Question about Watches
My Elgin Regulator clock wont chime
I have an Elgin Regulator Wall clock that I just purchased from a thrift store. It keeps time but the chime won't work. It keeps time beautifully. I was messing with it last night and I could not get it to chime. I gave up and went to put it on the wall and it chimed out of no where so now I know it is possible. It takes one battery and had two dials on the back - one to adjust time and the other says "adjust" with a plus and minus sign. Not sure what this adjusts. Does anyone have any idea how I can make this clock chime? I would live to listen to the chime like I used to when at my Grandmothers house when I was little. Thanks in advance! Here is a picture I found on the internet of what it looks like: https://www.proxibid.com/asp/LotDetail.asp?ahid=96&aid=57847&lid=14545833
escapement
  • 2334 Answers
SOURCE: Strausbourg Manor Wall Clock chime adjustment
It is normal for the average wall clock. Of course, this can be adjusted, but without watch/clockmaking knowledge it is impossible, because first you need to find out which part of the movement is causing early chiming - and there are plenty of them.
Super fine adjustment can be found only in top of the range clocks. Hundreds of hours of craftsmenship are spent to adjust and fine tune them. That's why they cost a fortune.
If you can not live with that early chiming, you have to bring your clock down to the watch/clock repair shop and ask for help. Be ready to pay quite a money, as this job takes the skill and a lot of time.
Rate me, please.
Posted on Jul 29, 2009
  • 15 Answers
SOURCE: the time and chimes are out of sync for our tempus
Turn the minute hand until the 16 westminster chime operate and then the hour strikes. Remove the minute hand and simple put it back on at the 12 o-clock position. The chimes should now be in sync.
Fred
Posted on May 10, 2010
SOURCE: Elgin Westminster Quartz Chime clock won't work
IF I GATHER CORRECTLY , YOUR CLOCK HAS TWO BATTERIES, ONE AT BASE AND ANOTHER ON THE BACK OF THE UNIT. THE ONE ON THE BACK OF THE UNIT IS RESPONSIBLE FOR CLOCK'S FUNCTIONALITY AND I THINK THE BATTERY AT BASE IS FOR THE ROTATING BALLS ( PENDULUM ). SO OPEN UP THE BACK IF YOU HAVE NOT DONE SO, AND REPLACE THE BATTERY. CAREFULLY THOUH AS THERE RE TWO SCREWS ON TOP AND A SNAP AT CENTER BOTTOM WHICH YOU COULD EASILY BREAK IF YOU DO NOT DO IT WITH CARE. OPEN UP THE SCREWS FIRST AND GENTLY USING A SCREW DRIVER PUSH BACK ON THE SNAP HOLE TO FORCE IT UPWARDS AND INWARDS. IF NONE OF THIS MAKES SENSE THEN WE ARE LOOKING AT TWO DIFFERENT CLOCKS.
HOPE THIS HELPS.
Posted on Oct 11, 2010
  • 16 Answers
SOURCE: Quartz president wall clock, I need to set the chime
I have a pendulum wall clock from the president collection. If yours is the same or similar, the following may help:
*Look at the back for a slide switch labled "start" at the top and "set" at the bottom and move it to "set"
*Look for for small push buttons. They represent the hours and minutes. Push each in turn, the number of pushes to represent the time, ie, for 09:45, ignore the first(0), push the second 9 times(9)-push the third 4 times(4)- push the 4th 5 times(5). When done, push the slide switch back to "start".
If yours is the same as mine - a wall hung pendulum clock with Westminster chimes, made around 1988. I would be happy to scan and send a copy of the instructions.
John
Posted on Nov 03, 2010
escapement
  • 2334 Answers
SOURCE: I have an Elgin Westminster
I'm afraid you have to visit clock repair shop, as without close inspection it is not possible to say what's wrong with your clock.
Posted on May 18, 2011
How to turn-off chime of elgin Westminster chime wall clock with pendulum?
Are there two batteries. One for the time and one for the chime? Try taking the one for the chime out and it should stop chiming. mine worked that way but is a different make.
Feb 04, 2017 | Elgin Watches
Elgin Anniversary clock chimes early
take the big hand off and move it back one square on the shaft
Nov 11, 2012 | Watches
My Citizen Wall clock runs perfectly, however it does not chime the correct hour. How can I correct this, it is only 3hours off, but it it annoying
take both hands off the clock wait till it chimes then put hands back on to the time it chimes at, then adjust to correct time.
Sep 30, 2012 | Watches
Setting chimes and time for elgin e77
I thought I had some instructions on that Elgin clock, but it was for a mechanical wind up unit. There were many different models of these programmable clocks manufactured and the instructions differed. And they are just not readily available. I received a sports watch in a trade (with no instructions)and after 3 months I am still trying to determine how to program it!
It might be that the "H" stands for hours and the "S" for set. So how do we set the minutes? I will pose this question to my Internet Clocksmiths Group and see if anyone knows. If I do receive some instructions, I will get back with you.
Buy Performance Parts.
Jun 04, 2012 | Elgin Watches
I have an Elgin Westminster chime quartz wall clock (with pendulum). It uses a C-cell battery. It will not work at all. Please help if you can, since it has sentimental value to me. Don't know if...
May 18, 2011 | Watches
I have an Elgin Westminister Quartz Chime clock. Everything works fine, except the pendulum does not swing, anymore. Can I fix this or can I buy parts to fix this problem?
I have a clock with a pendulum and it has two batteries, one for the clock and one for the pendulum.
Perhaps your is the same?
Mar 13, 2011 | Watches
I just purchased a Heritage Mint Ltd Timepiece Quartz Regulator wall clock but it chimes two hours slower than the actual time. Need to know how to correct it. There is a red push button on the back of...
I have the same clock. Here's what I did to re-set it after changing batteries: After replacing batteries, use the turn dial to set the correct time. Press the RED button 6 times, wait for it to go through that series of chimes, then press the button again to set the time.
Example: Press RED button 6 times. Wait for it to chime. Press RED button the correct number of times for the hour to be set. For 5:00, press the button 5 times, etc.
I lost the directions to my clock, and I am posting this from memory and also just had to re-set mine and it works OK now.
Hope this helps!
Feb 07, 2011 | Watches
John
Apr 21, 2010 | Watches
HOPE THIS HELPS.
Sep 23, 2009 | Elgin Watches
Elgin grandfather clock chimes not working
I'm not positive about this, but I seem to recall that these type of clocks have two "silence levers" on the movement. These levers are located at the upper left and upper right corners of the movement as you face the movement from the back. The movement back panel has to be removed if it has one.
If the levers are pushed toward the chime rods, they will silence the hour or musical chime, depending on which one it is. I believe the silence levers are supposed to be moved away from the chime rods so the rods can retract and then strike the chime bars.
Mar 29, 2009 | Elgin 0518709FA
Watches Logo
297 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
