Question about Garden
I need to tighten the belts on my Atlas Snow thrower
I need need to tighten the belt for the auger on my Atlas Snow Thrower
  • J.McAndrews Jan 07, 2013
    Thanks for the help
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 30 Answers
There should be an idler pulley with some sort of adjustment. Usually it is just a pulley with a bolt through the center that goes through a slotted hole on the frame. If you loosen the bolt and move the pulley toward the belt, it will increase the tension on the belt. If the bolt is already to the end of the slotted whole and cannot be moved further in, then the belt is worn and stretched and needs to be replaced. Keep in mind that there are other idler adjustment mechanisms that might be used. This is just the most common.
Posted on Dec 31, 2012
2 Suggested Answers
huffman49
  • 235 Answers
SOURCE: Snow thrower is self propelled. was working fine then stalled
check the bearings in the auger sounds like the froze up and now they need to be replaced (the smoking you saw was from the belts slipping on the pullies)..good luck
Posted on Apr 14, 2010
Tip
Snow throwers
Just returned from the parts store, they had sold out of drive belts for the auger drive on snow throwers... figured I could help out here;
Wet snow is heavy, duh right? Before you run your snow thrower disconnect the spark plug, for safety. Check the chute, and sand any loose paint rust etc. you want a smooth chute.. paint if needed, let dry 24 hours before use, spray with silicon lube spray, this will loessen the stress on your auger belt and hopefully keep your machine running all season. Good luck!
on Feb 28, 2010 | Air Purifiers
Briggs&stratton snow thrower model 536.881510
Sounds like a belt that is worn out or needs adjusting to tighten it up.
Feb 11, 2014 | Garden
My MTD 10hp auger will not turn. I adjusted the auger cable by tightening the bolt on the handle. I disconnected the spark plug and checked the shear pins on both sides of the auger. They are both still...
Yes there are 2 belts one for the drive and one for the auger. If you remove the cover on top that is located between the engine and the auger housing you can check the belts. The auger belt has come off the pulley or is broken. Hope this helps you out. Best regards and good luck.
Jan 08, 2011 | Mtd Genuine 9460897 Snow Blower Auger...
Feb 26, 2010 | Craftsman 16" High Garden Tractor Snow and...
Snow thrower won't throw snow
the problem could be the snow is to heavy for the motor to keep up, if thats the case you may need to upgrade to a more powerful model or try not to overload it. take it a little slower so the motor can keep up. but try tightening the belt. with your pointer finger push down on the belt it should have about a half inch give, if it moves more than that its too loose and probably slipping under load
Dec 13, 2008 | Toro Blowers Rake and Vac - Electric...
Garden Logo
154 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
