Question about Uniden GMR 4040-2CKHS - two-way radio - FRS/GMRS
Alert keeps flashing on display
The word alert keeps flashing on display monitor and cannot turn it off
    Prodigy:
    An expert who has answered 500 questions.
  • 607 Answers
Do you have the user manual for your radio?
if not, then you need to head off to your nearest Radioshack or similar store, and ask nicely, be prepared to pay for the manual, may get it free. If they have a spare copy, they'll help you.
Otherwise search the uniden website.
under Radio & communications section follow the links, if it's still in stock and available, the radio I refer to, then you should be able to get a link to downloads section for your radio manual.
If that fails to get results, try finding a friendly owner of the same radio with a copy of the manual, and ask if they can send you a copy to your email as an attachment for you do download.
I hope this helps you resolve the issue.
Best regards,
Peter
Posted on Mar 05, 2013
Light flashes for alerts, texts
Select "Accessibility" and turn the ON switch next to "LED Flash for Alerts"
Apr 21, 2014 | Apple iPhone 4 Black Smartphone
Error 1203 on a Dell Printer - what is this?
2080 1203 2055...Critical / Failure / Error...2080 1203 2346The Storage Management Service performs alert monitoring and logging. By default, the Storage Management Service starts when the managed system starts up. If you stop the Storage Management Service, then alert monitoring and logging stops. Alert monitoring does the following:
  • Updates the status of the storage object that generated the alert.
  • Propagates the storage object's status to all the related higher objects in the storage hierarchy. For example, the status of a lower-level object will be propagated up to the status displayed on the Health tab for the top-level Storage object.
  • Logs an alert in the Alert log and the operating system (OS) application log.
  • Sends an SNMP trap if the operating system's SNMP service is installed and enabled.
    http://search.dell.com/results.aspx?s=gen&c=us&l=en&cs=&k=Error+1203&cat=sup&x=10&y=12
Mar 23, 2011 | Vacuums
No display on monitor; green switch keeps flashing
You may have shorted out transistors in the inverter circuits, common problem.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 28, 2010 | Dell E173FP 17" LCD Monitor
Power light and screen keeps flashing on and off. No picture just a black screen.
unplug from pc, turn on monitor. if there is a 'no signal' or any image displayed on the screen then the problem is not the monitor..
Nov 15, 2009 | Dell E153FP 15" LCD Monitor
No video on my Gateway fpd2275w Monitor
First things first a quick check list:
1 Make sure monitor plugged in.
2 Turn on monitor. If there are words and instructions displayed then there is power in monitor. Green light for power next to buttons, etc. If there is no warnings or alerts on the screen. Then we have a power issue to the monitor. Or your back light has gone out preventing you from seeing welcome screen alerts etc.
3. If there is welcome screen alerts etc. then check your plug to the PC. If its connected, then your settings on your PC for the monitor are not configured. If you have two of the same plugs on your computer for the monitor. switch them and roobot. Let me knows how this worked out. Thanks.
Sep 19, 2009 | Gateway FPD2275W LCD Monitor
Flashing green light
http://www.xerox-displays.com/drivers.html
This is the link to the xerox install info. This should fix the problem. If it does not please list the CPU OS and video card you have. Before connecting the LCD monitor make sure in your display properties are set to a refresh rate of 60 hertz. You can set refresh rate by going to the control panel in windows and display settings properties.
Jan 16, 2009 | Xerox XG-91D 19" LCD Monitor
The display menu keeps flashing and i can't get rid of it.
Bad control chip, mine has the same problem. If under warranty - send it in. I just tossed mine and bought a different LCD.
Nov 08, 2008 | Samsung SyncMaster 720N Monitor
Vibration alert - blurry pictures
sigswr50,
The vibration alert flashes when the lighting conditions are poor and the flash is turned off. You can still take pictures in this mode and if teh camera is well stable, the pictures will be sharp. In low light conditions like indoors, turn on the flash or set the camera to Auto mode.
sigswr50 and xenolette
You need to let the autofocus time to focus. Press and HOLD the shutter button HALF WAY and wait for the white rectangle on the LCD display to turn green. Then press the button all the way down to take the picture.
Dec 11, 2007 | Sony Cyber-shot DSC-W80 Digital Camera
Uniden GMR 4040-2CKHS - two-way radio - FRS/GMRS Logo
48 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
