Question about Sony FD Trinitron WEGA KV-36FV27 36" TV
Hello, have a Sony Trinitron KV-36FV27 and I want to know if it has hdmi so I can connect it to the lap top
I just wanted to know if it has HDMI so I can connect it to my lap top. Also I wanted to know what it's called or how it is written in my TV port.
    Sergeant:
  • 214 Answers
I believe it does. It will say HDMI 720p and the connector port is very distinct. You can't miss it..
Posted on Dec 30, 2012
3 Suggested Answers
SOURCE: sony trinitron KV-30HS420 HDMI
Yes. As long as your PC has an HDMI port as well (or at least a DVI port and a DVI-to-HMDI converter dongle).
Posted on Sep 07, 2008
  • 5475 Answers
SOURCE: i want to connect my computer to sony wega
An HDMI to component video cable will not work. These are meant for projectors that work with computers and have only component in jacks.
You will need is a VGA to Composite video converter, VGA to component video converter or HDMI to component video converter. These translate the computer output to the input the TV will understand. Here are some VGA to component video converters: http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-video/c10000-c11200-c11215-p1.html . (The exception is if your computer has a TV-out port. In this case, you need an adapter that looks like an S-video plug that will then have composite or component video jacks.) If you want to use the TV speakers, you will also need a 3.5 mm to 2 RCA audio adapter (either M and F/F for an RCA cable to the TV or F to M/M for a 3.5 mm audio patch cable) or cable (3.5 mm M and M/M RCA).
I hope this helps.
(A computer gives RGB output on the VGA cable; the TV reads PbPrY on the component video. Thus you need for the converter rather than a simple adapter. Similar communication differences apply on the HDMI signal.)
Posted on May 12, 2012
Hdmi instructions
Hi Kelly,
I believe the Sony Trinitron WEGAs do not have an HDMI connection on the back of the TV. If they do it would be labeled as HDMI input below that familiar looking HDMI narrow horizontal connector. But I believe what you have is the RGB connector which looks like three round female connectors which are color coated Red Green and Blue. Now these RGB connectors are a form of high definition but it's not a direct connect for for your HDMI DVD player or your XBOX 360 or what ever you want to hook the TV up to.
You'll have to convert you HDMI to RGB. you can still purchase DVD players with RGB outputs but if you already have a device that requires a TV with HDMI, you can buy a converter. Go to RadioShack or BestBuy or search online for a HDMI to RGB converter cable . It should look something like the picture below.
RED GREEN AND BLUE for video. And then the white and red connectors that are banded together are for your audio.
Good Luck
Dec 12, 2014 | Sony FD Trinitron WEGA KV-32HS420 32" TV
Sony wega tv hdmi not responding to xbox one
Is the Xbox one not picking up the tv if not try an HDMI cable. They mostly cost $15
Dec 30, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I recently bough a used 40in sony trinitron xbr. i have the DVI to HDMI cable but wether its my laptop or xbox the sound wont come through the tv at all. any suggestions?
Check the audio cable it might not been connected securely.
Could also be missing.
Even with the HDMI you may still needs it ( DVI is for video only).
DVI means Digital Video Interface.
Sep 26, 2012 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony kv-36fv27 color is bad.
Know to solders?Resolder ur video board socket holes that connected to( CRT tv Tube).Resolders the Yoke cable red, green,yellow connected to the main board also.Should get colors back,if the colors IC on the video in not dead,and capacitors help the IC on the video board.
Dec 19, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
My Sony Wega KV-36FV27 TV will not turn on
My sony wega trinitron will not turn on, it just clicks when i ush the power button an blinks on standby/timer
Dec 11, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Sony KDS R50XBR1 TV, LIME GREEN PIC
if all sources and hdmi cable are good--you need the hdmi input board--dont know sonys letter designation
Jul 22, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
HDMI port does not work on the KV-30SH420
I dont have a TV with HMDI input but i do have a computer moniter. To change i have to press a button that changes from VGA to HDMI. My computer supports HDMI and when i tried it, it works. Try looking in your manual for a way to switch input methods.
Jan 20, 2009 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Sony trinitron KV-30HS420 HDMI
Jul 10, 2008 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Sony KV-36FV27
Replace all 3 video ic outputs on CRT broad #TDA6111Q,
Feb 06, 2008 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Is the Sony FD Trinitron WEGA KV-36FV27 36" TV a digital TV
This is an Analog TV - you will require converter box.
go here to order it: https://www.dtv2009.gov/ApplyCoupon.aspx
jl
Nov 26, 2007 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Sony FD Trinitron WEGA KV-36FV27 36" TV Logo
77 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
