I don't know how to save high contrast options
    Genius:
  • 1,669 Answers
You probably have to have Administrator access to make such changes permanent!
Posted on Dec 31, 2012
Want to know how to adjust contrast
Very old set--always adjust so contrast not too high--it should always be lower than brightness---say brightness at 75% and contrast lower--if contrast set too high smearing will occur and picture quality will be affected.
Apr 08, 2012 | Televison & Video
Tip
How to adjust contrast settings on a BlackBerry Tour
Whether you are colorblind, curious, or just into weird color schemes, you can change the contrast on your BlackBerry Tour from the normal colors it displays to either grayscale or inverted colors. Here's how:
1. From the main screen, press the BlackBerry button (the one with seven dots) to get to your Home folder.
2. Scroll down until you see the Options folder (the one with the wrench icon) and click on it.
3. Select Advanced Options from the list.
4. Select Accessibility.
5. Go down to the second option, Color Contrast, and use either the ALT key or the space bar to select a new contrast setting. As you select one, the screen will change immediately, so you can preview each one before making a change.
6. When you've settled on a scheme you like, save the change before exiting; press either the BlackBerry button or the Back button and then choose Save.
The contrast setting you choose will affect just about everything you see on your BlackBerry, including Internet content, pre-loaded games, and even third-party applications. When using the Tour's camera or video camera functions, everything will be displayed in normal color, but any pictures taken will immediately appear altered, depending on your contrast setting. Videos are an exception to this rule; if you watch a video on your Tour with either of the alternate contrast settings, the video will still appear in normal color. (Though if you pause the video, the image it pauses on will adhere to your current contrast setting.)
on Sep 21, 2010 | RIM BlackBerry? Tour 9630 Smartphone
I entered the problem before. Here it is again:
In the Control Panel>Accessibility>Display
If the high contrast box is checked, uncheck it.
When you say in "Add program", where is that exactly? Under Display in the Accessibility window I only see High Contrast Options andCursor Options. Did you maybe change a program in the Control Panels "Add or Remove Programs" section? It's either that
or
your monitor may be entering power saving mode.
This problem could be that your Power Options in the Control Panel have been switched to "switch off the component ever now and then to save power". To change this, do the following:
1) Navigate to the Control Panel by clicking Start and then Control Panel. Then double click on Power Options as shown below circled in red.
2) This will then display the Power Options window as shown below.
3) Once you have opened the Power Option Properties, under Power Schemes select the one that best suits your PC system.
4) Then you can select whether or not to switch off your monitor and/or hard drives after a period of time when it is not being used.
If you have your PC on most of the time then I suggest you select Never as the turn off option for both your hard drive and monitor. If you are using a laptop the turning off the hard drive and screen can however save on battery power when the laptop is not in use.
If your problem persists then it might just be as simple as a loose connection, make sure that your monitor display plug is correctly plugged into your display card or onboard display correctly.
Let me know how it goes.
~Slasher_X
Nov 06, 2011 | Computers & Internet
Somehow I must have done a 'Setting-Mistake' , as my LG monitor ( MS xp ) switches for 3 seconds completely black, in regular sequences of 1 minute. Please help Hans
Hi there.
or
~Slasher_X
Nov 06, 2011 | LG 22" FLATRON LCD Monitor
I received my suunto t3d black watch yesterday and accidentally set the contrast too high and it saved. I've tried everything but can't seem to find the setting to fix it. I've even removed the...
To reset contrast on the sunnuto t3d hold down all 4 corner buttons at once, this will place the watch in sleep mode. Wait a few seconds and press any button to wake the watch back up. This will allow you to run through the inital set up just like when you got your watch, alot of your info will be saved so you can just quickly confirm them with the mode button. I also set my contrast too high, I have reset it to 3 and found it much easier to read in all lighting.
Aug 13, 2011 | Watches
I don't know how to adjust the bright and dark for the screen.
To adjust the brightness and contrast, do the following:
1. Press the either the Minus button and highlight the option you wish to change.
2. Press the Menu button to select the highlighted option.
3. Press the - or + buttons to adjust the brightness/contrast settings.
4. Press the Menu button again to accept the changes.
Click the link below for the documentation on this monitor:
http://support.dell.com/support/edocs/monitors/e156fp/En/about.htm
May 23, 2011 | Dell E156FP 15 inch LCD Monitor
How to change the reverse contrast to normal contrast
On the Home screen, click the Options icon.
Click Advanced Options.
Click Accessibility.
Change the Color Contrast field.
Press the Menu key.
Click Save
Dec 31, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
I HAVE WINDOWS98 AND RECENTLY DOWNLOADED AND INSTALLED A ANTIVIRUS NOW I HAVE A PROBLEM.BAD. EVER SINCE I DID THAT MY COLOR SCHEME ON EVEN THE INTERNET IS AWFUL!!!I HAVE TRIED TO GET IT BACK TO...
Hi There ,
Please follow the Steps Below to Resolve your problem
1. Click on start -- Control panel -- Accessibility Options
2. In the Accessibility Options -- Select the Display Tab
3.To turn off High Contrast, clear the Use High Contrast check box.
and Check it again
Please let me know if it worked
Thanks and regards
Aboobacker sidiq
Internet explorer Specialist
Nov 26, 2010 | Microsoft Internet Explorer 8
I want to change the led color on my blackberry
You cannot make any changes in LED colour settings.However, you can set the color contrast of application interfaces, menus, and pop-up screens to Normal, Grayscale, or Reverse Contrast. To change the color contrast, complete the following steps:
  1. In the Options application, click Screen/Keyboard.
  2. Set the Color Contrast field to Normal, Reverse Contrast, or Grayscale.
  3. Press the Menu key.
  4. Click Save.
Oct 29, 2009 | RIM BlackBerry Pearl 8100
Edge Enhancement Option Disabled...
edge enhancement option i think would be enabled if you are in dynamic or movie mode. What it does is to enhance the contrast of the edges of 2 different colors.
I have the LA32S8, similar specs but only 7000:1 CONTRAST ratio. when playing dvd, i set it to movie mode. Settings vary on different tv and player. you can adjust first the backlight, then brightness then contrast, color and sharpness. the brightness you adjust by choosing the level that shows enough details on dark scenes. adjust if its too dark not to see the details of the scene. contrast, you can set by distiguishing vivid colors of the picture, dont put too much contrast as your picture would look flat. it should have a 3d look, same also with sharpness, you can experiment on the face of a person to show details on the edges.
color you set just enough to make it accurate on color reproduction.
My settings for movie are
contrast 92
brightness 49
sharpness 23
color 57
tint g48 r52
backlight 7
tone warm1
digital NR off
black adjust high
dynamic ocntrast high
gamma +2
edge enhancement on
color space auto
Oct 05, 2007 | Samsung LN-S3241D 32 in.LCD HDTV
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
