Question about Garden
Snowthrower wont go in gear
Starts but wont go forward or backward
  • 755 Answers
Check drive belt! I will bet she is stretched or broken.
Posted on Jan 26, 2013
2 Suggested Answers
huffman49
  • 235 Answers
SOURCE: my yard machine snowthrower wont start
when it just wont start you might want to try checking to see if you get a spark, if that is OK then try rebulding the carb. that usually fixes the problem...good luck but don't forget.. turn the ajustment screw all the way in (not tight) then back it back out 1 full turn. after it starts fine tune it from there..good luck
Posted on Apr 05, 2010
How do I fix my snowthrower which is not going forward or backward sometimes when the gear lever is positioned properly?
Hi Patrick,
Most "walk behind" snowthrowers / blowers have simple mechanical transmissions. No fluids like you would find in a car or truck. You posted in a riding tractor category - so I don't know exactly what you have.
If the fluid is slippery, and dripping on the disc or drive wheel that tracks on the disc, it is just slipping. Open the compartment under the machine to find and stop the source of the drip. Thoroughly clean the disk and wheel, reassemble and you should have forward and reverse again.
Feb 10, 2015 | Light Garden
My saab 900 is stuck and wont go forwards or backwards but the gears aer moving help
1-clutch
2-broken axle or c/v joint
3- transmission failure
Mar 13, 2013 | 1999 Saab 9-5
The neutral lite wont stay on , the foot lever is not allowing it to go to neutral
The neutral light won't stay on because the gearbox isn't in neutral. try rocking the bike backwards and forwards, kick the gears down as many time as you can (at least 6) and then try moving the gear lever up one until the bike moves freely backwards and forwards. Your bike should then start. It would be easier to identify any problems if you let us know the make and model of the bike.
Feb 11, 2013 | Motorcycles
I have Citroen C4 2007 manual gear.Car starts fine and I can change to all the gear but wont move forward or backwards in all the gear?
the gearbox will need to be removed and the clutch inspected it sounds like the drive plate is unservicable
Jan 22, 2013 | 2006 Citroen C3 1.4i
2000 Sebring JXI wont start & when in reverse you can push the car forward or backward
https://s18.postimg.org/4m8krqjk9/sebring_starter.jpg
Click on the link for starter wiring. Not sure what's going on with your tranny? You can see in the diagram, the tranny module gets voltage from the crank position, ignition switch. You can also see the fuse, not only check the fuse, use a testlight and check voltage on fuse circuit.
Any testing, make sure functional parking brake is set and block the wheels. be safe. Safety is your responsibility.
Battery has a full charge and battery connections all good?
Jul 05, 2017 | 2000 Chrysler Sebring
My Yardsman Snowthrower will not move when it is put in gear.
My old machine just did the same thing. When I lift the unit off the wheels with the gear engaged the wheels move. when I put it down the machine doesn't move. This happened while I was using the machine. BTW the machine is 20 years old.
Dec 31, 2009 | Mtd Products Yard Machines 158CC Tiller
Craftsman lt1000 rider 42 in deck is stuck in gear and wont go into neutral. so i cant get it started.
this happens when lawnmower is cut off in gear try this mash clutch and shake mower forward and backwards while trying to shift into neutral
Sep 18, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Every time i put my quad into first gear it wont move forwards
Sinccronise the gearbox and then try again.
Aug 24, 2009 | Cycling
Car wont roll forward or back even in neutral
I assume it's a manual transmission.
If the car will not roll backward or forward in neutral (with or without the clutch engaged) the transmission is most likely locked in two gears at the same time.
This may happen if gear selectors are excessively worn. If you are able to examine the gear selection levers external to the gearbox, ensure they are in the 'neutral' (no gear selected) position when the gear lever is in Neutral. If not in correct position, you may be able to manually reset the levers to correct neutral position and thereby unlock the gearbox.
In any case, if it's happened once, it will happen again, so get the gearbox and gear selection mechanism checked for wear or breakage.
Jul 31, 2009 | 1997 Subaru Legacy
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
