Question about Sharp AL 1631 Copier
On the harp al-1631 what does the flashing f then 5 mean ?
I also need a diagram with all the keys on the machine so i know what they all mean, the book is lost.........................and i cant figure out anything, unless i get the flasing 5 f off................................very imortant , that it is gone and i know then what to do.
it just sets here till i can use it.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
*** ALWAYS DICONNECT POWER SOURCE BEFORE REPAIRS****
Check and clean white stripe, make sure it is clean and white.
Check and /or Replace the exposure lamp, they go bad and cause F-5.
If lamp is good, replace exposure lamp sensor.
Check connector ( flat cable) connections to scanner brd.
Replace scanner brd ( board) if defective.
If scanner brd is good, replace power brd.
Posted on Jan 25, 2009
AL-1631 is flashing "H". How do I fix this which appears to be heat related.
the h means that your fuser needs to be replaced. it might be fixable by changing the thermal fuse but most of the time the whole fuser needs to be replaced
Sep 28, 2014 | Sharp AL 100DR Laser Toner Drum Works for...
We can not find the manual on our Sharp AL-1631 copier. At first the light (shaped like a Z) came on to the left of the green button and we turned off the machine and now that light is off but a flashing...
The flashing red triangle which should look like a stack of dots is your toner cartridge empty indicator. You will need to replace the toner cartridge with a full one or have your existing one refilled. A manual for this discontinued machine will be difficult to find.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 23, 2010 | Sharp AL 1631 Copier
Our Sparp AL-1631 is flashing 4 then H what does it need?
To reset the H4 condition on your Sharp AL 1631 copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
Thank You for using Fixya. Our solutions are being rated this month based on positive testimonials so please leave a testimonial for me if this solution works for you.
Thanks!
Oct 05, 2010 | Sharp AL 1631 Copier
SHARP COPY MACHINE AL 1631 FLASHES A L1 ERROR
Most likely when removing a copy someone hit the scan lock on the front of the machine.
Look on the front , bottom side of the scanner where the paper comes out. You will see a latch that is used for shipping the machine that is more than likely locked.
Thats what causes an L1 90 percent of the time. Just slide it to the unlocked position or take a small screw driver and remove it and throw it away. You can put a piece of tape over the opening to keep dust and moisture out
Jul 15, 2010 | Sharp AL 1631 Copier
AL 1631. Indicates that a drum has to be
To reset the drum light press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone!
Feb 13, 2010 | Sharp AL 1631 Copier
Sharp al 1631 not working properly
That is the drum replacement light reset it by pressing these keys: Clear, then the far left key, then Clear again then far left again.
So C, far left, C, far left
If done quickly like within 4 secomds the display should go blank. If so then key in 24 as if you were making 24 copies.
Now key in 7 and hit print again.
Turn the machine off then on and the light should be gone and the copier is ready to use.
You can reset your drum life at least once with no problems.
Jan 05, 2010 | Sharp AL 1631 Copier
I have a sharp 1631 copier,after start up,i get L-6 error code.what does it
it means your machine was equipped with a counter protection. you need a key counter, swip card or password. i do not know which your machine started with so i do not know what you need now to resolve it. used machine you bought?
Dec 29, 2009 | Sharp AL 1631 Copier
Sharp al-1631 copier. drum error code
You can reset this indicator by pressing these keys in sequence:
Press "C" then press "Exposure Mode" then "C" again then "Exposure Mode" again.
Note that the Exposure Mode key is the far left key on the panel.
One you press these 4 keys in sequence the display should go blank. Then key in 24 as if to make 24 copies. Then press Print (Green Button)
Then key in 7 as if to make 7 copies.
Press print again. You should now get flashing 000.
Turn machine off then back on and the light should be gone.
Here it is in a short version:
C, far left, C, far left, 24, print, 7, print,
then power off and back on.
Nov 16, 2009 | Sharp AL 1631 Copier
Sharp AL 1631 is flashing 1 L. What does that
Hi:
This might refer to your scanner assy being locked. The scanner assy is the unit under the glass that scans your document prior to copying it. Look inside the cavity where you pick up your completed copies. Look at the upper left corner and see if there is a knob there. If there is, make sure it is in the completely unlocked position.
Andrew
Aug 09, 2009 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
35 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
