Question about Ulysse Nardin Mens Maxi Marine Diver Titanium Watch
I have a Ulysse Nardin self winding watch. On a Heiden watch winder, it doesn't wind without inclining the unit. I had to do this with another winder. Is this a peculiarity with Ulysse or is it th
Winder for automatic watch
When you wind it manually (forward or clockwise) it winds the mainspring. Only need to watch it 5 or 6 times if it's completely stopped you wearing it will do the rest. If you going to get a automatic winder get one that will wind in both directions. It will give a few revolutions clockwise and then we'll go reverse counterclockwise.
Hope this answers your questions thank you.
Jun 06, 2015 | Bulova Mens Marine Star - 98B209 Watches -...
Tip
"Self-winding" Automatic mechanical watches that don't run.
Many questions are posted about watches that don't run or just run for a few seconds or minutes. If it's a quartz/digital watch you need to have the battery replaced. If it's a mechanical watch - even a high end "perpetual" watch like a Rolex, you'll need to manually wind it. Self-winding, or automatic, watches have a rotor in the case that spins as your arm/wrist moves throughout the day. The motion of the rotor winds the watch. When the watch is left unworn for a day or you spend your day just reading a book or otherwise remain inactive, the watch runs down. To restart it and provide a power reserve, simply wind the watch manually by turning the crown clockwise about 40 turns. It should run fine as long as you stay active. If you don't wear the watch everyday and don't want to have to wind and reset it every time you put it on, you can buy a watch winder to keep it moving. You can find them for under $100 on ebay for basic models and for more money you will see ones that wind multiple watches and have nice decorative cases.
on Apr 15, 2010 | Watches
Watch stops after wearing for a few hours
Self winding watches need motion ( wrist twist) without they can stop. Sometimes just shake your wrist for a few seconds. I purchased a winder box for times I don't wear. ( Amazon)!
it is belt driven winder, rotates watch 5 minutes every hour.
Apr 21, 2015 | Rolex Submariner Oyster Watch for Men
How to wind Elgin FG8030 watch?
if self winder. shake/ rotate it , it will self wind from a counter weight inside. or if older it may require a key?
Feb 16, 2015 | Elgin Watches
My automatic omega watch stops after 20-24 hours eventhough i am promised it should last for 48hours if worn continuously for 48 hours.
Almost all automatic wristwatches made today have an 18-24 hour "power reserve" when fully wound. A 24 hour reserve is actually very, very good. I can't think of a modern self-winding wristwatch that has a 48-hour power reserve because that would require a super-long or much larger mainspring than would fit in a modern watch movement / case. There may be some hand-crafted or super-premium watches that can do this, but only a very select few.
Manual wind railroad pocket watches, which were some of the finest and most accurate mechanical watch movements ever made, generally had a 40-hour power reserve. That extra capacity was created by using a large mainspring to store the extra energy. These mainsprings could be used because of the much larger size of these watches, compared to modern wristwatches.
If you are concerned about keeping your watch ticking, even when you're not wearing it, you might want to look at a "watch winder"--basically, a small watch case that rotates the watch for you, keeping the automatic winding rotor moving and the watch ticking. In addition, sitting at a computer all day will wind your watch much less than walking and otherwise moving around. Even though you're wearing your watch, if you're not moving, you're not winding it.
May 09, 2011 | Watches
My A24322 is not working. Pl let me know how to get this started. Is this an automatic watch or a winding watch?
Your watch is an automatic (self winding) watch which can be started by swinging it gently from side to side for some minutes to wind the spring up.
For details see their web site by inserting the following link into your search engine http://www.breitling.com/en/index.php#/models/navitimer/navitimer-world/.
Self winders rely on being used to keep them wound and operate best if used every day.
Jan 08, 2011 | Breitling Navitimer World 715 A24322 Watch
I have a new, purchased ar an auction so no paperwork a Cartier pasha woman's wristwatch. I don't know how to wind it. Please tell me
There are several models of this watch and you don't say which one you have but thi range are either automatic (which means that it is self winding) or quartz (battery driven).
If it is not going it could be
(1) (for a quartz watch) the winder has been pulled out (push it back in) or the battery has expired. (Do you know how old the watch is?).
(2) If the watch says "automatic" on the face, then it haas probably just run down (they run for 2-3 days if they are not used). If this is the case, holding the watch horizontally, swing it gently from side it side for a few minutes (this will operate the self winding mechanism) and the watch should then start. To keep an autimatic watch operating it needs to be worn daily or placed on a winder when not in use.
Aug 23, 2010 | Watches
How do you get started to wind a BMW watch. There is no resistance when I wind the crown. There does nt seem to be any plastic or anything in the way. I ve set the date successfully. Its a BMW Chrono...
mcdevito75 here, BMW watch, nice watch, Actually there are 2 ways to start winding an automatic or self wind watch. Since you feel no resistance in the winder (crown) which if you did, would mean the automatic mechanism is attached by gear to the mainspring and winding the crown (stem) would start the winding process. Without any resistance winding the crown, your automatic mechanism is free-lance as a way of saying, in your watch which simply means your BMW watch winds solely on wrist / arm motion. First, make sure you hear the automatic mechanism moveing inside the watch when you move the watch in almost any direction, now simply hold the watch in your hand and with a rocking motion, say from 12--to 6 rock your hand back and forth for about 30 seconds. You can also make circular motions with the watch in your hand for 30 seconds, any motion that will cause the automatic movement in your watch to move will, start the winding process. After you see you watch has started, simply wear your watch to keep it wound.
Jul 31, 2010 | Bulova Watch
My men's presidential date just is very difficult to wind. I try to wear it often, but it quits. The winding mechanism is so stiff that I can only partially wind it. It does move easily in the oposite...
If it has only recently gone stiff then it sound like a trip to the dealer for repair.
It may sound daft but all the Rolex I have examined are self winders. Is yours? (you can often hear the self winding mechanism by placing the watch close to your ear and rocking it gently).
Could it be that you need to pull out the crown to wind it?
Feb 03, 2010 | Rolex Mens Super President, 18kt YG
The user guide is wrong
I have a Theorema Parago Automatic through not wearing it regularly it sometimes stops. Winding it wouldn't solve the problem and I couldn't find a solution either on the Theorema site or online so through a series of self help efforts the following is the solution for this watch 1 Set the watch to the correct time date day etc. 2 Wind the watch using the side winder for about 40 revolutions in clockwise rotation 3 Hold the watch in your right and strike it firmly into the stiff palm of your left hand. This gives the winding mechanism a shark shock and kicks it back into life.The watch then works away without a problem.
Nov 17, 2008 | Ebel Tarawa Automatic 9127J40/5435136...
Ulysse Nardin Mens Maxi Marine Diver Titanium Watch Logo
56 people viewed this question
Top Ulysse Nardin Watches Experts
Ansel Alberto
Ansel Alberto
Are you an Ulysse Nardin Watch Expert? Answer questions, earn points and help others
