result(s). Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Jan 18, 2009
    Unfortunately, no buttons/key pressing fix; this is a hardware problem and offhand would require replacement of components. Perhaps an initial check-up by a qualified professional for an estimate/quotation would be in order. Based on that your decision for repairs could be made.
    If the cost of repairs and downtime would be factored in, then you may have to re-evaluate your options and consider a replacement.
  • 744 Answers
Hi might be some picture tube problem.
  • 716 Answers
Unplug Then Hold Power On/Off For 30 Seconds Then Release And Plug It Back In.
  • Michael Fisher
    Michael Fisher Jan 18, 2009
    Also What Is The Exact Model Number? The One You Gave Has No Information Please Include Spaces And Everything.
  • Michael Fisher
    One More Thing You Can Try When Powering On Hold The On/Off Button The Unit Should Beep Then Release.
Repair power board
How do you know that it's the problem? Do you hear the relays come on? Does your tv blink? How many blinks? That is a vital part in diagnosing a panasonic tv.
Regards,
Joseph Van Buren
Aug 05, 2014 | Panasonic Viera TX-P50ST30B 50AAAA€AA 3D...
Panasonic TX-L42E5B tv sound working but screen is black
It can also be the YMain board or the back light inverter board or a capacitor or fuse has blown on the power supply board. Which you usually lose sound before you lose both sound and picture. Try to hard reset is for about 4-6 hours by completely unplugging it.
Mar 25, 2014 | Panasonic VIERA TX-L42E5B 42" LED TV...
Plasma Panasonic
Replace the Power supply board very common issue with that chassis.
Oct 22, 2012 | Televison & Video
Panasonic 32" LCD TV showing almost Black pictures
If a 4 year old 32 inch set likely cheaper to replace than repair it assuming parts are even still available.
Aug 25, 2012 | Panasonic Viera TX-32LX77 LCD TV
Samsung TX-P2670WH 26" tv squealing
hi there, you do have a problem at the hozintal section, check the FBT and some parts at the horizontal section and at the power supply section. ty
Jan 01, 2008 | Samsung TX-P2670WH 26" TV
Picture has rolled up leaving a black bar on the bottom
Greeeting from Belize you are having a problem either with cold solder or a problem in the power supply those lines are hum bars due to a defected filter cap.resolder your power supply if that does not solve the problem then you replace the power supply you can get a power supply kit from www.dalbani.com in florida.good luck.also make check in the vertical section if you cannot do it your self take it to a qualified tech to resolve your problem this should cost you about $75.00. to get it fix.
Oct 30, 2006 | Samsung DynaFlat TX-P3076WH 30" TV
Panasonic TX-36PF10 TV Logo
47 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
