Question about Nordic Track NordicTrack C2155 Treadmill
My nordic track c2155 won't run
Will not run at any speed but incline does work
Gackmaster
  • 12 Answers
SOURCE: I have a Nordic Track EXP 1000X treadmill and the
Probably 85% of the time, it's the sensor.
1. remove the screws from the bottom of the enclosure case. 2 or 3 in the front and 1 on each side
lay it back down, and power it up, and actuate your incline. watch the end of the motor, to see if the shaft is moving. It probably IS turning but only a little bit. NOT enough. In this case I'd say it is the sensor.
2. Unplug the unit of course.
3. the incline motor is in the middle of the pack,..you'll see a black tube looking thing sticking up.
4. on the bottom side of this, you will see,..or feel for a black square sensor attached to bottom of the motor casing.
5. follow the wires and unplug this.
6. pry it off with a screw driver. Remove incline assembly, if you cannot reach it.
7. replace sensor and try it again.
if the MOTOR does NOT turn when using the incline buttons, the problem backs up to possibly a bad control board. or a bad motor on your incliner, however, i'd say that's the last thing to go.
Order of failure: 1. sensor 2. control board 3. motor.
good luck
Posted on Jan 26, 2010
  • 26 Answers
SOURCE: when i power my Nordic Trac A2050 on it powers up
This sounds like a bad controller. If the machine is under warranty contact the warranty provider. The controller is not hard to replace if you are electrically inclined but it does require calibrating.
Posted on Jun 16, 2010
  • 3 Answers
SOURCE: C2155 treadmill 1 1/2 yrs old, Nordic track. Panel
I had the same problem with my Nordic track. I pressed every button until I found the one that did not beep. The one that does not beep is stuck. My problem was with the Ifit button. The first few times I would push the bad button until it started beeping. That worked for awhile (couple of weeks but started up again). I disconnected the Ifit unit and now the thing work fine except for Ifit which I never used. Nordic track wanted to sell me a new console which cost more than the machine.
Posted on Oct 31, 2010
SOURCE: Nordic Track A2250 Pro stuck inclined
My Nordic Track Treadmill A2250 is stuck on the 12% incline position and it wont go back down and I have tried to reset it by turning it off, switching the reset button to off and then on or even unplugging it several times. What would be my next move?
Posted on Feb 13, 2011
  • 3 Answers
SOURCE: i have a nordic track
All, just figured something out. I had the evil beeping problem as well. I decided to play around and see if I could fix it. I unplugged the iFit adapter from the main control board and when I plugged it back in and tested it, IT WORKS AGAIN! NO MORE BEEPING!
Posted on Oct 29, 2011
I have a Nordic Track C2155 that doesn't power up on the display after inserting key. The red LED on the power supply board does light up
The circuit board is fried. It's too expensive to have fixed if the warranty is expired. You can try and find a used display from ebay or craigslist. It would be an easy swap.
Jan 01, 2017 | Nordic Track Exercise & Fitness
Wont incline
please RUN the software calibration, for easy diagnostic and fix it. GO Under the hood motor, and follow the steps . or read your owner manual or download from www.fitness.manualsonline.com
God bless you
Dec 01, 2013 | Nordic Track NordicTrack C2155 Treadmill
How do I install the walking belt for the nordictrack C2155
see the video and follow the steps and fix it. God bless you
Sep 29, 2013 | Nordic Track NordicTrack C2155 Treadmill...
How do I fix my Nordictrack Elite 7500? The incline is stuck and won't move up or down.
1) Lube the elevation motor, see the diagram, parts gear + shift
2) adjust the POT, for a little and see if there are better improve.
3) RUN the software calibration for diagnose, troubleshooting, fix it.
God bless you
Jul 09, 2012 | Nordic Track Exercise & Fitness
Nordic Track X5 belt won't move
1) Lube the deck belt, this happen because the electronic system protect the system and shut down.the cause is deck worn.
2) Lube the rollers bearing too.
3) Measure the input voltage motor, if there are the motor need repair.
4) Measure the output voltage board, for input voltage motor, if there are Not the board is faulty.
God bless you
Jun 12, 2012 | Nordic Track Exercise & Fitness
Will power on but doesn't go faster than 1 Mile or increase incline
Dear Sir:RUN inmediately the software calibration for easy diagnose and troubleshooting.Proceed according with the instruction manual
adjust the speed sensor, cleand, and tight the connector, may be the s. sensor is faulty.
May 03, 2012 | Nordic Track NordicTrack Treadmill, A2550
My nordic track apex 6100 xi all of the sudden won't run...or walk...at all? HELP!
Dear Sir:
This is probably a 1) faulty speed sensor or 2) the speed sensor is not plugged in properly. Its also possibly a 3)faulty motor control board or lower board.4)the drive motor is faulty 5) The drive belt is broken.6) Resent c.breaker 7) Test the power cord. 8) Reset the c. breaker from your home. 9) Do not use extension cord .
Adjust the speed sensor see the diagram, and RUN your software calibration for easy diagnose and troubleshooting. read your user manual.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Feb 11, 2012 | Nordic Track NordicTrack Elite zi...
Incline reads 0.0 but is not all the way down
Renee, Here is how to recalibrate the incline motor. Read all of it It will be good to keep.
Plug in your treadmill, do not stand on the walking belt. Hold down the "Stop" and "Speed +" key and insert the safety key or magnet, let go of the two keys. Now press "Stop" key once. This puts you into the level 2 of calibration. Press the "Speed +" key slowly until you see 85 on the console, (at this point the display is going to show the percentage of motor usage and also the actual walking belt speed) at 85% motor usage your top speed should be between 10 and 10.5 MPH or (of 12 and 12.5) depending on the treadmill. You must know your treadmills top speed. (Important the motor may be damaged if you set the maximum speed higher than the maximum speed that your treadmill is made for). If the speed is higher than 10.5 or 12.5 then you need to turn the potentiometer down to the correct level. If the speed it to low you need to turn the potentiometer higher. Once the speed is correct you are done calibrating the speed. Press the (-) speed key to lower the percentage to (0). Next press the incline (+) button, this will make the incline motor go all the way to the maximum incline and come all the way down to the level position. Then remove the safety key and the treadmill will reset into the normal manual mode, when you re-insert the safety key. Matt
Dec 04, 2011 | Nordic Track NordicTrack Treadmill, A2550
I have a nordic track c2155. it powers up, but every button i push makes it beep. i have made sure the reed switch is 1/8th away from the pulley and that the unit has power
Aug 19, 2009 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track NordicTrack C2155 Treadmill Logo
57 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Paul Sikkema
Paul Sikkema
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
