Question about Samsung WF203ANW Front Load Washer
Drum is making nosie - Samsung WF203ANW Front Load Washer
  • Samsung Master
  • 17,130 Answers
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Posted on Dec 31, 2012
Tub not spinning made bad nosies before it stop spinning
if the main drum bearings have failed hence the noise it may have thrown thee drive belt open the door hold the drum top and bottom and try to push the drum up there should be no movement rotate the drum by hand any rumbling noise is so the bearins have failed
Mar 09, 2014 | Samsung WF218ANW 4.0 cu. ft. High...
Screaming nosie coming from mini cooper automatic
Possible power steering pump failure
Jan 25, 2013 | Cars & Trucks
Make a lot of nosie
Hi mervyn2011
Sounds like you have a bearing problem or drum roller/slide problems.
You will need to take the dryer apart to determine which problem it is.
For an owners manual go to the following webpage
Please take time to rate me
Bud
http://www.indesit.co.uk/indesit/_pdf/manuals/19504260005_UK.pdf
For parts go to the following webpage.
http://www.ransomspares.co.uk/parts/brands/indesit/tumble-dryers/is70c/
Oct 16, 2012 | Indesit IS70C Electric Dryer
My dryer heats and dries, but when i open the door the drum doesn't stop nor does the light come on. We've changed the bulb...not the problem with the light. Also was squeekin quite a bit..now...
as far as the drum not stopping when door is opened that will be a bad door switch
the noise could be anything from a drum support roller to a blower wheel,the bearing on the motor,the rear drum bearing or even something such asa coin caught between the drum felt seal and the drum
nosies a hard to diagnose online since they dont sound the same in written form
Aug 26, 2011 | Dryers
The washeers drum sounds a bit nosy I think smething might be stuck inside the inner drum. How do I get to check the inner drum?
the inside of the drum makes a clicking sound, and I located the noise at the back of the drum and the noise seem's to be in the central part where the bearings is located.
Jun 29, 2010 | Hoover Nextra HNWL 3166 Front Load Washer...
The drum is not spinning during washing or rinsing
Idler pully is the usual problem. The two tub roller will usualy make knocking sounds but can make squeling nosis.
Jun 06, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Bad sound when the washer goes into it's spin cycle
Your drum spider bracket broke. You will need to replace the complete drum assembly. The drum assembly will cost about $325 just for the part. If you can replace it on you own it will save you alot of money. To repalce the drum assembly you will need to completely disassemble the machine. If this is the route you want to go. I can walk you thru the process. Just let me know. Jeff
Jun 01, 2009 | Frigidaire ATF6000ES Front Load Washer
Just makes a hum nosie and won't spin or anything else
Sounds like the belts are off the bottom of the machine..
You may want to pull the front cover and look underneath.
May 30, 2009 | Washing Machines
Drum is making nosie like it dragging
Your motor that turns the drum could be going bad or the drum might be slowing down due to the axle it turns on might be "locking up". My bet first guess would be the motor.
Jan 27, 2009 | GE Dryers
Samsung WF203ANW Front Load Washer Logo
135 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
