Question about Broderbund PrintMaster Platinum
Printmaster platinum 18 won't install on windows 8
I have my disc but it says the OS is not compatible. Is there a work-around?
djrecklezz
  • 57 Answers
SOURCE: cannot install PrintMaster platinum version 18 on 2of 3 computers
on your desktop go to run and look for your software then run it
Posted on Jan 06, 2009
SOURCE: Installing PrintMaster Platinum 16
The program should give you a choice of Typical Install, Full Install, and Minimum Install. Choose Full Install, however she may still need some of her discs for some of the art since the program may not load all the art anyway.
Posted on Jan 26, 2009
proartya8765
  • 581 Answers
SOURCE: I bought a new computer with Windows 7. Is
This should answer your question
I understand that you are inquiring if Printmaster 18 is compatible with Windows 7. Our developers have tested every aspect of Printmaster 18 to see if it will function properly on Windows 7. It has passed all tests except one, which is the Save As PDF feature. Our developers just became aware of this and are working on a resolution to make it work on the Windows 7 operating system. We apologize for any inconvenience this has caused, but we can assure you that we will provide a fix for this as soon as possible.
http://www.broderbund.com/store/broder/Content/pbPage.ProductSupportMain
Posted on Jan 10, 2010
leecom72
  • 4806 Answers
SOURCE: compatability issue
How to install an XP/Vista program on Windows 7
First of all locate the setup or installer file, this will be either in the contents of a CD/DVD (you have to explore the contents of the CD/DVD) under the name "setup" or a downloaded .exe (executable) file.
Right click on the setup file and select "Properties" from the sub menu.
A Properties windows will appear on screen, click on the "Compatibility" tab.
At the bottom of the tab you will see the header "Privilege Level".
Check the box that says "Run this program as an administrator"
Also at the top of the Compatibility tab you will see "Run this program in compatibility mode for:"
Check that box and if you have the option select Windows XP (service pack 3).
Click Apply and then OK and install your program.
NOTE: if you have upgraded from Vista Windows XP mode may not be available depending on how you system was configured.
How to run an installed program on Windows 7
Some programs will install but they won't run on Windows 7. Again this down to compatibility but unlike Vista, Windows 7 has the compatibility mode working down to a tee.
Locate the desktop icon or the program in "All Programs" from the Start Menu or Orb as it's affectionately known today.
Just as in my tip about installing a program it is just the same.
moz-screenshot.pngmoz-screenshot-1.pngmoz-screenshot-2.pngRight click on the icon or file and select "Properties" from the sub menu.
Click apply and then OK and run the program.
NOTE: If you have upgraded from Vista Windows XP mode may not be available depending on how you system was configured.
Regards.
Posted on Jul 09, 2010
  • 2340 Answers
SOURCE: will Printmaster Platinum 16 run on windows 7 I
Printmaster Platinum 16 is not compatible with Vista or windows 7.
Posted on Oct 24, 2010
Unable to download from disc Printmaster v.18.1 despite being led to believe its compatible with Windows 8
Printmaster 18.1 is not really compatible with Windows 8. Here's a link to a possible solution directly from Broderbund. You can try it, but you might be out of luck.
Printmaster 18 1 Platinum
Feb 28, 2014 | Mindscape PrintMaster Premier 7.0
How can I run PrintMaster 16 Platnum in Windows 7
Printmaster 16 Platinum is an older program and is compatible with XP and older versions of Windows.
First check which version of Windows 7 that you have. Click Start > Control Panel > System and Security > System. If your version title ends with x64, you will need to use an option that lets you run an older version of Windows. If you do not see x64 in the title, then the compatibility mode might work.
For the 32-bit OS, right click on the installer and choose Properties. In the Compatibility tab, check the box for always run in the compatibility mode and select an older version of Windows. Apply the changes and click OK. Then right click again and choose Run as Administrator. You may need to repeat this to run the software as well. This is not guaranteed to work in Windows 7 32-bit.
