Question about LG Washing Machines
Water coming out from bottom of washer - LG Washing Machines
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 31 Answers
Not sure if it is a front or top loader. But it can leak from bellow, pump, and drain hose.
Posted on Dec 30, 2012
Lift and support your washer. Check all hose connection on the bottom. If all hoses are good you may have a leaking water pump.
Sep 10, 2014 | Samsung SW62ASP Top Load Washer
Water leak from the bottom of washer
Hi friend, thank you for your post!
I understand that water is leaking from the bottom of your Frigidaire washer. There are many components that could cause a washer to leak the bellow (gasket), leak from drain hose, drain pump, or water valve. Since it could be any one of these underlying issues I would recommend having a technician come out to diagnose and repair your appliance. Hope this is helpful. -Matt
Jul 30, 2014 | Frigidaire Washing Machines
WHY IS WATER IS LEAKING FROM WASHER?
you just have to pull it out and take back panel off start filling with water and watch and see where it coming from a few rubber hoses under there or water pump.
Jul 30, 2014 | LG WM2016CW Front Load Washer
Oil in the bottom of washer
The oil is leaking out of the agitator gearbox. The water is coming from the seal on the agitator. I think the gears are badly worn..
Nov 19, 2013 | GE Washing Machines
Star washing went get to rinse circle stop, press stop bottom and start bottom tries to start but not work
if you're saying it dies in the rinse cycle you could have a problem with your cold water not coming into the washer,the washer only uses cold water in rinse cycle,no cold water the washer won't run,try starting it just with cold water and see if it fills,if not bad water valve or problem with water in house valve or bad hose.
Apr 08, 2013 | Kenmore 24032\24036 Top Load Washer
Where would the water come from if it is draining from the bottom of the washer when trying to fill tub
more than likely the pump is cracked and as it fills its leaking out. If I had the model number off the machine I could give you a better answer
Jun 05, 2012 | Washing Machines
I bought an Admiral washer Model No. ATW4475VQ. I bought it from Home Depot. The first washer was delivered, and when I did a load of laundry, water leaked from the bottom of the washer. I did not see any...
It's impossible to tell. from your description.
Usually a new washer is set up with new hoses. If the installers aren't complete idiots that should be good.
You can look at where the water lines come out of your wall and make sure it isn't wet there.
You could also test the water pressure at your house and make sure it isn't extremely high. Sometimes these new units can't take overly high water pressure.
Good Luck!
Mar 27, 2017 | Whirlpool ATW4475VQ Washer
WATER COMING OUT AT BOTTOM OF WASHER
Dear Sir,
In this case the seals surrounding the pistons (3 in number)..are faulty.
You can open the cover first ( by using a TORX T15 screw driver). Start machine in this way with all attached...( never run a power washer with out water and never store a power washer with pressure in it). When you start machine with out cover you can more easely see from where water is coming out. Mostly the case will be that water is coming out from between the head and the bottom part of machine. If water went into the bottom part...then the oil is ruined also.
So this case needs that all seals to be changed. One must inspect the pistons....because if the pistons are scrathed and pitted...then it is useless to put new seals. Thus new pistons must be put with new seals...and other gaskets renewed.
fulltech.
Feb 07, 2011 | Karcher K2.26 Electric Power Washer
Water is leaking from the bottom of the machine and will not fill up
Your water leak can come from 3 areas:
1) drain hose on back of washer is coming off / splitting / getting loose
2) water pump is leaking (cracked?) or has a gasket that has deteriorated.
3) hose between tub and water pump has come off / split / became loose.
Since your washer isn't able to hold water, it makes it easy to remove the clothes, and lean the washer forward to see what is going on. Most washers' mechanicals can be acessed from either the bottom, or from the back via access panel. The water leaks are generally a pretty easy repair.
Sep 18, 2010 | Admiral Washing Machines
Washer kenmore leaking water out bottom
Its very possible it could be one of the tubes that run to the fabric softener or detergent.
Dec 30, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing Machines Logo
15 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
