Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool ultra care ll, how to replace rubber coupling?
How to replace rubber coupling
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 31 Answers
Flip control panel up, take off cabinet, remove pump off motor, remove motor, and your coupling is on the motor and gear case .
Posted on Dec 30, 2012
4 Suggested Answers
jbjaxiis
  • 95 Answers
SOURCE: Ultimate care ll
Either the bleach is being put to the clothes too early, or too much laundry at one time and the bleach cannot mix properly. Check a small load to see if you get the same results
Posted on Jul 08, 2008
SOURCE: whirlpool washer stoped after the agitate cycle
If it fills with water, agitates then stops still full of water (even if you manually advance the timer), you have a bad lid switch. This is an inexpensive repair, or even a do it yourself project.
Posted on May 19, 2009
SOURCE: Burnt rubber smell after replacing motor coupling
what has happened is that the coupler has not been fully seated on the gearbox shaft, the motor shaft, or both. you should use a socket and hammer to firmly seat the plastic coupling on each shaft. If the coupling is not properly seated, the washer will work, you will get rotation, but there will be constant back pressure on the motor shaft, pushing it against the rear bearing race and the pump at the rear, the added friction causes heat buildup in the motor and sometimes overtemp switch operation. Just solved this tricky problem myself. another clue that the coupler isn't fully flush and seated is the last motor retention strap is very difficult to get on, due to the 1/8-1/4 inch extra length.
Posted on Apr 13, 2010
Washer seems to be stuck on spin. Has slight oil/rubber burning smell. Will only advance out of spin if you manually turn the knob to the next step.
The timer is bad and needs to be replaced. if you continue to run it this way you will need to replace the motor coupling real soon. That is where the burning rubber smell coming from.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/charles_c2f37a3461344482
Jan 20, 2014 | Whirlpool Ultimate Care II LSQ9549L Top...
How do I repair my Whirlpool Ultimate Care 2 LSQ9549L Top Loader Washer?
check the motor coupling,if the coupling is broken you'll hear the motor run but the agitiator won't move and no spin,the coupling connects the motor to the transmission.watch this video
http://www.youtube.com/watch?v=9K1KHEogf3c
May 30, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
My whirlpool ultimate Care II Heavy Duty Super Capacity Plus washer Very slightly agitates and don't spin dry
The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
Mar 21, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Jan 16, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool top load washer does not spin. Does
Hi, the likely problem here is a bad coupling. Here are the directions for a bad coupling. Kenmore's, Whirlpool's and Ropers are direct drive machines this means they don't have a belt. Instead the transmission is connected directly to the motor via a coupling. This is what a coupling looks like:
8fbd130.jpg To confirm this pull the machine forward enough that you can lean it back and it will stand back under it's own weight. Wedge something underneath the chassis so it does not fall on you while your accessing the bottom. Go under the Machine and locate the motor, You will see the pump connected to the motor connected to the transmission. 1. Unplug the wire harness from the motor then. 2. Use a screw driver remove the 2 clips holding the pump in place and remove or push the pump out of the way. 3. You will need to remove the 2 screws from the brackets holding the Motor in place with a nut driver. 4. With a screwdriver remove the 2 clips holding the motor in place (be careful to support the motor as the clips comes off) 5. remove the motor and drop it onto the floor. Now you will see the coupling..one side on the motor the other side on the transmission the rubber connector in between. Replace the coupling if broken or worn and reassemble the washer in reverse order. Now you should be all set. Be aware you may smell rubber on the first couple loads this is normal after replacing a coupling.
If you have any other questions please feel free to comment. Mike
Dec 26, 2009 | Whirlpool Washing Machines
The plastic love-joy like coupling stripped out between transmission and motor. What is the easiest way to remove motor and replace it?
REMOVE TWO SCREWS HOLDING CONTROL PANEL
TIP BACK PANEL
REMOVE TWO LARGE CLIPS HOLDING BACK PANEL TO HOB
UNPLG PLUG GOING THRU HOB
TILT CABINET TOWARDS FRONT AND IT WILL SLIDE OFF
REMOVE 2 CLIPS HOLDING PUMP
TAKE OFF PUMP
REMOVE TWO CLAMPS HOLDING MOTOR
TAKE OFF MOTOR
REPLACE 1 RUBBER COUPLING AND 2 PLASTIC DRIVE BLOCKS
REVERSE ORDER TO REASSEMBLEI
Jul 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a whirlpool ultra care 11 washer, model # LSQ92002T0. WILL NOT DRAIN OR AGITATE. STARTED FINE STOPPED DURING USING. THANK YOU
Your motor coupling is probably broken. Tip washer back and look for rubber shavings or any broken plastic.Motor coupling goes from motor to transmission This is common with these models/t.Visually check coupler.
Jul 07, 2009 | Whirlpool Washing Machines
Whirlpool Ultimate Care II drum does not spin.
Depending on your washing machine model, the drum and motor are connected by 2 plastice yellow circular pieces, with a black rubber washer in the middle with holes where the pegs or rods go into. The 2 plastic circular pieces have 3 pegs or rods if you will, that connect to the black rubber washer via 3 holes. Sometimes, one or both of the 2 plastic circular piece pegs get broken off or the rubber washer cracks and breaks apart, so that the motor will not turn the drum. If thats the case, you can purchase the 2 circular pieces and black washer piece as a set.
Jan 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer fills fine but will not spin
the motor coupling is broken. It is a cheap enough part but can be alittle time consuming to replace. it is located directly behind the motor. it is 2 pieces of rubber and i piece of plastic in between the rubber pieces
Jan 02, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultra Care II
I believe this is a similar model to mine, which did the same things. This is a direct drive style (no belt). What possible happened is the coupling in between the motor and transmission has broken partially, and it "grabbing" only under a light load. It's a relatively inexpensive (under $5) part, and can be changed pretty easily.
These couplings can be found on Ebay:
http://cgi.ebay.com/285753-Whirlpool-Washing-Machine-
Motor-Coupling-Coupler_W0QQitemZ170183665420QQihZ007QQcategoryZ20714QQss
PageNameZWDVWQQrdZ1QQcmdZViewItem
If this link doesn't post correctly, just search for "whirlpool coupling". Good luck.
Dec 30, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
Sal De
Gerry Harvey
Gerry Harvey
