Question about LG Washing Machines
Water coming out from under the washer - LG Washing Machines
    Sergeant:
  • 291 Answers
Do you know how to get the front or back of machine off? You didn't provide a mod# or description of the machine so i can't tell you, but you will have to see inside/underneath to find the leak. Often times a hose-clamp just needs tightened or replaced, but it could also be from a faulty water pump (easy fix), water valve (easy fix), or a tub seal (definitely NOT an easy fix.) Try reposting with a model number and maybe one of us can tell you how to get in there so you can see what's going on. It's possible nobody will see it if you just reply to this post.
Posted on Dec 30, 2012
Water does not go into the detergent chamber. The water comes out from under the machine on the floor.
Are you sure that is not the "bleach chamber"?
To avoid risk of "bleaching" some parts of clothes with concentrated, bleach, the washer will get the bleach only when water is full & washing has started.
Non-bleaching detergent can just be put in with dry clothes.
Dec 21, 2013 | Kenmore HE2 Plus Front Load Washer
Water coming out from under washer
What is the complete model number of your unit?
Nov 23, 2012 | Washing Machines
Older model washer, water coming out under the washer
hose could be leaking going to your pump there are two attached to it, also the pump has a seal where it connects to the motor could be leaking there, and there is a tub seal. but it does sound like a hose came loose
Feb 10, 2010 | Washing Machines
Ndesit IDL 535 DW, not cycling, water coming from under unt.
The washer is fitted with an anti flood device that detects water leaks and closes water inlet valve and puts washer in pump out mode. The anti flood device is a polystireen float with micro switch at the bottom floor of the washer. Dry the water and find the leak (pipe or pipe clamp) and this should then solve the error.
Jan 22, 2010 | Indesit 24 in. IDL500 Built-In Dishwasher
Washer is leaking. If facing washer, water is on
probablly water pump or hose tilt machine to view where water is coming from
Jan 17, 2010 | Kenmore HE2 Plus Front Load Washer
Water under stackable washer dryer
The front panel comes off and you will be able to trace the water source. These combo units spin immediatly and if the drain is slow the water will spin up over the edge of the tub during drain.
Eric
Dec 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
Leak from under the washer
tub seal has gone bad, will only get worse. Expensive fix,
Jul 02, 2009 | Maytag PAV2300 Top Load Washer
GE Profile top load washer purchased 2003 water comes out from under washer when spin and drain cycle on. this not mentioned in trouble shooting area. think it is water pump or whatelse can it be?
It has to be in the water exit path somewhere - is there a pump sump inspection? Is there a hose split? Likely the drain hose, or where it connects to the machine. Has the pump split open? Can you remove the machine cover and inspect it while it is doing a cycle so you can see where the water is coming from?
Apr 26, 2009 | Washing Machines
Water leaks
If there is water leaking from under the washer, then you have a water leak from one of your water hoses. Check the back of the washer, where the water comes into the washer, to see if its leaking water or the hose is cracked. If its leaking water from the intake hose, then unscrew the hose and check the rubber washer, to see if it needs reolaced. Sometimes those rubber washers get cracked or broken. If that doesn't help, unplug your washer from the power cord and unscrew your intake water hoses and flip the washer gently on it's side and check the water hoses under the washer for leaks or cracks. Replace the hoses if cracked. Your local hardware store should have replacement hoses. This should solve your problem, but if not, then you need to call a washer repair person to look at it. I hope this helps.:)
Jan 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Water running out from under the washer
sounds like two seperate problems. firsst water running from under your machine might be a bad seal, or water could be backing up the drain line. i would guess that it is a plumbing problem because of theissue with water in the sink. have a plumber snake out the drain lines and the problem with the washer should disappear.
Jan 21, 2008 | Speed Queen AWS52NW Top Load Washer
Washing Machines Logo
18 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