The alternative is to run an older version of Windows. This could be on a second computer, a dual boot computer or a virtual computer (if your hardware supports the feature). Most of these methods require licensed version of the older Windows OS. If you have Windows 7 Pro or Ultimate or upgrade to them, you can run a virtual XP OS for free. Download Virtual PC and XP mode from Microsoft. Then install the Printmaster program in XP as if this is the only OS. (Other virtual computer programs are Parallels and VMWare.)
The only other option is to upgrade to a version of Printmaster that is Win7 compatible. One option is Printmaster 2012 Platinum available here: http://www.broderbund.com/p-273-printmaster-2012-platinum.aspx .
I hope this helps.
Dec 10, 2011 | Broderbund PrintMaster Platinum 16
Have old printmaster platinum 8.0 tried to download on new comp windows 7 it says something about 16 bits
Printmaster platinum 8.0 is rather an old 16bits software and it is not compatible to your new version Win 7 OS.
You can check software compatibility @ Windows 7 Compatibility Center
Your option is to upgrade to version 18 which is Win 7 compatible.
Hope it helps.
Feb 20, 2011 | Computers & Internet
My wife has been using Printmaster for years and has created thousands of projects. Her latest version is 18. We got a new computer with Windows 7 and it said that version 18 is not compatible. So we...
Installing PrintMaster 18 on any computer requires .NET Framework 1.1 to be installed on the hard drive. If NET Framework 1.1 is not installed, it will be installed from thePrintMaster 18 install disk before PrintMaster 18 is installed. If possible download .NET framework 1.1 If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant" in Windows 7 will display this message.To continue with the installation, select "Run Program".
Feb 18, 2011 | Broderbund PrintMaster Platinum Version 18
How do you make Printmaster Platinum 16 work with windows vista
Printmaster Platinum 16 is not compatible with Vista or windows 7. You can try to use Vista compatibility mode to run older programs in Vista. There is not guarantee that it will work!!! Please take note:- **The installation of an older program to run in a newer OS may also crash your PC too.
Link to How to "Use windows vista compatibility mode" - Use at your own risk!
Good luck
Dec 20, 2010 | Broderbund PrintMaster Platinum 16
I installed window 7 into my laptop. My printmaster platinum 18 is now not working properly. What can I do to resolve this issue
Right click on the program shortcut click on properties from the menu and click on the compatibility tab , check "Run this program in compatibility mode of windows xx" and select the version of windows in which the program used to run. Apply the settings and open the program again. If the program still doesnt work try to reinstall or get an updated version for windows 7 maybe Print Master 2010.
Sep 12, 2010 | Broderbund PrintMaster Platinum Version 18
I have chnged my computer system form XP to Window, now I cannot install PrintMaster Platinum Version 17? Is there any way that I can istall this program disc?
Thank you for your question.
In this instance it is easier to direct you to a video on the "Microsoft" website regarding installing older programmes. This is much clearer than trying to explain in writing.
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
All the best with your install.
Kind regards
Jul 20, 2010 | Broderbund PrintMaster Platinum Version 18
How can i run platinum 16 on windows 7. it says there is compatability issues cannot find any driver updates
The recommended solution is to upgrade for version 18.
I'd guess you already tried running the installer by choosing Run this program in compatibility mode (by right clicking and choosing properties) and then right clicking again and Run as administrator.
Your next option is to run a virtual PC within your Win7 computer (or a dual boot system) with a compatible OS running on the "other" machine. With Win7 Pro and Ultimate, there is an option to download two programs and install them for a free WinXP virtual computer (XP mode). For the other primary OS's you'll need to have a valid license of the compatible OS to install in program that runs the virtualization or the second boot disc. Then install the Printmaster in the "machine" with the correct OS. You may find you need to save the files to external media to transfer them. (The virtual computer won't let you have one printer installed on both the virtual system and the real computer.)
I hope this helps.
May 01, 2010 | Broderbund PrintMaster Platinum 16
My printmaster Platinum 10 version will not install on Vista.
downgrade too XP 10 is not compatible with Vista
May 02, 2009 | Computers & Internet
Broderbund PrintMaster Platinum Logo
469 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
