Question about Olympus VN-3100PC Digital Voice Recorder
I don't know how to recorder the voice
Show me the way I can recorder the voice
I need to transfer the audio I recorder on my sony digital voice recorder icd-bx112 to my computer. I don't know how.
There is no direct transfer. You can connect the recorder to a computer and play back the message to an audio recording program on the computer. See "Recording on Other Equipment" on the second page of the manual: http://www.fixya.com/support/p2654563-sony_icd_bx112_voice_recorder/usermanual-0607A34-pdf
Sep 18, 2011 | Sony ICDBX112 Voice Recorder
Need instrution manual. can't figure out how to record, play back and need the manual. please let me know how to get it.
Try
mauritron.com
They have the world's largest library of
owners user instructions operating guides
and
technical repair schematics circuits service manuals
I'm not connected to them, just a satisfied user.
Also if you don't find your item in their listing then ask and they will get it for you
Sep 12, 2011 | Samsung SVR-S1330 Voice Pen Digital...
I have olympus vn-2100 pc digital voice recorder and i don't have the instruction how to use it. could you please email me the instruction? Ruth Ellner
You can download the manual from the manufacturer's web site at
http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=1270
Sorry, but I can't email it to you without an address.
Aug 31, 2011 | Olympus VN-2100PC Digital Voice Recorder
I can not get a manual from the rca site and I don't know how to erase stuff from my device. Help!
You should be able to download the manual at
http://audiovox2.info/docs/common/VR5220/VR5220_OM.pdf
If you can't, please reply to this post specifying the web browser you're using and any error message(s) you get when trying to download the manual.
Aug 15, 2011 | RCA VR5220 Digital Voice Recorder
It wont stop recording, the keys wont work
Check the hold button on the left side. It may be on so no buttons will work.
Jun 30, 2011 | Philips Digital Voice Tracer 4GB Wma MP3...
Hi, i would like to know if recordings can be downloaded from the Coby CXR190-1G to the computer.
Yes, absolutely!
I'm guessing you don't have the CX-R190 software that's compatible with your OS version.
No problem.
I use a patch cable between the AUDIO IN on my PC and the EAR on the recorder.
Since the ouput of the recorder is monoaural, all you need is a mono (2 wire) lenght of cable with a standard 3.5mm plug at each end. I made one myself, but I guess Radio Shack may have something like this:
If they don't have it, then a STEREO cable (3 wires) will work just fine.
Like this one:
To record the sound you can use any audio recorder.
I use Audacity. It's a freebie and pretty straightforward to use.
After you've plugged it all in, all you need to do is start Audacity and then start to playback the files from your recorder.
When they are on your computer, you can copy, cut, paste, add special effects, and later convert them to MP3 or whatever.
Good luck.
Jun 28, 2011 | Coby CX-R190 Digital Voice Recorder
I am trying to download audio files from an Olympus digital voice recorder VN-3100PC to my HP computer that has Windows Vista. But I cannot get the files to show up and I think the driver is not installed...
Most likely the problem is " or something" .
I'm sure you know Windows Vista has issues with many things, even if the Recorder's software claims compatibility.
I know, that does not help at all, but there is a way around the issue.
Crude? Pehaps. Effective? Absolutely!
Since the ouput of the recorder is monoaural, all you need is a mono (2 wire) lenght of cable with a standard 3mm plug at each end. I made it myself, but I guess Radio Shack may have somethinng like that.
To record the sound I use Audacity. It's a freebie and pretty straightforward to use.
After you've plugged it in, all you need to do is start Audacity and then playback the files from your recorder.
Then you can convert them to MP3 or whatever.
Feel free to drop me an email if I can be of more help.
faxmando@yahoo.com
May 27, 2011 | Olympus VN-3100PC Digital Voice Recorder
Im trying to record a telephone conversation but don't know which settings the recorder should be on. Which input on the recorder do I use. The monitor or mix?
Hello don't used the monitor that's only for a headset try the mix or line in if you need and adaptor to connect your phone, this place has a lot of choices including for digital systems at http://www.tvps.com/Departments/Telephone-Recording/Telephone-Recording-Adapters.aspx
Apr 13, 2011 | Panasonic MC6000 Voice Recorder
Olympus VN-3100PC Digital Voice Recorder Logo
29 people viewed this question
Top Olympus Audio Players & Recorders Experts
Mitch Davis
Mitch Davis
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
