Question about Samsung Bluetooth?® WEP200 Headset (81451TMIN)
How to pair it with phone - Samsung Bluetooth?® WEP200 Headset (81451TMIN)
Cannot pair samsung alias phone to motorola bluetooth
Hi,it's very easy to pair.
First get one of the phones blue tooth on, and pair with the other phone .
When pairing,it will ask you for password key, you can use any number of your choice, but it has to be a four digit number.(Any four digit number) eg 1234,1111,0000 etc.
Ones you type in the code you want to use for pairing, it wlll ask you on the other phone you are trying to pair to type in that the same code and your done with pairing you, Ones the other phone recognizing the phone you paired it with you can now send data to each other.
If it does not pair immediately, restart the phone and try again.
Good luck.
Sep 27, 2010 | Verizon Communications Samsung Alias Cell...
How do I pair bluetooth from one phone to a new phone? Removing bluethooth from my old phone to another phone.
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Sep 12, 2010 | LG Dare VX9700 Cell Phone
Can not transfer songs from my old phone to my new phone via blue tooth the both phone have connected but when i try to send information it comes up not connected
Hi, you will need pair both phones together before you can be able to send .
Take care.
Aug 20, 2010 | HTC Wildfire Cell Phone
Lg 8700 can not get to pair with any blue toogh device ,my phone has no other devices added
You Need To Type In A 4 Digit PassCode To Get Through To Another BlueTooth Device. Pairing Bluetooth Phones Is Kind Of Complicated. If You Are Pairing 2 Phones... Here Are The Steps:
1.) Find The Other Phone By Searching For It On BlueTooth
2.) Select The Device/Phone You Want To Pair With
3.) Enter The Last 4 Digits Of The Phone Your Trying To Pair With's Phone Number
4.) The Other Phone Should Be Asked If It Wants To Pair With Your Phone, Say Yes
5.) Type In The Last 4 Digits Again Of The Phone Your Trying To Pair With's Phone Number, Except This Time ON The Phone You Are Trying To Pair With
6.) You Should Get A Paired Successful
Pairing With Any Other BlueTooth Enabled Device:
1.) Search Through BlueTooth For The BlueTooth Enabled Device You Want To Pair To
2.) Select The Device You Want To Pair With
3.) Read The Instruction Manual That Came With The BlueTooth Device You Are Trying To Pair With, You Should Find A Pair Key In There Somewhere
4.) Enter The Passkey You Found (OR Already Know) And You Should Be Ready To Go
If All Else Fails, The BlueTooth Is Obviously Broken On Your Phone... Exchange It For A New One
Jan 30, 2010 | LG VX-8700 Cellular Phone
Pairing bluetooth to my phone
  • general instructions for no specific phone and device to pair
    • turn on both devices (phone and other device)
    • on the phone search for a bluetooth devices(that is on)
    • if the other device is asking for a password, enter a known password to success the pairing
    • or else it will pair automatically for a non password pairing
May 03, 2009 | Lands Phones
Bh 101 bluetooth headset lost manual and forgot pairing code
Try this: 1. Ensure that your phone is switched on. 2. If the headset has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light starts to flash blue quickly. If the headset has been previously paired with another device, switch off the headset, and press and hold the multifunction key until the indicator light starts to flash blue quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. See the user guide of your phone for instructions. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. You only need to pair the headset with your phone once. If pairing is successful, the headset appears in the menu of the mobile phone where you can view the currently paired Bluetooth devices. When the headset is connected with your mobile phone and ready for use, the indicator light of the headset slowly flashes blue.
Apr 14, 2009 | Cell Phones
I can't connect Verizon Gleam SCH-U700 to Parrot CK3100
This solution came from Parrot Tech Support and it worked for me:
We were able to get the two to pair using the following steps:
The phone will stay saying pairing, then the parrot will say pairing successful, pull the battery on the phone, when you turn it back on, the phone will display PARROT CK3100 WANTS TO PAIR, ACCEPT? Say YES.
Mar 11, 2008 | Cell Phones
Paired with old phone, can't pair with new phone.
have ya phone ready to almost pair. Then on the 850 ear piece press the call button until lit and then open boom up and press the phone pairing ok button and the 850 should work. waaala!
See how easy that was.
Oct 08, 2007 | Motorola Mobility HS850 Consumer Headset
Samsung Bluetooth?® WEP200 Headset (81451TMIN) Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
