Question about Samsung LNR238W 23 in. LCD Television
Qam tuner come with - Samsung LNR238W 23 in. LCD Television
2 Suggested Answers
  • 65 Answers
SOURCE: Does this model have a built-in QAM tuner?
Yes it does.
  • Includes built-in ATSC/QAM/NTSC tuner for off-air HDTV and SD (standard-definition) reception
  • Accepts high-definition 1080i, 720p, and 480p signals from DTV set-top receivers and progressive-scan DVD players
  • Side-panel A/V hookups and controls allow easy connection with a camcorder, gaming console, or other device
  • Posted on Aug 15, 2009
    Ematic AT102 How do you program it to receive the cable channels when no cable box is needed?
    Unfortunately, the Ematic AT102 does not have a tuner for cable television. It only has a ATSC (digital over-the-air) tuner. You need to connect it to an TV antenna and then search for channels. Depending on where you live, you may need an external antenna to get sufficient signal strength to receive local channels. See http://www.tvfool.com for signal strength information in your area.
    Older cable signals are NTSC (same as analog over-the-air). Newer digital cable is QAM. (Some channels are broadcast as clear QAM which don't need a cable box with some tuners/TVs.)
    To record your cable, you will need a different type of DVR/set-top box. An old VCR or DVD recorder with an NTSC tuner would work to record analog cable. There are a few ATSC converter boxes that also support clear QAM. This is one of the models: http://www.solidsignal.com/pview.asp?p=CM-7003 .
    I wish that I had better news for you. Other options are available for NTSC, ATSC or QAM tuners. Please add a comment with more information about your cable service if you'd like extra information on these options.
    Feb 23, 2017 | Televison & Video
    DOES THE SEIKI SE20HY 20 INCH CLASS HAVE A BUILT IN QAM CLEAR TUNER?
    This LED has QAM clear tuner as per manufacturer specifications.
    Jan 01, 2016 | Seiki Televison & Video
    Does the tv model sylvania tvk191 have a qam tuner?
    If the TV is sold in the UK, then yes it has a QAM tuner.
    All TVs have to be able to pick up Freeview to legally be sold as a TV in the UK. Freeview is the public name for the DVB-T service which is our Digital Video Broadcast - Terrestrial service. DVB-T is just the standard definition channels. DVB-T2 is the version of Freeview that includes HD as well as SD channels. The QAMs are the way in which the signal is encoded. But it's really a level of detail that you don't need to go to. It's sufficient to know that the tuner is ether DVB-T for SD only, or DVB-T2 to pick up SD and HD.
    Sep 08, 2014 | Televison & Video
    Comcast cable has stated that i need a cable box unless i have a tv with a QAM tuner. Does my Emerson LF391EM4 flat screen TV have a QAM tuner?
    Depends on where you get your service. Where I liveon East Coast of US, ya got to have a Comcast box (DTA Digital Transit Adapter) or better) PERIOD. Currently, there are no TV sold in my area that can beat the Comcast system. It may be different where you live.
    Aug 05, 2014 | Emerson Televison & Video
    Activate QAM Tuner
    QAM tuner fault. Contact any service technician to replace it.
    If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
    Jul 28, 2014 | Westinghouse LD-3235 32in LED 720p Flat...
    I have a Jensen TV, Model Number TS2050J. I need to know if it has a QAM tuner built in.
    Hi.
    No, your tv is an older model sdtv with an analog only NTSC tuner.
    Newer model have an ATSC/Qam digital tuner, but not your model.
    This means that if you want to watch tv, you'll have to get a converter box. It will have the ATSC/QAM tuner i it, and it converts the signal into lower definition NTSC, and then sends it to the tv through either coax cable, or rca cables.
    Once in a great while you might even find one that has s-video output, but those usually are expensive.
    I hope this helps you out.
    Feb 08, 2011 | Jensen TS2050J 20" TV
    My Brand New 40" westing
    To get HD channel form your cable TV without using the cable provider HD tuner box but using your TV Clear QAM tuner (your TV has Clear QAM tuner, my TV also has QAM tuner so I do not have to use the cabel box, but my COMCAST does not provide may Clear QAM signals like they use to) to get the unscrambled HD, the cable provider must provide those unscrambled Clear QAMsignals for your TV to pick up the signalS.
    Learn more about Clear QAM cable signals:
    http://en.wikipedia.org/wiki/QAM_(television)
    Did you use the correct setup during the tuner setup to scan the availabel cable channel per user manual?
    Dec 30, 2010 | Westinghouse SK-40H520S 40 in. LCD TV
    Can't view local HD with built-in QAM tuner on Sharp Aquos LED
    I found this solution at ehow.com and it works: http://www.ehow.com/how_5417083_hd-channels-comcast.html. You'll just have to switch over to another input to view the HD channels.
    Dec 03, 2009 | Sharp Televison & Video
    Yes it does.
  • Aug 15, 2009 | Samsung DynaFlat TX-P2775H 27" TV
    Samsung LNR238W 23 in. LCD Television Logo
    23 people viewed this question
    Jerry Greenberg
    Jerry Greenberg
