No water coming into Washer
Have checked water supply Hot/Cold, cleaned strainers (filters at rear of Machine) Checked Drainage Hose. Still no water will come into Washer.
    Sergeant:
  • 291 Answers
Faulty water valve most likely.
Posted on Dec 30, 2012
Water does not get hot on a hot wash
Shut off the water. Disconnect & check the BOTH water supply hoses at the MACHINE to check for obstructions / kinks / etc: Check for and clean any strainer / filter on the hoses and inlet to the washer. Direct the hoses into a tub or other container and turn water ON. make sure you have water flow from BOTH hoses and that one is HOT and the other is COLD. If OK, reconnect to machine. Turn water back ON. Choose a WARM wash.
If you get COLD only, you probably have a bad HOT solenoid - if HOT only you have a bad COLD solenoid. Be sure by:
Shut water off and swap hose connections (hot to cold & cold to hot) and try again.
If you get COLD only, you probably have a bad COLD solenoid - if HOT only you have a bad HOT solenoid. If you get HOT only, you probably have a bad COLD faucet / hose - if HOT only you have a bad COLD faucet / hose.
Replace the bad solenoid as needed. Good luck!
Sep 28, 2015 | Hotpoint WMA48 Front Load Washer
I have a lime.stoppage in the washing.machine or hose, where do I start? It is not.the.wall faucet. I tested it.
check/ replace the inlet solenoid valve unit in the machine
if it is faulty or not getting power then the water will not flow into the machine.
simple test is to change the hot water hose to the cold water tap and use hot water setting with the cold water tap on
if the water flows then it is the cold water solenoid
Mar 18, 2015 | Washing Machines
Hot water supply to washer works,but not cold water
Probably the small filter screen in the cold water supply line is plugged up with sediment. The screen will either be directly on where the hose connects to the supply line, or may be on the rear of the washing machine where the cold water supply line connects to the washer, usually a simple screw-on just like a garden hose.
Jun 25, 2014 | Bosch WFMC 3200 Front Load Washer
GE washing maching not filling
Several factors can cause a GE washing machine not to allow water to enter the drum, including closed valves, kinked hoses, a faulty electrical breaker or sediment in the water lines. Sediment occurs most often when the water to the home is off due to electrical outages or when installing items in the plumbing. Cleaning the screens will remove a sediment blockage, allowing water into a washing machine.
    • 1 Check each water valve for the hot and cold water lines to make sure they are open completely. Open valves are turned completely to the left. Check the fuse at the electrical box to make sure it is not faulty, and check to make sure the washer is plugged securely into the outlet. Observe the water supply hoses to make sure there are no kinks from the supply valves to the back of the appliance.
      Observe the water supply valve handles to see if they are cracked. If so, they need replacing.
    • 2 Turn off both the hot and cold water supply valves. Turn each knob completely counterclockwise to turn them to the off position. Pull the washer forward to reach the water supply valves, hoses and the back of the washing machine. Place one hand on each side of the washing machine and slightly lift the front while pulling straight out from the wall.
    • 3 Place a bucket at the rear of the appliance. Use adjustable pliers to unscrew the hot and cold water hoses on the back of the washing machine. Turn each hose counterclockwise to unscrew and remove from the washing machine while pointing them into the bucket to catch any water in the hoses.
    • 4 Turn on the hot water supply valve and hold the hose pointing into the bucket. Observe to see if water is coming out of the hose or trickling out of the hose. Repeat this procedure for the cold water supply hose. Limited water or no water flow indicates that the lack of flow is at the valve end of the water supply hoses.
    • 5 Pull the filters out of the washer valves with needle-nose pliers. Rinse under warm water to clean out any sediment and replace them in the hot and cold water washer valves on the appliance.
    • 6 Unscrew the hot water supply hose from the valve using adjustable pliers. Turn the hose connector clockwise to unscrew and remove. Repeat this procedure with the cold water supply hose. Pull out the screen from each hose with needle-nose pliers and rinse under warm water to clean. Replace the screens.
    • 7 Replace both water supply hoses on the washer valves and the washing machine and tighten them with adjustable pliers. Slide the washing machine back into place and level the legs by slightly lifting the front of the washing machine and setting it back down.
Oct 03, 2011 | Washing Machines
We can only use hot water in our Whirlpool 7.5kg WFE1070BD 1000RPM - how to we shut off the hot water and use cold water? We have tried only cold but the machine will not operate. Please help. Many...
Turn off the water to the machine. Disconnect the cold water hose from the back of the machine and put it in a large bucket. Turn on the water to see if you get full-pressure cold water from the hose. If not, the shut-off valve or other plumbing has a problem.
If you do get cold water from the hose, check the strainer inside the hose fitting on the back of the washer. Clean it if it is clogged. If you still don't get cold water in the machine, you have a problem with either the solenoid valve or the cold water fill contacts in the timer (the timer won't start until the tub is up to the selected level, but if the valve isn't opening or the supply line is otherwise blocked, the machine will never fill). Sometimes in this case you can hear the solenoid valve humming (normally the sound is masked by the running water).
If the problem is a clogged strainer, clean out the hot water strainer also.
I find I get better wash results with warm water (runs both hot and cold for the wash cycle). The soap is more active than in cold water, so I don't need quite so much, and the machine doesn't take as long to finish a cycle since it fills faster. Of course, the cold water has to be running to get the energy savings compared to hot only.
Jun 06, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Ty for being here. I have a kenmore stack washer dryer. Washer is a model 417.94802 301. The hot water feed work fine comming into the machine. However the cold feed only comes in at a trickle. I...
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 05, 2009 | Washing Machines
Cold water into tub of wash machine
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!
Mar 05, 2009 | Kenmore Washing Machines
Cold water feed into tub seems somewhat pluged.
8. re-try.
Kenmore washer: no cold water
easy way for me to determine problem is reverse the hoses on the machine still no cold??? should be no hot now!! in which case you have a bad water valve no cleaning need to replace
Mar 01, 2008 | Washing Machines
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
