Question about Boating
175hp 1996 choke issues
Fails to start when cold,needs Ether> Ok wnen hot.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 57 Answers
Try running some "Sea Foam" through it. Its good stuff. If not may require carb cleaning by a pro.
Posted on Jan 12, 2013
93 b2600.. cool days needs ether to initailly start, then fine. Sun beatingg on hood & hot; starts fine. go figure
Coolant temp sensor acts as engine choke for fuel injected cars, so if it fails you will have this issue. Some early fuel injected cars also had a "cold start injector".
Jul 14, 2015 | Cars & Trucks
1996 Chevy Astro V6 67K wont start when cold, needs engine starter fluid, ok when warmed up. Runs smooth. What is wrong?
I would say that the choke sensor (or whatever it is called) went bad & isn't telling the computer that it's cold & requires more fuel. Instead of starter fluid, did you try to push the foot feed 1 or 2 times?
Mar 07, 2015 | 1996 Chevrolet Astro
Auger won't start unless ether is sprayed into carb,then it will run until you stopauger . to re-startspray more ether
Is there a primer bulb that you need to prime? is there a choke that you can fully close proir to attempting to start.try holding full choke and throttle on initial cold engine start.if none of these help then a weak diaphram fuel pump may be the issue
Sep 06, 2014 | Ardisam Earthquake Earth Auger...
My 1996 Toyota Camry is having starting problem. It turns over but won't start unless I floor the gas pedal. Once she's running, she runs like a charm. She starts right up when I'm driving running errands....
all cars have automatic choke system when the engine is cold the choke is automaticall at onn
you must have noticed that when the car was ok and was cold started it use to stay at high rpm and after its warm the rpm reduces
so get your choke settings checked or needs some part to change in the choke system
Feb 11, 2011 | 1996 Toyota Camry
1988 chevy truck 2500 5.7 engine. After engine starts it runs like it is running lean until the engine warms up. On cold start you can spray ether in the throttle body and the engine clears up while...
EATHER IS NOT GOOD , ITS FOR COLD COLD MOTORS.. CHECK YOUR FUEL PRESSURE AND GAS FILTER .YOU MIGHT HAVE A BAD FUEL PUMP ITS IN THE GAS TANK!!! . USE CARB & CHOKE CLEANER ..PARTS MASTER # 1736 ..ITS NOT AS HOT AND WONT POP A HEAD GASKET .IF'N I WAS ANY HELP AT ALL PLEASE VOTE.. JAY
May 25, 2010 | 1988 Chevrolet Silverado 2500
My Yamaha 250cc BearTracker does not start when temps are below 60°F. Is there a fix? Should I try ether?
No ether can damage an engine and they can become dependent on it. Alot of ATV's are hard to start when it gets cold. Is the battery charged if equepted with one. You will need to choke it and let it run till it is warm and push the choke in when it starts to run rough. If this doent help let me know how it act's when this happens.
Oct 28, 2009 | 2002 Yamaha TT-R 250
No throttle when cold
HI
It is clearly that you have poor mixture.
Every engine needs more fuel in starting, thats the reason for the choke circuit.
But yours doesnt work as you said
Fix your choke circuit in your carbs and every thing will be OK
If you had problem with your fuel pump your bike never run ok cold or hot it dies in any throtlle response
Mar 28, 2009 | 1990 Yamaha FZR 250 R
Boating Logo
49 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
