Question about Sewing Machines
Can't sew. Needle hits zig-zag plate. Needle is not bent.
  • Sewing Machines Master
  • 1,564 Answers
Replace the needle anyway, it's probably blunted now. Also narrow the zig zag width. But your machine needs adjustment. Take it in for a good clean and repair.
Posted on Dec 31, 2012
SOURCE: Kenmore 1560 Sewing Machine
Be sure TOP control shows zig-zag. Flip top right bar from red to black or black to red on side of machine facing you. You can then change the widths by changing the numbers on that same circle control.
Posted on Jul 17, 2008
  • 323 Answers
SOURCE: can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
Posted on Feb 16, 2009
  • 980 Answers
SOURCE: Skipping stitches while zig-zagging
If you have put a new needle in then the chances are the machine has gone out of time, you can either take it in to the repair shop or you can contact me and I will attach timing instructions drivewithken@blueyonder.co.uk
Posted on May 14, 2009
  • 18 Answers
SOURCE: Singer 457 Zig Zag Sewing Machine not catching bobbin thread.
There are manuals avilable online to purchase for the singer machines, SOrry I was not able to locate a site that has them for free.
.... http://sewingonline.co.uk/singer-manuals.html
Posted on Aug 16, 2009
  • 980 Answers
SOURCE: how do you set the zig zag stitch on a Jones
Change the needle first it may be slightly bent, if you are sewing on fabric that creates static you will need a special needle, failing that you may need to retime the machine.
Posted on Sep 11, 2009
Model 930.Why is presser foot not lined up correctly?
Is your needle position centered? The round dial on the top right is a combination zig-zag stitch width selector and the center silver dial selects the needle position. If it is pointed at the #2, then the needle should be centered and something (probably the needle bar) has been knocked out of alignment on your machine (which would probably mean repair service).
Also, if the needle is hitting the presser foot, you probably have a straight stitch foot on your machine which requires the needle be centered. To do any decorative or zig-zag stitching, the presser foot needs to have a wide space for the needle to swing back and forth. The zig-zag foot is marked with a zero.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&ved=0ahUKEwiP-OL76L7JAhWG9x4KHZ-6AgsQFghDMAM&url=http%3A%2F%2Fberninainstitches.com%2Fpdfs%2FBernina_Presser_Feet_Guide.pdf&usg=AFQjCNFihfp9MHOUl_6HmXxRrC8t3N32TQ&cad=rja
Dec 03, 2015 | Bernina Sewing Machines
Neddle hits the plate, how do i fix it ?
check that the needle is fitted correctly
check for bent needle
check for correct needle
May 23, 2015 | Sewing Machines
Needle hits something and breaks on my pfaff 2140
check that the selector button is fully down on the straight stitch. It should matter if the needle is straight and you have a zig zag plate on the machine. The other option is that the needle is bent and a new one may fix the problem. They dont need to be out by much but you said you had broken needles so it might even be a timing problem and hitting the bobbin case rather than taking the thread to be picked up by the racer.
Mar 26, 2014 | Sewing Machines
Machine won't zig zag even though the needle goes from side to side the line of stitching is straight.
put in a new needle
rethread the machine top & bobbin--use every thread guide
make sure the zig zag settings are correct
it's also possible that the machine could have a worn or damaged gear or cam--which would have to be checked at a sewing machine shop
Mar 20, 2012 | Sewing Machines
I have a Kenmore model 1690. The needle when it goes down does not hit the hole in the foot plate. It comes down too far to the left of the opening, making it impossible to use the machine. I have...
This machine, when you have it on straight stitch, will sew with the needle to the left. If it's hitting the pressure foot, you may have the wrong pressure foot on the machine. If it's hitting the needle plate when you have the pressure foot removed, it's possible you have set for zig zag and you have a straight stitch needle plate on the machine. I believe this machine came with 2 needle plates. One for straight stitch, and another for zig zag.
May 03, 2011 | Kenmore Sewing Machines
Model CG-550. Needle hits a bottom plate. All thread and bobbin removed. Took the feed cover off. Do not see the problem.
Possible bent or wrong needle. If ok, check the zig-zag mechanism to see if it has come uncoupled from the needle mechanism. Good luck!
Oct 02, 2010 | Singer CG550 Mechanical Sewing Machine
THe needle hits the base plate about 1mm on the far side of the hole.
You may have the stitch setting on the left/right(depends which side it hits) setting, or the needle is un-noticeably bent. Depending on where the needle hits, if you are in zig-zag mode and it is hitting the base plate(wide slotted base plate req'd) the machine may need re-setting of the needle stops(if fitted). This is uncommon so its more likely to be a bent needle.
Mar 20, 2010 | Sewing Machines
What foot do I use with the twin needle?
You need to use the zig zag or satin stitch presser foot with the twin needle. You also need to make sure you have the zig zag plate on your machine. Also, remember when using the twin needle, you cannot put your stitch width beyond half way. The best thing to do is once you select the width, turn the handwheel to see where the needle is going to hit, you want to make sure it clears the plate or it will break.
Feb 09, 2009 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
76 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
