Question about Radio Communications
Lost pin to my Bluetooth hype headphones any help
Used to give pin when connecting now it don't and never memorized
4 Suggested Answers
tinualbinale
  • 436 Answers
SOURCE: Having issues syncing my Uniden
Please follow the correct instructions below to successfully pair your headset with the phone.Make sure that the headset is sufficiently charged before pairing.
Charge the battery
Before using your headset, charge the battery for at least 8 hours. Charging the battery completely (and keeping it charged) will help you get the longest possible talk and standby time out of the battery.
Pair the headset to your Bluetooth phone
Pairing is like "introducing" two Bluetooth devices and giving them permission to connect to each other. If you want to use the headset with more than one phone, you need to pair it with each phone separately. Once a phone and the headset are paired, they can connect automatically whenever they detect each other.
1. Make sure the headset is powered off and the power adapter is not connected (you can't use the headset while it's charging).
2. Press and hold Power until the LED flashes alternating red and blue. The headset is in pairing mode and should be visible to other Bluetooth devices.
3. On your phone, start a search for Bluetooth headsets or handsfree devices. (This process may take several seconds, and it will be different for each phone; see your phone's manual for detailed instructions.)
4. Your phone should discover a device called a BT108, BT108 headset, BT109, or BT109 headset, When your phone asks if you want to pair with this device, answer yes.
5. When your phone prompts you for a PIN code or password to pair with the BT108 or BT109 enter 0000.
6. When the headset is paired, the LED turns blue and flashes every 3 seconds. Your phone might display a confirmation message, also.
7. Your phone might ask if you want to change the headset's name; generally, you should only change the name if you have more than one BT108 or BT109 headset that you use with this phone.
Connecting to your phone
Most phones connect to the headset as soon as you pair it; if yours won't, turn the headset off and back on. If headset still won't connect, check your phone's owner's manual for additional Bluetooth information.
Once the headset is paired:
Whenever you turn the headset on, it will automatically try to connect to whatever device it was connected to last.
If the headset loses the connection (e.g., if your phone is out of range), it reconnects automatically. To manually reconnect, press Power.
If the headset goes more than 1 hour with no connection, it automatically turns off.
If you need further assistance please leave me a reply.Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
Posted on Jun 15, 2011
HDI Headsets
  • 537 Answers
SOURCE: my laptop doesn't have a bluetooth so i used a
It may be something in your control panel that you have to adjust or change the settings on. Not sure what you have for a laptop but it will be in the listening or sound portion of your computer.
Good luck from Headsets Direct!
Posted on Oct 25, 2011
HDI Headsets
  • 537 Answers
On your laptop you will need to change the settings in the Sound & Audio Devices to your Plantronics Backbeat 903.
Posted on Nov 11, 2011
My hype Bluetooth earbuds red light keeps on blinking....what should I do?
Dec 30, 2012 | Radio Communications
Tip
How to make your computer or phone passwords more secure
There are a lot of unscrupulous people out there so if you don't want to give them a chance to steal your money or your identity then choose a more secure password for your devices. Do not use the following memorable type of things like birth dates or bank pin numbers these are a thief's easy way into your life. Use a mixture of letters and numbers but also use a capital letter. A good example is Ph0n3 - it doesn't have to be complicated just difficult for others to guess. Good luck and stay safe.
on Mar 11, 2014 | Computers & Internet
My steelseries siberia v2 headset doesn't work for my sisters dell laptop but it works for my toshiba, how do i get it to work for dell?
I don't know what kind of connection you're using, but my guess is that the headphone has a 3.5mm 4 pin connection (has 4 sections of metal on it, and uses the same style connection used in an ipod).
So the reason it will work on your computer is because your receiver has the ability to read 4 pin connections. Hers is likely only for sound (the 3 pin connection). She likely has an additional receiver for a mic, separate from the headphones (thankfully we're seeing fewer and fewer of these).
You may be able to find an adapter at Radio Shack.
Sep 02, 2012 | SteelSeries Siberia v2 - Headset ear-cup ...
My Tiny 755C10 laptop has 44 pins slot and standard ide hdd has 47 pins. what can I do to fix it?
Standard IDE (PATA) HDD connection is 44 pins for a laptop.
(40-pins for a desktop IDE harddrive. Only 39 are used, though. One pin is removed)
http://www.av8n.com/computer/htm/disk-pinout.htm
What manufacturer, and model of HDD, do you have that has 47 pins?
(48 with one pin removed?)
http://pinouts.ru/HD/Ata44Internal_pinout.shtml
SO, the question is,....what is that 47-pin Harddrive?
Post back in a Comment.
Regards,
joecoolvette
Jan 28, 2012 | Computers & Internet
I got a garmin 255w as a gift, therefore I didnt get a purchase receipt. I forgot my pin and my security location is about 3 to 4 hours away from me, since I now moved, so im kind of giving up on this...
You'll have to take it back to the security location as there is no other solution since you don't have the receipt, or ask the gift giver for the receipt so you can get Garmin to reset the PIN. This is to prevent the GPS being used if it is stolen.
Sep 22, 2011 | Garmin nuvi 255W GPS Receiver
Where could i still find the Old Models of Garmin Nuvi 350- 660 -885t
As these models are discontinued, you might purchase them used off Ebay. Be careful, though, about buying stolen units. If they don't give you the PIN code, you will not be able to use the unit.
Sep 22, 2011 | GPS
Put in repair kit , but it still doesn't flush,
what did you replace the flush valve or fill valve don't understand what you put in if you will give more info will be able to tell you exactly how to fix have 37 years experience on plumbing,need more info all that you can give me will be on-line for a little while longer.
Jun 13, 2011 | Plumbing
How to install a wireless access point
It's pretty simple and hp.com has a website where you can pull the quick installation instrucitons if you don't have them. Basically, you set your computer network card (the wired one) to an IP address in the same set as the Access Point's default address. It may be 192.168.0.1 or 1.1, so you give your PC a 192.168.0 or 1. something but 1 address, plug a cable into the port on the AP, open Internet Explorer, and follow the login instructions. We tend to put our AP's at memorable numbers like 221 222 223 etc, or 251,252, whatever so we know where they are. Anyway, give it an address on your network, turn on security if you need to, then unplug it from your computer and back into the network. Reset your computer's network card to either a proper address or Obtain an address Automatically, and the AP should work.
Carl
May 14, 2011 | NetGear Computers & Internet
Hello , i bought a used nintendo Wii system but i cant unlock the parental control, how can i do to change the password or parental control to be able to connect to enternet?
When asking to unlock parental controls, it should ask for a pin. Since you don't know the pin it will ask for a security question. Once again, you probably don't know the security question so ultimately, you need to follow these instructions http://www.nintendo.com/consumer/systems/wii/en_na/settingsParentalControls_reset.jsp
May 10, 2011 | Nintendo Wii Console
Radio Communications Logo
183 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
