Whirlpool Front Load Washer Model WFW95HEXLO. NO WATER COMES INTO WASHER - ALL WATER INLETS AND OUTLETS CHECKED
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 31 Answers
Double check model number. Make sure you're getting 120v to the valves.
Posted on Dec 30, 2012
  • 213 Answers
SOURCE: Help with Model #GHW9400SU0 Whirlpool Duet Front Load Washer
unplug washer for 5 to 10 min then plug back in. this should clear the control. if not, the main control needs to be replaced
Posted on Nov 20, 2007
aborcass
  • 2651 Answers
SOURCE: Whirlpool front load washer, Clicking noise during spin cycle
i would open the door nad with your hand (glove on if preferred), feel around the intereior of drom for prhaps a nails, or hair clip that has gotten caught in one of the many holes in tub
Posted on Dec 21, 2008
  • 7 Answers
SOURCE: Front load washer fills up with water
Jamesbestor,
The water fill selenoid had junk in it holding the valve open or the seat in the valve is damaged.
Turn off the power and water, remove two screws on the back of the machine and remove the lid.
On the back left top corner are the water fill selenoids. Remove these and disassemble by undoing the 6 or 8 screws ( depending upon model ) holding the unit together. Clean and reassemble, it should take care of the problem. If not, replace the selenoid.
Posted on Feb 15, 2009
  • 212 Answers
SOURCE: whirlpool duet front load washer has standing water inside
take off bottom panel of washer. unscrew front plug to drain pump. clean out
Posted on Jun 22, 2009
SOURCE: My whirlpool front loader washer leaks water
Check the rubber boot just inside the door. You have to push the drum back slightly and rub your fingers around the entire boot. I had a similar problem and a key had fallen out of a pocket and cut into that boot. The leak would run out of the damaged boot then come out the bottom onto the floor. I purchased a new boot and it took me about 30 min to install it. The problem was solved. If the rubber boot is fine then the over soap thing is probably your problem.
Posted on Nov 20, 2009
Duet front load - water fills while door is open!
This is a leaking solonoid valve.
The valves are located just inside the machine where the water supply hoses attach.
  • Remove the power plug
  • Undo the top lid of the washer
  • The valves will have some internal pipes clamped on their outlets. Remove the pipes.
  • Dry the valve outlets with tissue.
  • Turn on the water supply to the washer (if it was off)
  • Watch the open valve outlets for seepage.
There may be between 1 and 3 valves depending on the model.
You should be able to replace the leaking valve quite easily.
Nov 02, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washer is stopped mid cycle
Is there buzzing? Check that BOTH water inlets are turned on. A common issue is the hoses get reversed, and machine runs fine until Dad gets the hot water bill, and turns off the hot faucet, and the machine will wait forever for the water....
Oct 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Our temperature control isn't working. If we put
You must have water to both inlets. Even with cold/cold, Your washer will mix the water some. Detergent will not activate if your water is extremely cold as it comes straight from the ground.
Nov 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer flashing f- 20.
not enough water coming in washer press pause/cancel twice to clear the codes the check water flow from valves look for dirt clogging the screens at the inlets at the valves kinked hoses make sure valves are full on or water pressure less than 10 psi
Feb 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Ultimate Care II won't fill up with water
Please provide the exact Model number in your reply.
I realize you indicated you had checked the hoses, but check the filter screen at each end of the hoses, and inside the water inlets of the washing machine. If mineral buildup has broken loose inside the lines, it will plug those screens (My neighbor had a similar problem happen to him a couple of months ago, in a bathroom, where 2 sinks, a shower, and the tub, all clogged due to mineral buildup breaking loose inside the pipe system.
Jan 18, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
No cold water on cold settings
Try switching you hot cold inlets to the washer on the back....If that doesn’t work let me know...
cbinny1
Jan 04, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
