Question about Radio Communications
Lost pin to my Bluetooth hype headphones any help
Used to give pin when connecting now it don't and never memorized
My hype Bluetooth earbuds red light keeps on blinking....what should I do?
Posted on May 01, 2014
4 Suggested Answers
tinualbinale
  • 436 Answers
SOURCE: Having issues syncing my Uniden
Please follow the correct instructions below to successfully pair your headset with the phone.Make sure that the headset is sufficiently charged before pairing.
Charge the battery
Before using your headset, charge the battery for at least 8 hours. Charging the battery completely (and keeping it charged) will help you get the longest possible talk and standby time out of the battery.
Pair the headset to your Bluetooth phone
Pairing is like "introducing" two Bluetooth devices and giving them permission to connect to each other. If you want to use the headset with more than one phone, you need to pair it with each phone separately. Once a phone and the headset are paired, they can connect automatically whenever they detect each other.
1. Make sure the headset is powered off and the power adapter is not connected (you can't use the headset while it's charging).
2. Press and hold Power until the LED flashes alternating red and blue. The headset is in pairing mode and should be visible to other Bluetooth devices.
3. On your phone, start a search for Bluetooth headsets or handsfree devices. (This process may take several seconds, and it will be different for each phone; see your phone's manual for detailed instructions.)
4. Your phone should discover a device called a BT108, BT108 headset, BT109, or BT109 headset, When your phone asks if you want to pair with this device, answer yes.
5. When your phone prompts you for a PIN code or password to pair with the BT108 or BT109 enter 0000.
6. When the headset is paired, the LED turns blue and flashes every 3 seconds. Your phone might display a confirmation message, also.
7. Your phone might ask if you want to change the headset's name; generally, you should only change the name if you have more than one BT108 or BT109 headset that you use with this phone.
Connecting to your phone
Most phones connect to the headset as soon as you pair it; if yours won't, turn the headset off and back on. If headset still won't connect, check your phone's owner's manual for additional Bluetooth information.
Once the headset is paired:
Whenever you turn the headset on, it will automatically try to connect to whatever device it was connected to last.
If the headset loses the connection (e.g., if your phone is out of range), it reconnects automatically. To manually reconnect, press Power.
If the headset goes more than 1 hour with no connection, it automatically turns off.
If you need further assistance please leave me a reply.Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
Posted on Jun 15, 2011
HDI Headsets
  • 537 Answers
SOURCE: my laptop doesn't have a bluetooth so i used a
It may be something in your control panel that you have to adjust or change the settings on. Not sure what you have for a laptop but it will be in the listening or sound portion of your computer.
Good luck from Headsets Direct!
Posted on Oct 25, 2011
HDI Headsets
  • 537 Answers
On your laptop you will need to change the settings in the Sound & Audio Devices to your Plantronics Backbeat 903.
Posted on Nov 11, 2011
How do I get a pairing code for a HYPE Ultra Slim Bluetooth Keyboard?
Pairing code for keyboard is not usually required. The one I have basically has a connect button, then you confirm on the computer. Otherwise the most common pairing code seems to be 0000.
Dec 01, 2014 | Hype Technology Ultra Slim Bluetooth...
Need manual for hype audio bomb speaker
You are looking for the same thing I am instructions for the hype audio bomb speaker ?
Sep 09, 2012 | bomb-mp3.com Computers & Internet
My steelseries siberia v2 headset doesn't work for my sisters dell laptop but it works for my toshiba, how do i get it to work for dell?
I don't know what kind of connection you're using, but my guess is that the headphone has a 3.5mm 4 pin connection (has 4 sections of metal on it, and uses the same style connection used in an ipod).
So the reason it will work on your computer is because your receiver has the ability to read 4 pin connections. Hers is likely only for sound (the 3 pin connection). She likely has an additional receiver for a mic, separate from the headphones (thankfully we're seeing fewer and fewer of these).
You may be able to find an adapter at Radio Shack.
Sep 02, 2012 | SteelSeries Siberia v2 - Headset ear-cup ...
How to connet bluetooth on nokia 5230
Bluetooth is a wireless technology that allows devices to communicate via high-frequency radio signals. Bluetooth headphones are just one of the many devices designed to work with portable music devices as well as ordinary phones. With Bluetooth headphones, you can listen to music as well as make and receive calls--all from the same device. Connecting them is a snap.
