Question about Gateway Computers & Internet
Want to re-install everything on gateway desktop
What should i install first on my gateway desktop? I had to replace the hard drive and need to know if i do recovery discs (3) or system disc
  • Gateway Master
  • 4,806 Answers
Hi.
The system disk is the hard drive, use the recovery disks to reinstall the operating system.
Regards.
Posted on Dec 31, 2012
Cytherian
  • 124 Answers
SOURCE: How to install new hard drive
Hi Mark,
External drives have come a long way and run almost as fast as many internal drives. If your need for extra hard drive space is pretty much driven by the Microsoft Flight Simulator game, you could get by with using an external drive. A few things, though: Make sure your system is supporting USB 2.0 (it should be) and that the drive runs at least 5400rpm. External HDD's run off standard 120v AC power.
Otherwise, if you want to get an internal drive, you can certainly get another ATA-133 drive. But SATA is faster and your computer may support it. The D530 CMT (convertible mini-tower) definitely does. But there is also the D530 SFF (small form factor), and D530 USD (ultra slim desktop)--not sure if those are rigged for SATA support.
As for maximum hard disk size supported, that's up to the operating system (e.g. Windows XP vs. Vista). You likely won't need any bios updates because of a new hard drive installation. However, its not a bad idea to review the BIOS update release notes to see what they're addressing.
Posted on Dec 30, 2008
  • 233 Answers
SOURCE: System Restore (Destructive) GM5084 Gateway Media Center w/ XP
So you have an OEM Windows disc with the activation code? You should be able to install the OS from this. Try taking the battery out for an hour then installing XP. Also go into setup and set the CDROM as first boot device. If Windows installs go back and change first boot device to HDD. If it still won't install try a different CDROM drive. I have heard that some CDROM drives will not install XP. I don't know why but I've heard this rumor. There is also a jumper on the motherboard that resets the CMOS to default. I think it is J1, J2? Try switching that to the other position and turn on the unit. Shut down and move the jumper back. That is all I can think of right now.
Posted on Jan 01, 2009
  • 16 Answers
SOURCE: gateway recovery disc
why not goto ubuntu linux it's free to download and easy to use
Posted on Apr 20, 2009
Chinthakaj
  • 416 Answers
SOURCE: Reformated used HP recovery disc when I restart it says SW build ID different from ID on recovery media
You have 2 options. You can write to Microsoft or to HP about your Issue & they might be able to help about the ID issue. Best I would suggest you buy the OS. ( Full installation Pack) this way you have nothing to worry.
Posted on May 11, 2009
  • 186 Answers
SOURCE: Motherboard upgrade - Sony Vaio VGC-RB62G - RAID 0 issue
Why don't you try to get your main drive running before getting into Raid Configurations. Set your single drive to Master and run setup telling it you have one drive. Once you are satisfied that it is not some other fluky error, put in the other drive and I believe if SATA you don't even have to worry about Master Slave. Go about your boot and go into setup again. Hopefully all is good with the world and all that has to be done is fix up BIOS. No matter what, there is never an " out of the box " clean system. Make sure you plug your cables in correctly. I assume you're running EIDE. You'll get it.
Posted on Apr 18, 2010
Gateway zx4351 operating system missing
When did you get this Gateway? Where did you get it? I assume you mean that it has no OS, cause Gateway does NOT make an operating System. Need more details, please!
Nov 08, 2014 | Computers & Internet
Hooking up a Internal Hard drive
You probably need to give more details. If it's a replacement drive, did you reinstall Windows from a CD? Did you copy from the original hd? It's simple enough to remove the two cables from the original drive, physically remove and replace the drive, and hook up the new drive. But then you'd need to boot to a Windows CD in the CD/DVD player to format and install Windows, if that's what you're attempting to do.
There's possibly a recovery partition on the old drive )or a recovery CD). If so, you'd connect the new drive to a second power cable, and data cable (which might not be included in the tower) :
(from http://support.gateway.com/s/Manuals/Desktops/8510406.pdf)
To restore system software from the Recovery discs:
1 Insert the Recovery disc #1 into the CD or DVD drive.
2 Restart the computer, then press and hold
R when prompted to display the restore process options. The
Options menu appears.
3 Select a restore process option:
- Press R to boot from the hard drive recovery partition
or CD. If no recovery partition is found, go to Step 4.
- Press F to format the hard drive and perform a full system
recovery, then go to Step 5.
4 Click a system restore option. For more information, see
"Restoration options" on page 5.
- Non-Destructive System Restore (Recommended)
- Full System Restore (Destructive)
- Full System Restore (with Backup) (Advanced Option)
5 Follow the on-screen instructions to complete the system
software restoration process.
Oct 29, 2013 | eMachines ET183105 PC Desktop
Trying to restore back to factory settings
System Recovery
When you've tried other methods of repairing your
system software (like System Restore or Application
Recovery), you may want to use the Compaq System
Recovery program as a last resort to reinstall the software.
When necessary, you can reinstall the operating system and
the application software that was originally installed on the
PC at the factory by using the System Recovery program.
WARNING: The Compaq System Recovery
program will delete any data or programs
that you installed after purchase. Be sure to
back up any data that you want to keep onto
a removable disc.
The System Recovery program uses a special recovery
partition on the hard disk drive that stores an image of the
original software.
NOTE: The System Recovery image is in a partition area
of the hard disk drive and takes up part of the total drive
space. This disk space is not usually available for your use.
In the unlikely event that you replace the hard disk drive,
or somehow damage the data in the special recovery
partition on the hard disk drive, use recovery discs to
reinstall the operating system and software on the hard disk
drive. See "System Recovery Using Recovery Discs."
