Question about Microsoft Windows XP Professional
CPU Fan not installed and a continuous sound
A message that CPU Fan not installed and a continuous sound but fans are running
  • 4 Answers
The proccessor is treatened of over heat
Posted on Jan 18, 2009
New case fan running but still getting error message system fan failed.
Did you try;
Power off, power unplugged to computer.
Press the Power On button, and hold it in. Hold for a count of 10 seconds.
Let go.
Do this procedure two more times.
Plug the computer back into power. WAIT 1 minute, turn the computer on.
This method clears CMOS Error Codes, and sets BIOS Setup back to the factory default settings.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00864946&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3340228#N436
CPU fan spinning at required minimum RPM's?
Not talking about the SYS_FAN (Case fan)
Regards,
joecoolvette
Jan 18, 2013 | HP Pavilion a1720n PC Desktop
Dell 5160 stop all of sudden. Message shows CPU too hot. What should I do?
There are 3 or 4 possible causes:
The fan in the computer is damaged.
You are using the computer on a very hot environment.
or ventilation outlets in the computer are blocked.
Aug 28, 2009 | Dell Heatsink Assembly
CPU
this problem comes becauase there may be carbon layer come between proccesor ant the cooling fan.
Apr 07, 2009 | E-Machines eMachines Desktop PC
Buzzer sound from intel d101ggc motherboard
Check the fans in your pc, it sounds like at least one of them isent working properly and your pc gets overheated. When a pc going to warm it gets really slow and hangs.
My guess is that the CPU-fan dosent work properly and your CPU gets overheated, but check all the fans to be sure. The CPU fan runs cantantly, check so it dosent stop now and then.
Good luck
Nov 21, 2008 | Intel D101GGC Motherboard
Fan on
The CPU fan on the GX280 is a variable speed fan. It only runs as fast as necessary to keep the CPU cool. But the fan also has an rpm sensor built in that regulates it at 3000 rpm. If the sensor is going bad, it senses its running slower than 3000 rpm when its actually running faster and continues to speed up until its wide open. Thus the 'jet engine' sound. Replace the fan and that should do it. If by chance it doesn't, it gets more serious and likely a motherboard problem.
Aug 26, 2008 | Computers & Internet
Cpu fan noisy/chip fan fail error messages
pils,
Yes. This sounds like a fan issue. The noise often comes from bearings failing within the fan. Also, a failing bearing can make things harder on the motor as it brings the fan up to speed. This is likely the reason that you see increased warnings during the fan speed check while booting because it comes to speed more slowly as bearing wear increases.
I give this a 90% chance that your CPU fan is causing the issue. Since a decent CPU fan will cost you ~$20 online, it's not much out of your pocket if you happen to uncover another culprit.
I'll keep an eye on this post. Let me know how things go.
Apr 03, 2008 | ASUS A8N-E Motherboard
Cpu fan noisy /chip fan fail
You must buy a new CPU Fan. You can get them HERE or a zillion other places on the Internet. You need a Socket 939 type fan that will handle your cpu speed. If you need help installing it, it may be in the manual. You can read the manual by clicking on the picture of your MB at the top of this post and then scrolling down.
Hope that fixed ya...
Geno
Apr 01, 2008 | ASUS A8N-E Motherboard
E machines h 5038
I had found one continuous problem with the E machine. The CPU fan. Take the cover off. Turn on the system. Is the cpu fan running or very noisey???. I find that the fan as most others collect a lot of dust. You will have to either vacumn or blow the dust & dirt out to free the fan so it spins normally. If the fan has stopped or stops and starts, replace it that may be the reason for the freeze up due to the cpu chip becoming overheated. Now if you are talking about the other fan. The power supply fan stopping and starting the system would shut down when that happens. That would be another issue.
Oct 24, 2007 | Computers & Internet
Microsoft Windows XP Professional Logo
503 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
