Question about General Electric RanControl WB27T10264 R CS
General Electric RanControl WB27T10264 R wiring
Wiring
    Problem Solver:
  • 13 Answers
Everything matches up from the old controller except the broil and bake relays l1b goes to com on broil purple goes to no on broil yellow goes to no on bake
Posted on Jan 13, 2013
How to install electric clothes dryer ?
http://waterheatertimer.org/How-to-wire-240-volt-outlets.html
Usually there are 3 screws in a row. The cord has 3 wires in a row.
Connect either outside wire to either outside screw. Connect center wire to center screw.
Look at type of plug on cord.
Gene
h
May 11, 2014 | General Electric Clothes Dryer Knob -...
General electric stovetop (1960's?)
see the diagram attached. God bless you
Nov 05, 2013 | Kitchen Ranges
Defrost heater not starting
4e2ea43c-1c5e-4568-92ef-e26d3e1d4b98.jpgWhat is the model number of the refrigerator so I can look at wiring diagrams and other reasons the defrost heater may not be working? Have you checked continuity through the defrost thermostat? Sea Breeze
Jan 25, 2013 | General Electric WR51X442 DEFROST HEATER...
Looking for upc code for circuit breaker thql 100 amp or the e a n code
The General Electric THQL two pole 100 amp double breaker?
http://www.azpartsmaster.com/Products/Circuit-Breaker----GE-THQL-100-Amp-DP__BKRTHQL21100.aspx
It's coded HACR.
Heating, Air Conditioning, and Refrigeration equipment.
Means it can be used with electric motors. Electric motors draw a surge of electricity to start.
The UPC code will be for THAT style of breaker, and THAT manufacturer who made it.
Same with the EAN.
It will be on the breaker.
Let's use the Connecticut General Electric THQL 21100 100amp 2-pole breaker for an example;
http://www.plumbersurplus.com/Prod/Connecticut-Electric-THQL21100-100-Amp-2-Pole-General-Electric-Thick-Series-Plug-In-Circuit-Breaker/159077/Cat/1478
Here you see it's UPC is 094925005165
If you are trying to purchase, or guide someone remote from you, in buying a breaker that will fit their service panel, find out what service panel it is.
The Model Number.
This will tell you, or a representative that sells breakers, what General Electric style of breaker that is needed.
Or state it in a Comment, and I'll look it up.
Regards,
joecoolvette
Oct 25, 2011 | Electrical Supplies
I NEED A CONTROL BOARD FOR A GE OVEN JRP15WOW4WW
The part# for that is WB27T10264 it could be purchased from your local appliance parts store or online at;
searspartsdirect.com
apwagner.com
appliancepartspros.com
repairclinic.com
apdepot.com
Gene
Aug 13, 2011 | GE JKP15 Electric Single Oven
How do I set a general electric outdoor timer
If I understand you correctly, you have GE outdoor box-type timer, for example the GE-15087. If this is the wrong timer, please respond with model number and I'll look up the information.
http://waterheatertimer.org/How-to-wire-GE-15207-timer.html
http://waterheatertimer.org/How-to-wire-GE-15087-timer.html
6888635.jpgSegment up, timer on segment down, timer off
GE has additional manuals
http://www.jascoproducts.com/support/manual-downloads/index.asp?search=timer&submit=Search&offset=-1
Oct 19, 2010 | General Electric Hardware & Accessories
I'm unable to identify the negative and positive wires of an General Electric air conditioner which has blue and brown, and of course I know the green is for earth. I need help on how to connect these to...
This info almost gets me to feeling positive on the connections. Might see if you can have them send you or direct you to a matching wiring diagram. SOunds like you have 3 wires - blue, brown and green. SO on 240 the blue and brown would connect to the fuse or breaker and then the green would go to the ground bus bar
Aug 19, 2010 | General Electric AEH18DL Air Conditioner
Motor growls & low torque. Need a wire diagram to check for proper wiring.
I'm not sure what happened on here, but your problem with a motor is listed under the heading for a 200amp main breaker. What kind of a motor are you talking about? Gas, electric? what brand what model?
Aug 19, 2010 | General Electric GE ELECTRICAL TQD22200X2...
I have an electric stove that has 1 black, 1 red
Since 1996, the NEC has required that all stoves and dryers be wired with a 4 wire configuration; 2 hot wires (red/black - supplies 240 volts), the bare green ground wire and a white neutral wire. Before you do anything, review this article which speaks to the 3-wire/4-wire arrangement. Good luck!
http://www.hammerzone.com/archives/elect/appliances/range1/cord/4_wire.htm
Mar 09, 2010 | General Electric Stove/Oven/Range Chrome...
General Electric RanControl WB27T10264 R CS Logo
188 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
