Question about Hitachi Deskstar T7K250 160 GB Hard Drive
HITACHI DESKSTAR 7250 320 GB HARD DRIVE
Ihave a new SATA drive but it is not running at the 3 GB/s transfer speed my system supports SATA II and I have read on Hitachi's site that you need to use the FTOOL. I have tried to use this on the floppy as it explains but when i go to boot from this disc it wont boot. So i made a normal MS boot disc, booted up in DOS and then changed disc's and run Ftool and i get the following error (stub error (2003) cant find dpmi16bi.ovl Has anyone any other idea on changing the transfer speed of the drive.
  • 432 Answers
File on disk maybe bad. Try this website: http://www.mes.cbs.dk/~sttt/readme.txt and http://www.geocities.com/SiliconValley/Network/2963/files.html
Posted on Jun 23, 2007
SOURCE:
Repair broken
Easy, just hook up old drive as secondary and new drive as primary. Copy what you need from the secondary onto the primary. When you are done, just disconnect the secondary drive and enjoy your new one.
Dec 28, 2013 | Hitachi Deskstar 7K1000.C HDS721010CLA332...
Install hitachi p7k500 full speed
Your motherboard MUST have a SATA 3.0 port. It is usually blue or look closely on the motherboard to see where the 3.0 port is located. If your motherboard doesn't have a 3.0 port your hard drive won't be any faster than a normal hard drive.
Feb 09, 2018 | Hitachi Deskstar P7K500 (HDP725050GLA360)...
Hitachi H3D10003272S, 3GB/S or 6GB/S ?
That hard drive has a Sata II (3b/s) interface so you won't get any extra performance from a Sata III (6b/s) port, but it will still run, but it will run as Sata II (3b/s).
Any it should be 3gb not 3gB
b = bit
B = byte
byte = 8 bits
So you would think that a 3gb/s would operate at 375MB/s but manufacturers advertise everything as 10bits = 1 byte so you have to take the speed or even hard drive size and multiple by .8 to get the actual speed 375 * .8 = 300MB actual speed.
Jul 19, 2012 | Computers & Internet
Hitachi Deskstar causes a Power Error on my Gigabyte GA-Z68AP-D3
test all leads that attach to your hard drive including electrical extensions, SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
make sure the CPU central processing unit has thermal grease and a dust free secure seating
even something as small as an electrical extension or a faulty fan lead can cause this problem computers need all of the data and electrical current to travel through every working device and to have an end for a computer to be able work properly
could be a memory dump you might have to many programs running at one time putting to much stress on the CPU not having enough ram will do this
might be getting to hot make sure the CPU has a dust free secure seating and has THERMAL paste
if you right click in the bottom toolbar select task manager applications you will see whats running also processes you will see whats ticking over if you see something running that should not be select end now you might even uninstall that program and some unnecessary programs
check your computer ram and cmos battery to make sure they are securely seated and the battery has plenty of charge
some motherboards cmos batteries are soldered in
hope it helps
May 08, 2012 | Hitachi Deskstar 35 1TB 7200RPM SATA II...
I have Hitachi Deskstar 7K160 HDS721616PLA380 160 GB SATA Hard Drive bios is detected but we cant format
If the operating system can't format the hard drive then the chances are that the drive is either failing or Failed.
Mar 19, 2012 | Hitachi Deskstar 7K160 HDS721616PLA380 160...
My Hitachi Deskstar 7K1000.B doesn't appear when connected to PC.
If you already tried unplugging/reconnecting and/or changing the Sata cable. Then please go to this link and ask for replacement.
http://www.hitachigst.com/portal/site/en/support/warranty/
Mar 26, 2011 | Hitachi Deskstar 7K1000.B HDT721064SLA360...
Hitachi Deskstar - Model HDP725050GLA360 Sata 3.0 500 GB S/N RJ3KSXHE Clicking sound after being dropped. Is there any hope of recovering the data on this drive at a reasonable price?
if the hard disk has crashed and the sound when it runs later he failed to be detected by the system, it is difficult to restore the data in it because it was not detected by the computer. The cheapest way is that you replace with only secondhand.
