Question about Garden
My neighbor's gardenway snow thrower by troy bilt electric start won't start.
It gets no power. pull start does nothing. it is almost like there is a safety or something preventing starting. no spark is happening
    Habit-Forming:
    New Friend:
  • 7 Answers
Check the oil level. There is a safety device in a lot of small engines that will either kill the motor or not allow the motor to start if it is low on oil
Posted on Dec 30, 2012
landsend
  • 1066 Answers
SOURCE: I just purchased a troy
remove the spark plug.  And pull the cord again.  if the carb float is stuck down or you overfilled the oil you could be hydro-locking the engine.  Check.
Posted on Mar 29, 2009
  • 4 Answers
SOURCE: Troy Bilt Rotor tiller, won't start
lac spark plug on motor pull cord if no spark take the pull start cover off and sand rust off fly wheel
Posted on May 05, 2009
  • 22 Answers
SOURCE: How do I change the belts on a very old troy bilt
It's an old one, for sure. Best thing to do is get an owners manual, in which the belt replacement is fully explained. Basically, you'll have to find something to support the engine, take out the two bolts and bushings on the forward/reverse lever, pound out the two engine mount pins (after you loosen the retaining bolts), slide the engine forward and do you best not to chip the reverse disc. You will likely need to remove the battery mount bracket, it'll make the job easier. Also, you'll need to take off the throttle cable. Getting it back together is a barrel of laughs, you'll need some long screwdrivers to make sure the belts get into the grooves on the pulley. Put the belts on the engine pulley first and slide the engine back into place. Watch out so you don't chip that reverse disc.
In this case, the owners manual would be a big help. It should have pictures which would explain this procedure much better that I can here.
Posted on Jun 14, 2009
lemmingleejn
  • 173 Answers
SOURCE: Rototiller pull start won't pull
First thing to do, if you haven't already, change the oil, and remove all 'old' gas.
Then, after that's done, remove the plug, in order to de-pressurise the cylinder.
Then try to crank it again.
If it turns, then clearly, it's not ceased.
Remember, don't loose you're patience, just take your time.
Good luck with that:)
Posted on Jul 28, 2009
  • 3 Answers
SOURCE: Lawn mower
Always start by checking the spark plug. If you are getting spark and still not starting, it's probably a carburator problem.
Posted on May 06, 2010
Chute on Troy Bilt single stage snow thrower won't turn
CHECK TO SEE IF THE ICE FROZE I THE CHUTE YOU MAY HAVE TO PULL THE COVER OFF THE TOP THIS SOUNDS LIKE THERE MIGHT BE ICE BUILD UP ALSO AFTER THE COVER IS PULLED OFF CHECK THE GEAR THAT TURNS THE CHUTE BY TURNING THE HANDLE
Feb 26, 2015 | Troy-Bilt Squall 2100 208 cc 21-in...
Electric start on Troy Bilt 21" single stage snow blower doesn't work. Recoil starter does. Electric start worked last year, but today, nothing. All cords good, power, etc.
The starter could be bad. Remove starter and see if it will turn over when 120v is applied.Check the wires to starter first! Good-Day!
Nov 16, 2014 | Troy-Bilt Squall 2100 208 cc 21-in...
Troy bilt repair manual
Check with the engine manufacturer if you have trouble with Troy built.
Aug 03, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Remove rim from Troy bilt snowblower?
Excellent. Put some grease on the axle before you put it back together so it comes apart next time.
Aug 02, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Snow thrower starts then shuts down after a few minutes
Hmmm... THAT sounds like you have an obstruction (ice???) in the fuel line or in the bottom of the tank.
Feb 15, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Augur wont turn on troy bilt model 2410 snowblower,stall s out when i engage the augur
ICE OR HARD PACKED SNOW IN BLOWER HOUSING
warm up or pour hot water down chute to thaw out
Feb 13, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Engine lopes after it gets hot won't maintain full RPM
still something in that carb that needs to be cleaned out
Feb 08, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Snow Thrower Won't Start. I have a Sears 26" Snow Thrower Model No 247.889702. It will not start. Changed fuel, new spark plug, propoerly primed the engine, tried both pull start and electric star
does it have spark? if you can start it with starting fluid chances are the carb needs a good cleaning or replacement. fuel these days goes bad in about 2 months without stabilisers in it. gums up the tiny passages in the carbs. i suggest seafoam as a treatment but anything is better than nothing...good luck
Nov 18, 2017 | Garden
Electric starter won't engage with the engine.
Hi
Disassembly the starter and ceck the starter housing,the armature,the end cover(with brushes and springs) and pinion gear.Also check the wires.Charge the baterry.
best regards savumihai71
Dec 21, 2008 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
79 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
