Question about LG 26LC2D 26 in. LCD Television
LG 26LC2D will not show any picture
TV will turn on but not show any picture and then will have trouble turning off and then back on
Buen d?a.
Tengo un televisor LG 26LC2D-ME que lo enciendo y no tiene imagen, aparece la imagen despu?s de unos minutos, cuando la vuelvo a apagar y encender tarda menos en aparecer la imagen hasta la tercera o cuarta vez que enciende normal, en ocasiones a la primera vez de encenderla tampoco apaga solamente desconect?ndola de la energ?a el?ctrica la fuente de poder ten?a algunos capacitores un poco gastados que los reemplace por nuevos estos fueron el c222 1000mf 50v, c221 1000mf50v, c234 1000mf35v, c237 1000mf35v, c201 3300mf25v,c202 3300mf25v, c226 1000mf35v, c228 1000mf35v todav?a continua la falla y al parecer los voltajes que alimentan a la tarjeta main y a la t-con est?n correctos la falla solo es en el sistema de encendido no tengo el software de actualizaci?n del equipo que pudiera ser una de las fallas, que me recomiendan revisar, gracias atte. Gabriel Espinosa M?xico gaboo65@gmail.com
Posted on Jan 15, 2015
4 Suggested Answers
  • 19 Answers
SOURCE: LG 42LG5 TURN ON TV PICTURE GOES BLACK
This could be 1 of a few things here. Without opening up your set and trying to look at voltages or indiciator lights I couldn't tell you exactly without some more info.
Without looking at it myself here are my thoughts and where I would first look at.
It may be a main board because:
1) Main board processes all your audio/video signals. Bad main board means bad video processing. Could do that. Especially if the main board is not sending the right signal or a bad signal to the rest of the boards so they don't do their jobs.
It may be a power supply because:
1) Power supply is well, the power supply. If it's sending inadaquete voltage to the main board you may not be recieving enough juice to keep that main board doing your video processing or further up the line keeping enough juice flowing to your TCon board to keep it telling things where to go and what to do. The power supply sends voltages to your Ballast board(controls your lights) and to your main board through which power is supplied to your TCon board via a LVDS line and a +12/+16V signals. If the power supply isn't pumping out enough juice to keep the TCon or Main Board running, it could be a problem. By the same token it could be that your P/S isn't sending power out to your ballast board.
It could be a TCon because:
1) If the TCon is bad, you won't get your pictures. This could be the TCon board itself or the LVDS cable from your TCon to your Main. However, with few exceptions, if it's a bad TCon you're looking at a total panel replacement.
It could be a ballast board because:
1) The Ballast Board controls the lighting behind the LCD screen. If this isn't working right you won't be seeing much of anything without that back lighting. If this is bad, it's a panel replacement. These are not field replaceable items by LG.
Based on the symptoms, without more data or a eyes-on view of it, I would say you're most likely looking at a Main Brd or PSU problem.
Posted on Feb 21, 2009
tvservice306
  • 458 Answers
SOURCE: tv takes 20 mins to turn on
try replaced main board,,,,,
Posted on Apr 03, 2010
joeguest2
  • 2080 Answers
SOURCE: I have a LG 26LC2D
Also try the following codes and see if any of them work better:
11934,
11637,
11530,
10017,
10442,
10056,
11314,
10003,
11032.
Good luck.
Posted on Mar 18, 2011
How to fix/ trouble shoot a 2015ish LG LED 47" TV that plays sound but keeps losing the picture.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
May 11, 2017 | LG Televison & Video
No picture, only sound on LG 47LV5500: how do I get picture back?
Definitely odd for sound to come through and not sound, especially via an HDMI connection.
I would contact LG for support, your TV could be defective.
Good luck
May 28, 2012 | LG 47 47LV5500 47 LCD TV
My LG HD tv screen suddenly went green. sound is
I disagree with info provided, if screen of your LG lcd tv becomes green that means inverter board is working and lcd tv does not have convergence ICs.
Please unplug tv from ac wall socket for minute to get it reset, replug back in and turn it On and check its picture.
If still showing green screen then change input source with remote, if tv shows same green screen on all inputs that means its either lcd panel problem or digital signal processor got bad loacted on main board. Local tv repairman is needed to confirm and fix it.
Thanks.
Jul 21, 2010 | LG 42LC2D 42 in. LCD HDTV
My LCD 32LC2R have a sound but no picture
Can you please tell us the price of inverter board ?
Nov 14, 2009 | LG 26LC2D 26 in. LCD Television
Picture is solarized.. half of screen is dark, but image still viewable.
Sounds like 1 of your back-lights has failed. You will have to take it in to get fixed
Sep 21, 2009 | LG 26LC2D 26 in. LCD Television
No picture when turned on - sound ok
I think that you should try playing around with some of the plugs
Jun 21, 2009 | LG 26LC2D 26 in. LCD Television
TV is on but not picture or sound
try making sure that all your cables are connected and in the right spot where its needed for what components you are using. if it continues, then you have a bad tv and contact either LG customer service or take it back to the store if it's under warranty
Apr 07, 2009 | LG 26LC2D 26 in. LCD Television
LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
Jan 28, 2009 | Televison & Video
LG 26LC2D 26 in. LCD Television Logo
228 people viewed this question
Computer Repairing
Computer Repairing