Feb 20, 2011 | Hitachi Deskstar P7K500 (HDP725050GLA360)...
This is a jumperles HD How to switch ftrom SATA
Http://hgst.com and download the hitachi tools for this drive. It is set via software.
TechRx, Inc. - Green Bay
Apr 19, 2010 | Hitachi Deskstar® T7K500 320 GB Hard Drive
Open Questions:
Dell Printer support phone number +1=855=536=5666+ Dell Printer Customer Service QEFKEFU Dell Printer assistance available 24*7. If you are facing any issues in printer you will get expert assistance through Dell Printer helpline number {+1855.536.56*66*}for fixing all kind of printer related issues within seconds. Dell Printer TeCh SuPpOrT pHoNe #{1855.536~5666*} nUmBeR USA... Dell Printer Tech Support Phone Number +{1-855*536*5666*} to resolve all Dell Printer products. is an American multinational company which was founded by Michael Dell Printer using its company headquarters in Round Rock, United States of America. SPOTIFY tech support pHoNe Number {18555365-666-} to resolve all SPOTIFY products. Dell Printer is an American multinational company which was founded by Michael SPOTIFY using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, Dell Printer care number, and selling of computer-related services and products. SPOTIFY Tech support Phone Number Recently, SPOTIFY has been named the number SPOTIFY customer nical care advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, SPOTIFY tech support number can be dialed to contact the certified customer nicians Contact Customer nical Care Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a SPOTIFY Service Tag or a SPOTIFY Get SPOTIFY Customer nical Care Phone Number and Customer Services. SPOTIFY is a US-based multinational customer organization having its headquarters located in Round Rock, Texas. This customer organization cares, repairs, sells, and develops customer nology products. Basically, the company offers computer related products and services. {1*855.536.5666T~} allows to any type of help is provided of experience employees .Dell Printer CUsToMer cArE {1*855.536.5666I~} nUmBeR USA OFFICIAL Dell Printer CUsToMer cArE Number {1*855.536.5666-} to resolve all OFFICIAL products. Dell Printer CUsToMer cArE is an American multinational company which was founded by Michael OFFICIAL using its company headquarters in Round Rock, United States of America. SPOTIFY toll free pHoNe Number {1855536,5666-} to resolve all SPOTIFY products. Dell Printer is an American multinational company which was founded by Michael SPOTIFY using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, Dell Printer care number, and selling of computer-related services and products. SPOTIFY Toll free Phone Number Recently, SPOTIFY has been named the number SPOTIFY customer nical care advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, SPOTIFY toll free number can be dialed to contact the certified customer nicians Contact Customer nical Care Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a SPOTIFY Service Tag or a SPOTIFY Get SPOTIFY Customer nical Care Phone Number and Customer Services. SPOTIFY is a US-based multinational customer organization having its headquarters located in Round Rock, Texas. This customer organization cares, repairs, sells, and develops customer nology products. Basically, the company offers computer related products and vikki services. Dell Printer tech support pHoNe {18555365-666-}} nUmBeR USA Dell Printer tech support pHoNe Number {18555365-666-} to resolve all Dell Printer products. Dell Printer is an American multinational company which was founded by Michael Dell Printer using its company headquarters in Round Rock, United States of America. Dell Printers Support Phone Number for Dell Printer Technical support help. Dell Printer Support is an independent body, which is established with the vision to deliver exceptional technical service for the Epson brands.
Oct 16, 2019 | Dell Computers & Internet
See all Hitachi Deskstar T7K250 160 GB Hard Drive Questions
Hitachi Deskstar T7K250 160 GB Hard Drive Logo
1,099 people viewed this question
Top Hitachi Computers & Internet Experts
Ekse
Alun Cox
Marvin
Marvin
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