  • Turn on your cell phone. Enable Bluetooth by accessing your phone's general or network settings. Your phone will search for Bluetooth signals in the area--they are usually denoted by a small icon displayed on the screen. If you don't know how to turn on Bluetooth or aren't sure whether your phone supports Bluetooth technology, refer to your phone's user guide.
  • 2
    Turn on your Bluetooth headphones while near your cell phone. Turning on a Bluetooth-enabled device will usually put it in pairing mode, meaning it is actively searching for a device to connect to. Since your phone also is actively searching for a Bluetooth device, it should find it right away and prompt you to connect to it. It may ask for a password--refer to your headset's user manual for the default password and how to change it.
  • 3
    Test your connection. Once your headset is paired, the phone will usually start sending calls and audio to it without any additional configuration. Some phones may prompt you and ask which device to use. Try making calls and/or playing music. If you hear music from only one ear, your phone may not support stereo Bluetooth. If you don't hear anything, re-pair the headphones. Power off your phone and headphones, then turn them back on and repeat steps 1 and 2.
  • Dec 09, 2011 | VXI Corporation Blueparrott B250-XT...
    Jbl 610 driver
    Windows Vista should see the bluetooth headphones without any extra drivers. If you open your bluetooth options, and you can see the headphones, and it asks for a password, try 0000 or 1111.
    Also - check your computer to ensure that it does have bluetooth capability. If the computer doesn't have bluetooth built in, you'll need to use the USB communicator that should have come with the headphones. If you don't have the USB stick that came with the headphones, your best bet is to contact JBL and see if they will send you a new one.
    Another thing you can try, just to verify the headphones are good - is to try to sync them with an ipod or iphone and see if you can listen to music through them.
    Nov 15, 2011 | JBL Reference 610 Wireless Headphones
    Having issues syncing my Uniden BT112 Bluetooth to my BlackBerry Bold. I used this Bluetooth with another telephone and don't have any of the old packaging. I don't have a pin number. Help!
    Charge the battery
    TinuAlbinAlex
    Jun 15, 2011 | Uniden BT-108 Bluetooth Headset
    How can i connect my bluetooth headphones
    Things You'll Need
    • Bluetooth capable phone
    • Bluetooth headphones
      • 1 Turn on your cell phone. Enable Bluetooth by accessing your phone's general or network settings. Your phone will search for Bluetooth signals in the area--they are usually denoted by a small icon displayed on the screen. If you don't know how to turn on Bluetooth or aren't sure whether your phone supports Bluetooth technology, refer to your phone's user guide.
      • 2 Turn on your Bluetooth headphones while near your cell phone. Turning on a Bluetooth-enabled device will usually put it in pairing mode, meaning it is actively searching for a device to connect to. Since your phone also is actively searching for a Bluetooth device, it should find it right away and prompt you to connect to it. It may ask for a password--refer to your headset's user manual for the default password and how to change it.
      • 3 Test your connection. Once your headset is paired, the phone will usually start sending calls and audio to it without any additional configuration. Some phones may prompt you and ask which device to use. Try making calls and/or playing music. If you hear music from only one ear, your phone may not support stereo Bluetooth. If you don't hear anything, re-pair the headphones. Power off your phone and headphones, then turn them back on and repeat steps 1 and 2.
    Jun 12, 2011 | Cell Phones
    I.Tech BlueBand Bluetooth Stereo Headphones whate is the pin code
    Hi, In some states, hands free driving is the law. In order to avoid a ticket you need to talk on your cell phone with a bluetooth headset or speaker or with a headset that attaches directly into the phone. Bluetooth headsets are popular for this and other reasons but connecting it to your phone can be confusing. Here are some steps to help you connect your bluetooth device to your cell phone.
    Instructions
    Things You'll Need:
    * Bluetooth headset
    * Bluetooth capable cell phone
    Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
    Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
    Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
    Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
    Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
    Hope it helped.
    And please don't forget to rate me...
    Thanks and have a nice day...
    Feb 21, 2011 | Itech Blue Pro Bluetooth Stereo Headphones...
    Radio Communications Logo
    1,793 people viewed this question
    Top Radio Communications Experts
    eradiostore
    eradiostore
    Mike Charette
    Are you a Radio Communication Expert? Answer questions, earn points and help others
