Question about Refrigerators
Daewoo fr661nw freezer part of fridge freezer not freezing food propley
TO be truthful i don't have a manual and don't really no how to work this fridge freezer so any help would be greatly received it has a control panel on front but don't have a clue the freezer is cold but still not freezing stuff properly, and the fridge part works fine
jgwhomeequip
  • 1902 Answers
SOURCE: freezer not freezing food and fridge not staying cold enough
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
Posted on Feb 12, 2009
fridgetech
  • 473 Answers
SOURCE: Daewoo Fridge Freezer not getting cold
Possible problems are a bad evaporator fan motor or a defrost problem. If the back panel in the freezer is frosted up then it is a defrost problem. If no frost listen for the fan in the freezer. If you don't hear it then it may be the problem. Not circulating the cold air.
Posted on Oct 05, 2007
projdoc
  • 2237 Answers
SOURCE: My Daewoo FRS2021IAL has a warm fridge
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Posted on Aug 27, 2009
  • 121 Answers
SOURCE: refrigerator is not cooling/freezing & control panel is flashing
I WOULD UNPLUG UNIT FROM OUTLET AND WAIT ABOUT 5 MIN. THEN PLUG BACK IN. IF WORKS YOU RESET THE BOARD IF DOESNT WORK THENYOU MAY NEED BOARD REPLACED. HOPE THIS WORKS
Posted on Sep 23, 2009
toolkits
  • 1099 Answers
SOURCE: freezer getting cold but not freezing food
..I'm not certain here but there are a couple of things we can look at and diagnose. First, be sure that your doors close tightly. If the gaskets leak, this will allow humidity in...that's where ice comes from. If you 'windowshop', this will also cause icing. Now...let's start with a full defrost. This can take about two days with the unit open and off. Once accomplished, the next thing to do is look at the unit itself. First, underneath, is the condenser coil clean? If not, do that. Now, from the back, remove the felt panel covering the lower portion. The big thing is the compressor. If the unit has been off for more than 20 minutes, clean the big pipe off. Now, start the unit. It should develop frost on the pipe which should either freeze up or dry out after 5 minutes or so. Caution: there is a fan in there! If still frosty, you're low on gas and the unit probably has a small leak. The icemaker can be looked at by removing it. It contains a float. If the float is damaged or jammed, it will not shut off...and will overfill the icemaker. Good luck.
Posted on Jul 28, 2010
My daewoo fridge freezer is freezing food I the fridge on every shelf
Turn down the cold control there can be 1 or 2 if 2 one is main electronic the other just a baffle that controls how much cold air in freezer is allowed into fridge that is be pushed by the fan located in freezer. Cold is only made in freezer then does a circular tour as it leaves cold in freezer moves top 2 bottom then as its warmed it enters freezer to do it all over again . Adjust baffle and or control in this unit it may show 0 or off but there seems to be a lot of movement available before it does turn fridge off. Ive had on a few occasions had how the shelf's are arranged deflect the or mess with the cold airs intended route.
Mar 16, 2017 | Daewoo Refrigerators
FRIGIDAIRE SIDE BY SIDE FRIDGE SIDE TOO WARM
adjust the temp on the freezer setting where it links up with the frig'...
Feb 03, 2013 | Refrigerators
Daewoo american fridge freezer not freezing and not making ice
I think it is your thermostat this controls the motor theirs a top 1 & a bottom 1 they both control the motor 1 4 freezing the other chilling because u say they are both not working it is also posable that ur f/frezer may need re charging
Sep 03, 2012 | Daewoo Refrigerators
Admiral american fridge freezer constantly blowing cold air into fridge compartment.
Changing the freezer settings won't really make a difference because regardless its still going to be freezing. The way the machine works is the freezer cools the fridge, and there should be a control in the fridge that operates the baffles in the airway between the freezer and fridge and reduces the amount of air that enters into the fresh food section.
Jun 17, 2012 | Admiral 26 cu. ft. Side-By-Side...
Whirlpool 6wmv43ns/02 Fridge Too Cold & Freezing Food
I would first try replacing the control in the fridge. If that doesn't remedy the situation, I would try replacing the thermostat next.
May 14, 2012 | Whirlpool Refrigerators
I have a model MTB1956GE Maytag Fridge, Frezzer
Can you feel air moving or hear the fan running in the freezer section? You said the freezer section is freezing well, but is it freezing really hard?
Regards,Richard
Dec 12, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
Freezer side don't freeze food hard. Ice is wet in
The problem can be temperature not set properly or any of fridge or freezer door not closed properly and cool air is getting leaked out. These are basic possibilities which first need to be checked. But if these possibilities are checked ok and still the problem is same, then its weak compressor issue. Click the link below for more details:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
This will help. Thanks.Helpmech.
Oct 27, 2011 | Jenn-Air Refrigerators
My Daewoo ERF 334M Fridge/Freezer has a little ice in the bottom of the freezer and is spilling water onto the floor - think it may be a blockage in the drainage pipe but do not know where this is located...
it go's down locate drain tube at bottom of freezer some time just defrosting manually will cure this drain gets small peace of food or tie from food freezes and blocks water from flowing warm water and a turkey baster works wounders
Aug 15, 2011 | Daewoo ERF336MB Freezer
Refrigerators Logo
117 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