Make your own recovery discs (CDs or DVDs) before you
need them; see "Creating Recovery CDs/DVDs." You can
also make the Recovery Tools CD. This CD contains utilities
that allow you to make changes to your hard disk drive; see
"Using the Recovery Tools CD."
Starting System Recovery
if the PC Is Responding
1 Turn off the PC. Disconnect all peripheral devices from
the PC except the monitor, the keyboard, and the mouse.
Turn on the PC.
2 Click Start on the taskbar, choose All Programs,
choose PC Help & Tools, and then click Compaq
System Recovery.
3 Wait until the System Recovery window appears asking
Do you really want to start System Recovery?
4 Click Yes to continue with the recovery process. If you
created recovery discs, you may be directed to insert
recovery disc #1. If the Recovery disc is a DVD, be sure
to put the disc in a DVD drive.
5 The PC starts the recovery; wait for the onscreen
instructions to display, and then follow those instructions.
6 Complete the PC startup, finish the registration process,
and wait until you see the desktop. Then, turn off the PC,
reconnect all peripheral devices, and then turn on the PC.
Starting System Recovery if the PC
Is Not Responding
1 Turn off the PC. If necessary, press and hold the On
button until the PC turns off.
2 Disconnect all peripheral devices from the PC except the
3 Press the On button to turn on the PC.
4 During the startup, do the following to enter the System
Recovery program:
When the black screen with the Compaq logo appears,
press the F10 key on the keyboard. (You have only a few
seconds to press the F10 key before the normal startup
process continues.)
reconnect all peripheral devices, and turn on the PC.
Oct 05, 2013 | HP Compaq Presario SR1115CL PC Desktop
Can i use my emachine recovery disk on my gateway after i install a new hard drive on my gateway?
No, you can't. (Well, it might be possible, but very unlikely, that it would work.) Recovery discs are made for specific machines. There are a couple of reasons why the discs for one system can't be used for another brand or model.
In addition to installing the operating system (Windows), recovery discs also include drivers for the machine's included hardware (video, sound, media card slots, etc.). The drivers on the recovery disc for an eMachines system won't have what a Gateway system needs, unless they were built using exactly the same motherboard and other parts, which would be quite unusual. If wrong hardware drivers are installed, Windows may not start and give you the famous "blue screen of death". Or Windows will start, then begin finding new hardware and asking you for drivers you won't have (although you could find them at the Gateway website). The discs also include the applications the manufacturer preloaded on the system. Some of these may not work and cause problems because of the hardware differences (a sound control program with the wrong sound hardware, for instance).
The other reason is that a restore disc also includes information that gets placed into Windows so the system comes up already activated and ready to go. Activation is based on information about the hardware configuration of the system, and yours won't be correct. Windows will see the this and you'll need to activate manually. If the Windows version on the eMachines recovery disc isn't exactly the same as the one on the Gateway, the product key on the computer won't work when you try activation.
Rather than try using the wrong recovery disc, see if you can borrow or download the installation disc for the Windows version specified on the product key sticker on the Gateway. Then you can do a clean new Windows installation and activate it using the product key. You can find the drivers your computer needs at Gateway's website as I mentioned before. It's more work than just running the recovery disc, but it will work. This does mean the system won't have any of the preloaded applications originally on the computer when you're finished. But this is not a bad thing.
Much of the preloaded stuff on a new computer is often called "bloatware", which you really don't need. It just slows the computer down, uses up Windows resources, and may be gathering information and sending it to sites behind your back. You can find good free programs to do anything originally installed and install only what you really need and want. Here are a few suggestions to get you started:
CD/DVD burning: CDBurnerXP
Antivirus: AVG, Avast!
Audio processing: Audacity
Image processing: GIMP
Office suite: OpenOffice
Good luck getting the system back up and running. Thanks for using Fixya!
Jun 30, 2011 | Gateway GT5670 Desktop PC
I want to wipe hard drive and reinstall recovery disc
Insert recovery disk and press any key when prompted on rebooting the fresh install/recovery will give option to format hard-drive
Removing the need to buy any additional software.
Aug 18, 2010 | Gateway 702GE PC Desktop
Need to load xp on gateway
Do you have a full installation disc or an Upgrade version of XP? The full install should give you an option for partitioning and formatting the new hard drive as part of the installation process. From Microsoft, read this page for details:
http://support.microsoft.com/kb/313348 . You may need some additional drivers if you have a SATA hard drive. More screen shots and details are here: http://www.theeldergeek.com/hard_drives_03.htm .
An alternative way of dealing with the problem may be to use a third-party Partition Manager software (Symantec's Partition Magic, Paragon's Partition Manager). Paragon's site is
http://www.partition-manager.com/ . This site has various levels of Partition Management software (with different features available in the more expensive versions). You'll need the bootable CD version of the software (recovery disc, .iso) to do the partitioning.
I hope this helps.
(I thought the upgrade version could also be done to a new hard disc including the partitioning; all you needed was a Win OS disc from an earlier version to prove qualifying ownership.)
Feb 20, 2010 | Gateway 700 X PC Desktop
What do I need to replace my hard drive on a gateway gt5404 deskt
Here is the support page for your PC, you may wish to contact them about a recovery disc. You can reinstall the OS without it but it's usually cheaper to order the recovery disc (plus it comes with the drivers for your unit).
Feb 22, 2009 | Gateway GT5404 PC Desktop
RECOVERY DISC ALONG WITH UP GRADE IF POSSIBLE
if you dont have the recovery disc for your computer, you will need to purchase a new windows installer, ones it is installed just download the drivers from the manufacturer website.
Feb 21, 2008 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
