Question about Bernina Artista 180
Screen calibration screwed up.. need to know how to reset it?
Was learning machine and accidently went into screen calibration and touched something.. now nothing is responding when touching stitches or anything on the screen????? helppppp
    Novelist:
  • Bernina Expert
  • 166 Answers
You can get back into the touch-screen calibration routine if you start up the machine with both of the needle offset buttons pressed at the same time ... once you've calibrated the touch-screen you'll be OK again.
Posted on Jan 21, 2013
  • Angie Lawrence Jul 06, 2014
    Thank you SOOOOOOO much! Was nearly in pieces when this happened to my 4 day old Bernina 880! Rick you are a GOD! :-)
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 28 Answers
Solution 1 is correct. Listen to Rick Beament. The machine will walk you through the recalibration.
Posted on Mar 06, 2014
3 Suggested Answers
SOURCE: touch screen on bernina artista 180 is slow to respond, is it expensive to repair
contact a sewing machine shop & ask them repair technican
Posted on Aug 07, 2012
SOURCE: bernina artista 180 touch screen slow to respond
A slow screen response time could indicate the touch screen or logic board is failing -- both are very expensive to replace (more than what you're paying for the machine.) Ask the seller to get a repair estimate from an authorized dealer, and talk to that dealer to be sure you're getting the full picture.
Posted on Aug 08, 2012
My Janome mc8000 touch screen is responding all wrong,touch one pattern and it does another but the re calibration won't work
sounds like there could be something wrong with the computer probably needs to be serviced
Apr 01, 2016 | Janome Sewing Machines
How to calibrate the gel on the touch screen of the bernina artista 180
Sounds like something you should ask your Bernina repair service.
Nov 17, 2015 | Bernina Artista 180
Letter characters won't change
You need to re-calibrate the touch screen. It is in the settings menu to reset touch screen. Done.
Cheers,
Embroidery Services
San Diego, CA
Sep 24, 2014 | Baby Lock Esante
Janome 11000
I'm guessing here but you might need to calibrate the touch screen or possibly a circuit board has moved inside the machine. I don't know if you can reboot the machine or return it to factory settings which might reset everything. Failing all of that I'd be asking a computer/phone repair place to look at it.
Apr 23, 2013 | Sewing Machines
.legge@hotmail.comMy designer 1 Touch Screen
Hi,Try this,switch off machine,press in reverse and pivot button together,switch on,release buttons and press up/down needle button,this brings up calibration screen.With a plastic stylus or something similar(not metal) touch in centre of each cross,they should turn green.Switch off and on again. This will calabate machine the screen.
Hope this helps
Mar 22, 2011 | Husqvarna Designer I
Hi Can u please tell me how to calibrate my Designer 1? Have not done it for a few years and now I've forgotten. Also my touch screen is only partially responding....I'm not getting any response...
Hi Vina, Since you can't get any response to your Menu-Norm-Prog-Rep-Set-or Help on your touch screen but you can get into your stitches, It does sound like you need to re-calibrate your touch screen. Normally you would get into your Set Menu to access your touch screen calibration. But as suggested on another solution. You turn off your Des 1, Holding in the reverse button (bottom left of the eight buttons) and the pivot button (the second one from the bottom of the four buttons) at the same time and turn on your machine. This is the Service menu that pops up (try not to touch anything on this screen, it could really mess things up if you don't know what you are doing) After this screen pops up go over to the eight buttons on the far left of your machine and touch the needle up, needle down button (top right button of the eight) the Calibration Screen will pop up on your touch screen (two plus marks labeled 1 & 2) In your sewing sitting position touch the center of the #1 mark and then the #2 mark. Once you've done that the Service Screen will pop back up. Shut off your Des 1 and restart it normally. Try getting into your different menus- Menu-Norm-Prog Etc. Hopefully that fixed your Calibration issue! ** Note: If the service menu doesn't pop up when trying to hold in these 2 buttons together and turning on your Des 1 the buttons weren't held in properly and you need to turn it off and try it again. Hopefully that helped you out!! Happy Sewing!! Kathy
Nov 24, 2010 | Husqvarna Designer I
HOW TO CALIBRATE MY DESIGNER 1 SCREEN the screen is off if i touch program nothing happens and the arrows are off to the right side
Hi,Try this,switch off machine,press in reverse and pivot button together,switch on,release buttons and press up/down needle button,this brings up calibration screen.With a plastic stylus or something similar(not metal) touch in centre of each cross,they should turn green.Switch off and on again,and it should be fixed. Regards, Cathy.
Sep 15, 2010 | Husqvarna Designer I
Janome MC 9000 off touch screen calibration
Thanks guys
I remembered the fix!!
On the Janome MC 9000
To calibrate the touch screen
1. Turn off
2. on Sewing arm above needle there are a series of buttons
3. Hold down bottom 3 buttons
4. While holding turn on machine
5. Using scribe
6. Touch the centre of each + as it appears
7. It will go Centre bottom rh centre top lh as you select each + position it moves of it's own accord.
8. Turn off machine
9 Turn on and test.
Important sometimes this does not entirely fix prob!!
Simply do it again "Yahoo""
Some mechanics will try to tell U the screen is on it's way out
Bollocks just calibrate.
Thanks
CYA
Nov 16, 2009 | Janome Memory Craft 9000 Computerized...
How do you recalibrate the touch screen on the Quantum XL-1000?
Enter service mode....
Press the start/stop switch and hold it while you power the machine on.
THEN, press the reverse switch, hold it and press the lcd. Release the reverse switch AFTER you touch the LCD.
Nov 15, 2009 | Singer Quantum XL-1000 Computerized Sewing...
Sewing Machines Logo
1,040 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
