Question about Cambridge Soundworks BassCube 12 Speaker
P200 Subwoofer won't power on. Help - Cambridge Soundworks BassCube 12 Speaker
2 Suggested Answers
  • 14 Answers
SOURCE: P200 Subwoofer all quiet
Try taking tha cable out of the amplifier and touching it, this should create a low hum, as your body is sending throug a small current. if this works then you may have accidently switched the sub woffer on in the amplefier. if however you get nothing through the sub then you may have a dry joint in the solder, or the board may be dead. Other option, try an other cable. they also use lead based solder so they do get old.
Posted on Dec 13, 2007
Subwoofer wont play!!
first clean your board.ok.....same problem......?remove chargin connector
Jun 14, 2013 | Audio Players & Recorders
Why won't my powered subwoofer turn on? It's not
Have you check if the plug is good on it?
Dec 03, 2012 | Audio Players & Recorders
8 INCH MTX ROAD THUNDER SUBWOOFER WON'T WORK NO SOUND NO NOTHING
has it ever worked, if so did you ever use it in the cold because in the cold it is possible for the wiring inside the speaker to crack and break
Oct 29, 2012 | Velodyne CT-80 Subwoofer
Which subwoofer will sound the loudest?
When you're looking for a loud subwoofer you'll need to consider sensitivity, enclosure type and available power. You'll need to start with a subwoofer with a high efficiency (sensitivity) rating housed in a ported or band pass box.
Power the sub with an amplifier that has a power output that is within your sub's recommended power range. You'll achieve the slam you're listening for. Using an amplifier with a bass boost control can also help.
Jul 29, 2012 | Furniture
How do i set up my subwoofer sawm40
Sounds like you have a passive subwoofer, you run speaker wire from 'front speaker receiver out' to the subwoofer, the 'subwoofer out' to your front speakers. Seem like your sub has a crossover that grabs the bass frequencies and passes off the rest to the front speakers
If you have a 'subwoofer line out' on your reciever and a 'line in' on you subwoofer then just use that single wire, this would be for a powered sub. You know that you have a powered sub if your sub has a power cord attached to it.
Jan 23, 2012 | Sony Audio Players & Recorders
My Sony CybershotDSC-P200 camera works when it is plugged in, and the screen shows that it's charged. But as soon as I unplug it, it won't even turn on. Is there anything I can do to fix it? Would...
hi you might check battery first. sometime battery goes bad. if not then main pcb is the problem. your local repair shop could charge around $50 depend on what they really want to charge. Thanks...best regard!
May 21, 2011 | Sony Cyber-shot DSC-W130 Digital Camera
I need to know what kind of cable to use for my behringer vmx 1000 usb subwoofer port...i know that it's xlr connection and i have a subwoofer that takes 1/4 inch, so it will be xlr female from the mixer...
The 1/4 inch should be a TRS (balanced connector) You should find pin 1 of the XLR to the sleeve of the TRS. Pin 2 of the XLR can connect to either the tip or the ring of the TRS and pin 3 of the XLR to the other TRS tip or ring. The line should be an audio interconnect line, balanced. If that doesn't work get back to me as there may be another problem. Make sure all interconnected equipment is powered from the same receptacle or power conditioner !!! Remember these subwoofers are WAY down in frequency so unless you have stuff down in the 50Hz or less range it won't do much. That is LOW...
May 03, 2011 | Behringer VMX1000USB VMX-1000USB DJ MIXER
The fuse blows instantly
When the fuse blows supect an overload in either it's power supply or the power amp section. Look round for burnt or damaged parts first. An ohm meter will show a faulty part in this state as it will act like a piece of wire. So when you touch the terminals of a transistor etc (power off) with the ohm meter leads, it will be just like you had touched the leads together!
Jun 13, 2010 | Cambridge Soundworks P200 Subwoofer
Dec 12, 2007 | Cambridge Soundworks P200 Subwoofer
Open Questions:
See all Cambridge Soundworks BassCube 12 Speaker Questions
Cambridge Soundworks BassCube 12 Speaker Logo
23 people viewed this question
Top Cambridge Soundworks Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
 Grubhead
Grubhead
Are you a Cambridge Soundworks Audio Player and Recorder Expert? Answer questions, earn points and help others
