Question about Health & Beauty
Wahl hair trimmer model nac motor wont start
Plug in turn switch on nothing!
  • 61 Answers
SOURCE: I just bought a wahl detailer trimmer and when I trim my beard,
Your problem is in your blade adjustment,nothing is wrong with the clipper,trust me i've adjusted thousands, set teeth so that hair can easily be feed through when clipper is on,perfect solution,wish i could draw you a picture.
Posted on Jan 26, 2009
SOURCE: how long to charge wahl envoy hair trimmer for?
LEAVE IT ON CHARGE FOR 4-5 HOURS
Posted on Apr 10, 2009
  • 30 Answers
SOURCE: Noisy wahl hair clippers
1st remove the blade. Once the blade is off grab the blade drive between your fingers, if it moves side to side without any spring pressure than the drive arm is loose from the armature. If that is tight, than the armature may be loose and lifted out of alignment. There are two screws on the right hand side of the case which hold the armature. If the screw is phillips head it is standard thread, if it is torx head it is reverse thread. loosen these screws and press down firmly on the armature. The top of the armature should be even with the top of the motor coil. If the drive lever as mentioned earlier is seperating from the armature then this should be warranty repaired by the manufacturer.
Posted on Sep 21, 2009
brector3
  • 1600 Answers
SOURCE: I lost my instruction manual. How do you oil the
Oiling the trimmer is very simple. It is only necessary to apply oil to the blades. Simply apply one or two drops of oil directly to the blades while running. This should be done before each use.
You should have gotten a bottle of the blade oil with your clipper. If you have also lost this, you can buy a bottle of Wahl clipper oil from shaveroutlet.com. see link below
http://shaveroutlet.com/wahl-4oz-squeeze-bottle-clipper-oil-p-584.html
Posted on Jan 24, 2010
  • 10865 Answers
SOURCE: my andis t hair trimmer doesnt work
hello. Chances are that the mechanism has rusted a wee bit. Get an aerosol can of WD-40 penetrating lubrication. Squirt some into the moving head and let it sit over night. Then turn it on. If it still doesn't work repeat the treatment. Joe
Posted on Mar 24, 2010
How to open wahl super trimmer model 1591/1592
Push the blade teeth away from the trimmer body, it will just click off. Undo two screws behind blade, undo one screw at rear of trimmer from the bottom. That's it cases will now split apart.
Jan 19, 2013 | Wahl The Peanut Hair Trimmer
The wahl peanut has the same motor than wahl tid bit?
the tid bit and the peanut are the same clipper. you will find the tid bit clipper at shaveroutlet.com. See link below
http://shaveroutlet.com/wahl-tid-bit-professional-compact-clipper-trimmer.html
Jun 22, 2010 | Wahl 8685 Hair Trimmer
The trimmer won't cut
This Wahl trimmer you need to have the blade sharpen and the trimmer motor adjust. for more power. www.mannyssharpening.com
Mar 17, 2010 | Wahl 8040 Hair Trimmer
Where can I buy attachments for Wahl Super Taper Hair trimmer. Full kit or just No 3?
Manny's Sharpening has the Wahl attachment for $3.00 ea any size from 1/2" to No 9 323 263-4697
Mar 08, 2010 | Wahl Super Taper Hair Clipper 2000 Hair...
Does the Wahl Model AC Trimmer have an adjustment for the blades? There is only a plastic insert between the blades
Wahl has two type of blades for this AC trimmer, some come with a fix blade no adjustment,the other type of blade has adjustable blade. Wahl dose market the blade as adjustable or non adjustable. But mannyssharpening.com has the adjustable blade type were they can adjust the blade for a close cut.
Feb 22, 2010 | Wahl AC Trimmer Hair Trimmer
This is a very good shaving machine and i want another one
You can get these wahl trimmers from Nose Hair Trimmer, that can be used for removing unwanted hairs from nose, ears and eyebrows.
This place would provide you most attractive deals on these branded trimmers with free shipping service.
Apart from wahl trimmer, you can also get recommendations for various other branded trimmers that are hygienic, comfortable and safe to use.
lowcost2.ru_2015.05.08-12.19.02_984580_electric_shaver_nose_ear_face_hair_removal_trimmer_clipper_dlya_nosa_y_ushey_y_brovey3-lmanv4snjocb41esrne4nwpm-3-2.jpg
Dec 03, 2009 | Wahl Vision 180 Beard Trimmer
Have lost charger and battery number for model number9918 please help
from the picture you have here, That I see you have a Wahl 8554 Wahl Alpha cordless clipper. but you stated the model 9918-6171 Groomsman Beard and Mustache Trimmer model, You need to be sure of what model you have. He are the two picture of each model. if this is correct, Mannys Sharpening has the charger for this cordless clipper, I had the same problem and he sent me one it took about 2 weeks for delivery.
27a92b7.jpgThe clipper on your Left is Wahl 9918
3283d36.jpg This clipper is the Wahl Alpa 8554 cordless
Call Mannys Sharpening he has all the replacement charger for Wahl.
323 263-4697
Jul 28, 2009 | Wahl 8554 Hair Trimmer
Health & Beauty Logo
70 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
