Why won't my Gigaware 2.1 multimedia speakers turn on?
Yes, I have them plugged in. Yes, I'm sure that they're plugged in correctly. No, I haven't had them for more than a week. A few days after having them, I decided I'd play a song from my phone. Well, after I got them turned on, and the sound input wasn't plugged in, I heard a lowish-pitched beeping that would change pitch and tempo whenever I adjusted the volume. I plugged the sound input into my phone's sound output... and nothing changed. Still the beeping. I looked to make sure that they were the right cords, that I didn't have anything messed up- and I was right, they were all correct. I then proceeded to turn them off and plugged the input into my computer, hoping that would make a difference. It sure did! Now the speakers won't even turn on! Whoopee! Aaaaanybody have any clue as to what's going on and how to fix it? I'd return them if it were just that easy, but just hours before we burned the box, along with all the other useless Christmas boxes. I have no idea where the receipt is, so returning them is most likely NOT an option. Thanks in advance!
shanth
  • 108 Answers
SOURCE: High pitch sound even with speakers disconnected
1.the problem with your audio processing circuits and improper power filter
2. Check audio amplifier coupling capacitors
3. Rectifier capacitors
4. contact service centre
Posted on Dec 22, 2007
Open SKy
  • 620 Answers
SOURCE: computer speakers make a fuzzy sound
Hello there
Yes, Niera, you have to update, the sound drivers, and see on BIOS if something is disable on sound. other than that is posible a a speaker problem.
Posted on Jan 14, 2008
  • 236 Answers
SOURCE: Alesis M1-Active left speaker emitts a very high pitched wine that sounds like feedback
have your built-in amp checked for trouble. there should be trouble in the output stage feedback loop. this is something to be done by a repair technician
Posted on Apr 11, 2008
trav1856
  • 57 Answers
SOURCE: x-540 speakers no sound rear speakers
rear speakers are not designed to put out the same output as fronts. They are for supplemental sound only, to make it seem like there's something happening behind you.
Posted on Dec 02, 2008
yooperbud
  • 8637 Answers
SOURCE: There is no sound coming from my speakers..
Check to see if the speaker s are plugged into the GREEN jack on the back of the computer.
It sounds like it might be plugged into the input jack.
Hope this helps. Bud
Posted on Jan 22, 2009
Where do I get a driver for my gigaware cat no. 4000380 usb speaker for laptop?
as the speaker is a usb connection , it is classed as plug-in
when you connect to the laptop and turn on the speaker power , the laptop will send you a message of new plug-in detected and will find the correct driver for you and install it
Feb 16, 2016 | Acer Computers & Internet
My gigaware 2.1 multimedia speakers (16W) sub rumbles/rattles at low frequencies
You seem to have opened up your speakers already. So, I think you should use your creativity to displace the parts a little so that no contact takes place even at max volume.
Dec 02, 2013 | Gigaware 2.1-Channel Multimedia Speakers
The subwoofer SP-PWM505 won't turn on.
Make sure its not set to Auto. Also check for a fuse in the back. Unplug the amp side and with the sub plugged in touch the RCA. You should hear noise from sub. Try this last. Some may say this is not good for the sub. Im in the business and never have seen it cause a problem
Jun 18, 2013 | JVC SP-PW100 Subwoofer
Plugged in & won't turn on? Where is the reset button?
hold down power video and computer buttons. probably lamp or button issue.
Jun 11, 2013 | Mitsubishi XD110U Multimedia Projector
Gigaware wireless mouse
With this particular model i've heard that downloading USB chipset drivers for your make and model of computer will fix this issue. Sorry i can't direct you to a direct link i don't have your computer details. Goodluck and let me know if this doesn't work
May 30, 2013 | Computers & Internet
Gigaware 2.1 multimedia speakers with Realtek HD audio manegerWhat's your problem?
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
hope this helps
Jun 06, 2012 | Computers & Internet
My samson servo 300's sound keeps cutting out, want to spray some electronic cleaner but not sure where ?
Yes; It maybe the protection coming on and off. This means there is a short in a speaker wire , or a blown speaker. The amp has 2 options for speaker hook up.1/4" plug and direct wire. If you are using direct wire it is possible to have frayed ends hanging around and can cause a short. You can test the speakers by unplugging them at the speaker, before you turn on the amp. Then turn it on, if the clicking still persist's turn off the amp and disconnect the speaker wires from the amp . Turn the amp back on. If the clicking still persists there is an internal problem with the amp. If not then you defiantly have either a wiring or speaker problem . You can test the speakers by using a 9v battery . Hook up the speaker wire to the speaker and put the battery on the other end of the wire, you should hear the speaker pop and see it move.If it moves it is still good. Note* this is also a good method of making sure your speakers are in phase. The battery is marked + & - the speaker will move forward when + is applied to the + of the speaker. make note of which wire is the +. if you get one speaker backwards it will cancel the sound of the bass. so hook the + to the red on the amp. Hope this helps you
Apr 26, 2012 | Samson Servo 300 2-Channel Amplifier
I bought gigaware docking speaker for iPod and it always charged my iPhone, but now all of a sudden it won't charge anymore It said something like accessory not compatible will not charge
sir you first clean your docking speaker and then charge it.. it will work fine. or other wise change your speaker there time is over.
Mar 29, 2012 | Apple Cell Phones
Unit won't turn on. Yes it is plugged in.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on; or it may turn on but produce no audio to the speakers.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Sep 13, 2011 | Technics SA-AX720 Receiver
Altec Lansing ada745 fuse
It is written on the sub. You can also take it out or look at the spare which is taped to the power cord wall plug. I believe it's T1A 250V fuse
May 15, 2008 | Altec Lansing Multimedia Computer Speakers
57 people viewed this question
 Grubhead
Grubhead
